Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Dec 31, 2020 at 7:35 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    So... anyone like TPMS?
  2. Dec 31, 2020 at 7:39 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    No
    teamhypoxia likes this.
  3. Dec 31, 2020 at 7:40 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I do when I have them and they work.
    CO MTN Steve likes this.
  4. Dec 31, 2020 at 7:42 AM
    johntoyota
    Down yonder in TN
    16 truck
    I dont necessarily trust the number that they read out most of the time but I do trust that they change when the pressure changes. I like them on the trails to let me know if one tire is dropping while I am on the trail.
    CO MTN Steve, xxTacocaTxx and Wulf like this.
  5. Dec 31, 2020 at 7:54 AM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    In my experience there is no need for it. My TPMS always read 3-5 psi different from the actual pressure in my tires. Not to mention that the door said 30 psi but it would randomly say one tire was low (changed which tire it was saying each time) while the readout on the dash said 30 psi on all 4 tires. I just look at my tires before I get into my truck, which is the same thing I have done with every vehicle I have ever owned (the Tacoma is the only one to ever have TPMS)
  6. Dec 31, 2020 at 8:03 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    Had to give up scrolling on the mouse and just use the scroll bar and drag it down. :bananadead:
    YamaDirtrider and Wulf[QUOTED] like this.
  7. Dec 31, 2020 at 8:05 AM
    deadpocketss
    deadpocketss Dingus
    Colorado
    '24 Subaru Crosstrek Premium
    Every battery is replaceable if you try hard and believe in yourself.
    johntoyota and Wulf like this.
  8. Dec 31, 2020 at 8:06 AM
    Wulf
    rock raisin
    Too many grateful dead stickers in the way?
  9. Dec 31, 2020 at 8:08 AM
    johntoyota
    Down yonder in TN
    16 truck
    Too many Grateful Dead experiences most likely.
    jubei likes this.
  10. Dec 31, 2020 at 8:22 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    The dummy light has no real value to me. If it was an active screen showing pressures with the ability to eliminate the warning light while running low pressures I would keep it. Even one up the system, the sensors have temperature data, if that could be displayed along with pressures that would be high value.
    Farcedude, teamhypoxia, jubei and 2 others like this.
  11. Dec 31, 2020 at 8:27 AM
    johntoyota
    Down yonder in TN
    16 truck
    You can set up a screen on OBDFusion that shows the pressures and the temps. I havent done it but I have seen the displays that have it set up that way. Its pretty sweet.
    The turd gens have a number display on the dash that is enough for me. Or was, when I had TMPS.
    literallynothing and xxTacocaTxx like this.
  12. Dec 31, 2020 at 8:35 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    More on my vehicles poor design faults. The 03-04 4runners can't handle almost all OBD dongles being plugged in while driving. Sets check engine lights and traction control lights due to communication interruption. Once I eliminate the ABS/electroboost setup I could likely get away with adding a reader to the system. My TPMS is still there, I just disabled the light and removed the sensors, my TPMS is also the door control receiver for wireless door locks so I couldn't eliminate it.
    johntoyota[QUOTED] likes this.
  13. Dec 31, 2020 at 8:37 AM
    Wulf
    rock raisin
    "decent condition"
    "Control arm ripped off frame due to rust"
  14. Dec 31, 2020 at 8:38 AM
    johntoyota
    Down yonder in TN
    16 truck
    Interesting you say that. For about a year, wherever the sensor that receives the signal from my fob is, has become very temperamental. I have replaced the batteries multiple time and thats not it. Sometimes it will work from 150' away (rarely) and sometimes it doesnt get the signal unless I rub the door with it. Seems to work better from the rear of the truck. I have wondered what the check is to fix it.
  15. Dec 31, 2020 at 8:38 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    "Drives fine until 30MPH"
    CG256 and johntoyota like this.
  16. Dec 31, 2020 at 8:43 AM
    Wulf
    rock raisin
    Best I can do is $350
  17. Dec 31, 2020 at 8:44 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Usually thoughts and prayers with that wireless voodoo.
    You have smart key?
  18. Dec 31, 2020 at 8:44 AM
    johntoyota
    Down yonder in TN
    16 truck
    I have a keyless push to start. I dont know if it qualifies as a smart key or not.
  19. Dec 31, 2020 at 8:56 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    Make sure you have no aftermarket LED lights (dome or entry lights) that are energized and accessories plugged into the the power ports. Stray RF and or ripple currents wreak smart key communications. One of the biggest causes of abnormal operations is aftermarket stuff on the dome light circuit. Typically the worst offender has been the large LED panel dome lights, they are very dirty electrically.
  20. Dec 31, 2020 at 9:00 AM
    johntoyota
    Down yonder in TN
    16 truck
    Damn it. I do have some Amazon led bulbs in the dome lights. One is burned out anyway. May switch back because I go in and out of the truck more times than I need those things on.
    If this works, your next Blue Yummy is on me! :cheers:
    Wulf likes this.
