Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Apr 27, 2022 at 5:27 AM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    69420 South would be down in the Springs!
  2. Apr 27, 2022 at 6:56 AM
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    Wish I had seen this post earlier. I will be sure to do my research better in the future.
    xxTacocaTxx likes this.
  3. Apr 27, 2022 at 8:26 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    big breeze = big fun
  4. Apr 27, 2022 at 8:27 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Trout fish below the resi when they stock it and below the blue for wilds
    MtnMan307[QUOTED] likes this.
  5. Apr 27, 2022 at 3:18 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Well shitfuck. My 10 ton press decided to lock up today.
    It's almost fully extended, with about 6 tons of pressure on it and won't release.
    I drained the oil from the pump, removed the valve assembly, oil all over the place, and the ram is stuck.
    Smacked it vigorously with a hammer on every surface, no dice.
    Wtf?
  6. Apr 27, 2022 at 3:25 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thinking it may be time to dumb the thing down, remove the fancy bullshit that dont work and retrofit a 10 ton hydraulic jack and make it like the Harbor freight versions.
    Or drag it to the curb and put a $100 price on it and maybe someone will do me a favor and steal it.
    CO MTN Steve likes this.
  7. Apr 27, 2022 at 3:47 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    After looking at HF presses, I bet I can go a full 20 tons. Mine is built hell for stout compared to their stuff. Btw, a new 12 ton press is only $170.
    A 20 ton bottle jack is only $55.
    Then a bit of steel, a couple trampoline springs, which I have, and viola, 20 tons of metal mashing grunt.
    I don't use it that much, it sits in the corner with shit stacked around it. But it's nice to have when needed.
    Plus it was grandpa's press. Guess I've gone full circle and talked myself into going forward with it.
    :burp:
    xxTacocaTxx, 303tacoma, Wulf and 5 others like this.
  8. Apr 28, 2022 at 8:41 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    https://media.giphy.com/media/453QsWPQj5bsQaqp8M/giphy.gif
  9. Apr 28, 2022 at 4:50 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Any thought on dismantling a press ram under 6 tons of load without it removing parts of my body?
    Any volunteers?
    :popcorn:
    xxTacocaTxx and CO MTN Steve like this.
  10. Apr 28, 2022 at 4:55 PM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    50 BMG :infantry:
    Deathbysnusnu[QUOTED] likes this.
  11. Apr 28, 2022 at 4:57 PM
    Wulf
    rock raisin
    Tie 50 ft of rope to it and pull it over from a safe distance
    I'm sure someone has a smart idea tho
  12. Apr 28, 2022 at 5:02 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I can't even begin to get the high pressure coupler off of it, it's locked up tight.
    Need to get the ram to release before I remove it.
    Thinking of wrapping a towel around the threaded portion going into the ram and take a wrench to it.
    Things going to spew oil like a prom night pecker.
  13. Apr 28, 2022 at 5:28 PM
    2K01SpaceOtterSea
    2K01SpaceOtterSea Active Member
    Ash
    Steamboat Springs, Colorado
    Mighty Martha
    Cummins Sticker
    Could you pop the ram with a 22 from a rope's length?
  14. Apr 28, 2022 at 5:33 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It's in my garage, in city limits. But I like the way you guys think.:thumbsup:
    It was sketchy enough whacking it with a 12oz ball peen yesterday.
    CO MTN Steve and Wulf[QUOTED] like this.
  15. Apr 28, 2022 at 7:33 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    this thread sucks.
    So in an attempt to keep it alive, here is me cheating death.
    The mess. Fully extended ram, with remote pump.
    Here is the cast I was beating on. Pretty sure the allthread was holding the 10 tons back.....
    the top is the ram, then a brass? coupler...with differing threads on both...
    then what appears to be a house jack assembly, inverted and modified of course. Atta Boy Grandpa!
    All the bullshit in my way, grinder, precision antique key machine, generator, etc...
    I's like to save the house jack portion as it allows for a lot of adjustment for fitting shit together, but prolly won't happen.
    Diaper, and oil after loosening the fitting.
    drain pan, Dana 44 heavy duty diff cover. The bitch is an 1/8" thick and is for sale.
    and the ram retracted. :burp:
  16. Apr 28, 2022 at 7:50 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I think I'll do a complete disassembly and clean the pump and the hydraulic line and maybe see if it comes back to life. That pump also runs a porta power set That i have stuffed behind the press. I think the ram is fine, but the pump is the problem. A 20 ton press project is pretty intriguing though.
    odomandr likes this.
  17. Apr 28, 2022 at 8:57 PM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    Looking for input from you guys on a new build we're purchasing.
    House comes with 8' garage doors which I know are plenty for the Taco and my teardrop. The builder just asked us if we're interested in a new option to get 9' doors for +3k. Any solid reason to go to the 9 footers other than just because?
    Coop68 likes this.
  18. Apr 28, 2022 at 9:08 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I've got a 7-foot door and wish it was taller. 8-foot is probably plenty unless there's an RV in your future.
    If you haven't already, ask about insulated doors. Much easier to install insulated doors from the start than to retrofit them.
  19. Apr 28, 2022 at 9:33 PM
    CharlieCafe
    Charles
    That's the one thing I'm considering is if the wife one day decides she has to have a real toilet. Then I'll need to switch the teardrop for a larger trailer.
    Also confirmed they are insulated. That's a must, last house we had didn't and the garage was north facing making it fking cold in the winter.
    303tacoma, xxTacocaTxx, Wulf and 2 others like this.
  20. Apr 28, 2022 at 9:34 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Anything that'll fit through a 9 footer will fit in an 8 footer but the reverse isn't true.
    Cost you a hell of a lot more than 3k to try and convert an 8 footer
    303tacoma, xxTacocaTxx, Wulf and 3 others like this.
