Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 26, 2012 at 8:07 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I liked my 5100's
  2. Jun 26, 2012 at 8:11 PM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    I like my 5100's with 885 springs. Not as nice as some of the more expensive set-ups, but for a budget build they ride really nice.
  3. Jun 26, 2012 at 8:12 PM
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    Yeah I have been looking at that ad on cl for a while now, I wish I could get it, but I don't have the cheddar for it either. My luck I'd that I would get it and need more stuff to make it work and would be staring at it in the garage making me crazy.
  4. Jun 26, 2012 at 8:13 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Well, I bought my truck with 5100s. Then added eibachs later. I don't think it would be a bad start. Just depends what your end goal is. I like my set up but want a little more clearance.
  5. Jun 26, 2012 at 8:19 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Right now my only goal is to lift up the front end to closer match the rear end. I don't have any desire to do any crazy rock crawling or even serious trail riding so I don't need anything high end or expensive. I don't plan to do anything crazy so anything more than basic would just be overkill. It seems that maybe a set of front 5100's might be the answer. I guess I could maybe even do OME fronts too since they appear to be less expensive. Not sure that's the best option for stock springs though.
  6. Jun 26, 2012 at 8:38 PM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    Putting a add a leaf in isn't any harder than putting the coilovers in
  7. Jun 26, 2012 at 9:23 PM
    Ostrichsak
    Jer
    Wha? :confused:
  8. Jun 26, 2012 at 10:44 PM
    Madjik_Man
    Colorado Front Range
    If any of you firefighters are being called to duty...
    be safe and thank you.
  9. Jun 26, 2012 at 11:18 PM
    42boxer
    42boxer Well-Known Member
    Brannon
    Mcguire AFB, New Jersey
    2000 Toyota Tacoma TRD
    Plenty to come
    +1
  10. Jun 27, 2012 at 3:58 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Based on what your plans are right now 5100's would be your most cost effective solution to get a bit of lift and a better quality shock. If you wanted to go really inexpensive just to level the front get some leveling spacers for your stock coils. Less then $100. You can always upgrade later as you grow in this addiction. :D
    If you feel your off roading desires will grow over the next year then going OME now would be a better spend. HD would be for if you want a heavy bumper and winch up front. Otherwise go with the regular spring. These are just my opinions though. :)
  11. Jun 27, 2012 at 4:08 AM
    Gramps
    Gramps
    07 TRD DC 4x4
    Ostrichsak- from the other tread you asked if I was sure about 2.5 on the 5100's. For ride on the OEM springs not ideal but the UCA should still clear. But I thought I read that you just have the TSB in the rear correct? 2.5 in the front would be too high based on what I have seen from others who did this. You would need an AAL in the rear as well if you wanted 2.5 and new shocks too. IMO 1.75 would be the right height for the TSB only.
  12. Jun 27, 2012 at 6:56 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Just wanted pop in this thread, and say hope everyone is safe, and no property loss with the fires. Was listening to Colorado springs fire radios last night, and it was depressing at how many houses where burning.
    Anyway, be safe firefighters, and residents.
  13. Jun 27, 2012 at 7:37 AM
    T-Rex266
    Elon
    Thank you!
  14. Jun 27, 2012 at 7:40 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    some shots i got of the flagstaff fire from green mountain
    one of the springs fire creating it's own weather system :eek:
  15. Jun 27, 2012 at 9:04 AM
    Ostrichsak
    Jer
    I don't think I want to run spacers. I'm curious how a 5100 would compare to a OME setup for city/highway use since that's probably what my truck will see 99% of the time. I also wonder about long-term use which will last longer. I think all this just tells me I need to keep researching before I decide which route I'm going to go since I still have so many questions.
    Well, I took measurements which I posted (somewhere) and my truck after the TSB is 22.5" from the center of the wheel to the wheel well and the front is 19.75" for a total difference of 2.75" between the front and the rear. I realize it may be difficult to get to exactly 2.75" up front w/o spending lots of money but I think 2.5" would be pretty darn close and look much better than it currently does. The TSB was done just a few months ago so there's a chance it may settle a little more yet too although I'm not planning on too much more if any at this point.
  16. Jun 27, 2012 at 9:21 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    OME is setup to run springs and struts that are matched almost perfectly.
    5100s are setup to let the user install any spring they want, regardless of function or use.
    I will say this, I run my 5100s (set to zero) with OME 884 springs, I drive it daily and wheel the shit out of it. Either way you choose, you should get an aftermarket spring to go on the new struts, if you are concerned with ride quality.
    This would be a good option for you: Just reduce the pre-load on the coilovers, which will make it ride better, and you are set for a long time.
  17. Jun 27, 2012 at 9:25 AM
    TheGrinch
    TheGrinch Cheese Head.
    Sean
    RP, CA
    07 TRD DCSB OffRoad on 33's
    6" procomp lift
    fuckin a. i saw this last night. i guess its right near teh house we were at too.
  18. Jun 27, 2012 at 9:27 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    I disagree. I only have the TSB on the rear and set my 5100's to 2.5 and mine sits perfectly level. Have had no problems with the springs or UCA. It rides just fine. However, that is only my experience. Each truck might be a little different.
  19. Jun 27, 2012 at 9:44 AM
    Ostrichsak
    Jer
    Looks like a great option if you're covering the $900. :D
  20. Jun 27, 2012 at 9:45 AM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Were you in South Boulder?
