Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. May 8, 2021 at 6:02 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Never go full Karen right out of the gate.
    You leave yourself no room to escalate if necessary.
    CO MTN Steve, MGMTVCO, CG256 and 2 others like this.
  2. May 8, 2021 at 6:07 PM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Yeah I was just pissed to spend 2+ hours disassembling my truck to find out that they sent me the wrong shit. My initial reaction was actually “oh fuck did I order pipes for a superduty?” But luckily, they fucked up not me. Now if only I didn’t have a Bluetooth drive shaft in the Tacoma, i wouldn’t even really be mad
    MGMTVCO and teamhypoxia[QUOTED] like this.
  3. May 9, 2021 at 7:03 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  4. May 9, 2021 at 8:42 AM
    JasonLee
    15 TRD OffRoad
    @Madjik_Man sell both 1st gens and get this.
  5. May 9, 2021 at 11:25 AM
    Madjik_Man
    Colorado Front Range
    Too beefy for my diminutive truck aura.
    Beautiful 1st gen, though.
  6. May 9, 2021 at 11:26 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    Was reading up on OV Tune stuff and saw someone mentioned that stock 3rd gen is a "skip shift" were OV Tune turns it to "sequential shift". I can only imagine one means it skips gears in between and the other sequentially down/up shifts.
    Anyone know anything about this? Pros/Cons to either?
    MGMTVCO likes this.
  7. May 9, 2021 at 12:23 PM
    Wulf
    rock raisin
  8. May 10, 2021 at 7:12 AM
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    This Saturday...
    MGMTVCO likes this.
  9. May 10, 2021 at 7:13 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Saturdays are trail days.....not coffee shop days.
    MGMTVCO, Littles, Chadr7858 and 2 others like this.
  10. May 10, 2021 at 7:14 AM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    Anyone with a Leer topper, Can you please measure the crown between the track bars? Im looking at building my own rack, and want to know how much i need to raise the feet in order to clear the center crown of the topper. Im thinking 1 inch should do it, but I want to double check.
    Thanks
  11. May 10, 2021 at 8:28 AM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Where you going
  12. May 10, 2021 at 8:40 AM
    johntoyota
    Down yonder in TN
    16 truck
    Not sure this week. Maybe the gulches. Have hit most all of the regulars that are open in the last 4 weeks so might have to start repeating. You want to ride?
  13. May 10, 2021 at 8:56 AM
    JasonLee
    15 TRD OffRoad
    DO YOU HAVE A TABLE SAW?
    I need to cut four (4) 12-foot, 4"x8" cedar in half, turning them into 4x4's. Do you have a setup that could do this? I assume a table saw with a big enough circular blade and some type of roller dolly support thing on both ends to keep it from falling to the ground.
  14. May 10, 2021 at 10:25 AM
    Apollo14
    Jonathan
    Vail, CO
    nobody said you had to drive on the pavement to get there.
  15. May 10, 2021 at 10:26 AM
    johntoyota
    Down yonder in TN
    16 truck
    The part of the flyer that said "Denver, CO" did.
  16. May 10, 2021 at 11:48 AM
    Madjik_Man
    Yes.
    With all the construction the set up is buried deep in my shed. But if you're desperate I can make it happen for you.
    JasonLee[QUOTED] likes this.
  17. May 10, 2021 at 12:24 PM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
  18. May 10, 2021 at 1:08 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I do have a table saw, and... That's a lot of material to feed through a table saw. Most table saws have 10" blades, which give a max depth of 3-3.5". Four inches of material would take two passes--cut once, flip, and cut again from the other side. A cut like that can only be done safely if the board is flat and square on three sides (top, bottom, and one side to ride against the fence), and even then might be sketchy with a 12-footer.
    A band saw would be a better choice. Or even a chainsaw if you don't need it to be perfect.
    Personally, I'd look for a local saw mill and see what they'd charge.
  19. May 10, 2021 at 1:28 PM
    TomTomBikes
    TomTomBikes Does Things "On Purpose"
    ColoRADo
    2015 MGM AC V6 4x4
    none
    How accurate do you need it to be?
    I believe a standard skill saw can expose 2-1/4" of blade, so snap a chalk line one on side and cut, then flip over and repeat. I rip 2x4's in half like this all the time, but I also don't need to be very accurate and it's just one pass with those.
    Agreed on the table saw comments, it will most likely bind the blade and isn't very safe.
  20. May 10, 2021 at 1:55 PM
    johntoyota
    Down yonder in TN
    16 truck
    Not mine but I have a buddy that has one of those lathes that makes smooth edges on top and bottom and leaves the edges bare so you can have "rough cut" stuff. Could probably turn it 90 and do the other two sides. Not sure what the max opening he can do is.
