Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Sep 18, 2022 at 2:37 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
  2. Sep 18, 2022 at 3:56 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Fuckin carnivores.
    Luv ya :D:thumbsup:
    CO MTN Steve, Littles, jubei and 4 others like this.
  3. Sep 18, 2022 at 4:52 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Anyone able to help me get this damn crawl box in in the next couple days? I tried but can't do it by myself. In Frederick. Thanks
    ShiftyShank and CO MTN Steve like this.
  4. Sep 18, 2022 at 5:03 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  5. Sep 18, 2022 at 7:22 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I am not a vegetarian because I love animals.
    I am a vegetarian because I fucking hate plants.
  6. Sep 18, 2022 at 7:23 PM
    eurowner
    eurowner Duke Sky
    Scoty
  7. Sep 18, 2022 at 7:23 PM
    JasonLee
    15 TRD OffRoad
    Yeah, those have 20k on them :/
  8. Sep 18, 2022 at 7:24 PM
    JasonLee
    15 TRD OffRoad
    I may put the OEM UCAs back on after some fresh boots.
  9. Sep 18, 2022 at 7:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I am thinking about buying a new set of joints and then warranting these and having them on hand to swap out in the future.Warranty should be very easy and simple with SPC
  10. Sep 18, 2022 at 8:18 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    found a mini mag lite in a ceiling several months ago. The battries were at that time firmly degraded and lodged in the tube solid.
    \Question is, how do I get them out? Already tried lubricunt and banging it against the workbench.
    Next i drilled out the inside of the battery, and it hissed at me, at which point I stuck it in a 1 1/4" square tube outside and left it there.
    any suggestions? I feel like the flashlight itself can be rescued if the degraded cells can be removed.
  11. Sep 18, 2022 at 8:58 PM
    JasonLee
    15 TRD OffRoad
    i bought a new set from O’Reilly for about $120. Going to send in old for warranty and hopefully have a spare like you stated for the next 20k change.
  12. Sep 18, 2022 at 9:12 PM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    Anything that eats the corrosion will likely destroy the workings of the flashlight. I would get a new mini mag, or, since you already drilled it, put a screw in it and yank it out. You already released the built up pressure, so now you have either lithium to worry about or sulfuric acid
    edit: it’s a tiny battery so it’s not a huge deal. Please don’t do that to an e-bike battery or larger.
    Wulf likes this.
  13. Sep 19, 2022 at 4:42 AM
    Kappes03
    Kappes03 [OP] Legend of the UG
    Colorado
    2014 Tundra CM
  14. Sep 19, 2022 at 7:20 AM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I could give you a hand one night this week after work. I have a trans jack and the crow foot wrenches you'll need for the top bolts if needed.
  15. Sep 19, 2022 at 7:29 AM
    eurowner
    eurowner Duke Sky
    Scoty
    If you can determine what the battery brand is, Enegergizer, Duracell, they will warranty the whole light.
    Deathbysnusnu[QUOTED] and Wulf like this.
  16. Sep 19, 2022 at 8:06 AM
    CG256
    CG256 Well-Known Member
    '19 TRD OR
    Heat or cold might help separate them. Throw it in the freezer for a little while and see what happens.
    If they're corroded instead of swollen maybe drizzle vinegar down around the battery to try and loosen it up, then dissemble and clean with rubbing alcohol.
    Deathbysnusnu, reallifedog and Wulf like this.
  17. Sep 19, 2022 at 8:26 AM
    CG256
    '19 TRD OR
    Have you tried taking the lighting element out from the top to see if you can't just ram the batteries out? Probably going to need to do that anyway to clean the corrosion and vinegar.
    Last ditch would be to ultrasonic clean it in mineral oil for however long it takes.
    Figuring out how to spend a few hundred dollars in time, effort and equipment to save a $35 dollar flashlight is the exact kind of distraction I need on a Monday.
    JDM, jubei, Deathbysnusnu and 2 others like this.
  18. Sep 19, 2022 at 10:18 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    already took it apart down to the bulb, it has a piece on top that says"Do Not Remove", so that's where I stopped.
    I'll try the freezer thing, see what happens.
    CG256[QUOTED] likes this.
  19. Sep 19, 2022 at 10:20 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Sissy
  20. Sep 19, 2022 at 10:26 AM
    CG256
    '19 TRD OR
    They should have put in a piece that says "Don't drill into batteries.":rofl:
