Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 16, 2021 at 10:41 AM
    TomTomBikes
    TomTomBikes Does Things "On Purpose"
    ColoRADo
    2015 MGM AC V6 4x4
    none
    Getting an alignment this afternoon, should I be specific about what they should do to give max clearance? Last alignment I was fine before, then rubbed real bad on the pinch weld after, and I'm back to no rubbing but visually out of spec.
  2. Jun 16, 2021 at 10:49 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Do you have the adjustable SPC UCAs?
  3. Jun 16, 2021 at 10:49 AM
    TomTomBikes
    ColoRADo
    2015 MGM AC V6 4x4
    none
    Yes I do.
  4. Jun 16, 2021 at 10:51 AM
    JasonLee
    15 TRD OffRoad
    Someone else with more suspension geometry knowledge needs to chime in here, but something about setting the SPC UCAs as forward as possible for clearance and then maxing out something as best as can be... or something.
  5. Jun 16, 2021 at 10:58 AM
    CG256
    CG256 Well-Known Member
    '19 TRD OR
    3.5 degrees of caster is what it took to get rid of my rub.
  6. Jun 16, 2021 at 10:59 AM
    TomTomBikes
    ColoRADo
    2015 MGM AC V6 4x4
    none
    Yup, that's where I'm at and why I asked.
  7. Jun 16, 2021 at 11:00 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Hope it is 4x4.
  8. Jun 16, 2021 at 11:03 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    @thefatkid
  9. Jun 16, 2021 at 11:05 AM
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    To get max clearance at the rear, first set the LCAs cams to maximize clearance (max castor). Then use the adjustability on the UCA to get things into spec. Just remember that adding more castor at the LCA adds clearance at the rear, while adding castor at the UCA removes clearance.
  10. Jun 16, 2021 at 11:56 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    Don't forget NY. A lot of them moved out here during Covid
  11. Jun 16, 2021 at 12:17 PM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
  12. Jun 16, 2021 at 12:22 PM
    JasonLee
    15 TRD OffRoad
    I call B.S. If you work for a company that makes a metric S*** ton of money, they shouldn't be able to dock you just because you live somewhere slightly less expensive. This is just another way for them to maximize profit and the billion dollar CEO salaries.
    RtacomaN and CO MTN Steve like this.
  13. Jun 16, 2021 at 12:39 PM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    100% he wants to maximize profits. However, if you were originally in the office and then told to wfh but now the office is open again, the company can require you to come back in. Assuming its safe and rules are being followed etc.
  14. Jun 16, 2021 at 1:00 PM
    alee891
    Austin
    Black Hills
    Tacomaless
    Isn't this counterpart to the "Californian's are driving up the cost of living in Colorado" conversation?
  15. Jun 16, 2021 at 1:06 PM
    JasonLee
    15 TRD OffRoad
    It's a lot more complex than just some people moving here with money. Economics is a complex subject and is typically responded to by emotions and psychological biases first.
    Phew, I think I avoided getting into politics with that response.
    dmurph1996 likes this.
  16. Jun 16, 2021 at 1:07 PM
    JasonLee
    15 TRD OffRoad
    Do you have an OVRLND camper?
    I know @crolison had one at some point... I'm thinking of switching over from the wedge but have some questions first.
  17. Jun 16, 2021 at 1:12 PM
    alee891
    Austin
    Black Hills
    Tacomaless
    Meh, I don't think the topics are that far off or complex as you're saying, at least for sake of TW discussion.
    Rich guy in New York doesn't want to pay out New York wages to remote employees now that the machine is ramping back up.
    Colorado "Natives" are pissed because those same people from New York (California & also Texas as you referred to earlier in a separate response) are bringing their higher wages to the State and raising the cost of living.
    hsMi6bAijkp5OlhWqwd3BZyDIjscoh8iC6lh0kee_37f68bf3c9baf18c5c8bd00ace708429ec970e45.jpg
    Edit: I'm also not arguing or disagreeing with you if it reads that way. It is BS that someone would want to reduce wages for their remote employees.... but those same individuals took a gamble in deciding to move to a different state entirely during a pandemic, and under uncommon work circumstances at that. We all knew things would bounce back eventually - now we're living it.
  18. Jun 16, 2021 at 1:14 PM
    Lindelowj
    Lindelowj Well-Known Member
    Jordan
    Texas
    2015 TRD Supercharged 4x4
    TRD supercharger kit, TRD skidplate
    I generally max out the caster if you have adjustable uppers!
    TomTomBikes[QUOTED] likes this.
  19. Jun 16, 2021 at 1:15 PM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    always down to learn about this too.
  20. Jun 16, 2021 at 4:21 PM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Max out your rear cam, set the SPC all the way forward and one position in towards the frame. Then use the front cam to do some caster adjustment, upper ball joint slides for camber, and tie rods for toe.
    teamhypoxia likes this.
