Colorado dealers who have dealt with this? Lane Changing Flashing Blinks
Discussion in 'Colorado' started by SeniorSpan, Mar 30, 2023.
  1. Mar 30, 2023 at 9:29 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    G'day all,
    I need some help. I recently traded my 2018 Tacoma TRD DCSB OR for a 2023 Tacoma TDR DCSB OR. When I purchased the 2018 I requested the dealership change the "Lane Changing Flashing Times setting" from 3 blinks to 7. The Tech Stream tech did that with out question and I had my truck back quickly.
    Requested the same procedure be done to the 2023 and no one at the dealership know what I'm talking about. I called the second dealership in town and asked if they could preform the procedure, again, I was talking a foreign language.
    I called Toyota in Texas, they admitted they had never heard the request before and could not help me.
    So, I'm turning to the TW Colorado members to ask if anyone knows of a Colorado dealer who has done the for a 2023 Tacoma any would provide me the dealers name and location.
    thanks much in advance.
    Bob
    skippyscage likes this.
  2. Mar 30, 2023 at 9:37 AM
    Sypherd
    Sypherd Custom Titled
    Michael
    Dripping Springs, TX
    2021 Sky Silver TRD 4x4 OR
    Pedal commander, Downhill Dragon Tuning, Gator SFX Tri-fold tonneau (sometimes)
    is this a relay replacement situation or software toggle?
  3. Mar 30, 2023 at 9:40 AM
    Firn
    Firn Well-Known Member
    White OR
    The app Carista and a small dongle for the OBD will let you do it yourself. There are a couple other options it will let you tweak as well, below is the list.
    Dings & Warnings
    Seat belt warning ding (driver)
    Enabled / Disabled
    Seat belt warning ding (front passenger)
    Enabled / Disabled
    Ding when key is left in the car
    Enabled / Disabled
    Ding when headlights are left on
    Yes / No
    Key-in-ignition ding sound
    Slow / Medium / Fast
    Remote low battery warning
    On / Off
    Driver Assist
    Pre-Collision System (PCS) sensitivity: remember last state
    Enabled / Disabled
    Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
    Far / Remember last distance
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
    Rear Cross Traffic Alert (RCTA) system
    Enabled / Disabled
    Heater & A/C
    Auto-turn on A/C when AUTO button pressed (if needed)
    Yes / No
    Open vents to outside air when ignition is turned off
    Yes / No
    Auto-increase blower speed when front defroster is on
    Yes / No
    Link air flow to A/C operation
    Yes / No
    Fan speed reaches its target…
    Slowly / Normally / Fast
    Instruments: Displays & Nav
    Instrument lights dimming sensitivity
    Darkest / Darker / Normal / Lighter / Lightest
    Instrument lights restoring sensitivity
    Engine start indicator
    On / Off
    Display odometer after ignition is turned off for…
    30 seconds / 1 minute / 10 minutes / Off
    Microphone sensitivity
    1 - 11
    Lights: Automatic
    Auto headlights activation threshold
    Lights: Exterior
    Daytime running lights
    On / Off
    Lane-change turn signal auto-flasher count
    Off / 3 flashes / 4 flashes / 5 flashes / 6 flashes / 7 flashes
    Coming-home lights duration
    Off / 30 seconds / 60 seconds / 90 seconds
    Lights: Interior
    Interior light control
    Enabled / Disabled
    Turn on interior lights when you shut off engine
    Yes / No
    Turn on interior lights when you unlock doors
    Yes / No
    Turn on interior lights when smart key in range
    Yes / No
    Dim interior lights after…
    7 seconds / 15 seconds / 30 seconds
    Locking: Automatic
    Wireless door locking
    Enabled / Disabled
    Auto-lock all doors
    Disabled / When shifting into gear / When vehicle starts moving
    Auto-unlock all doors
    Disabled / When shifting into park (P) / When driver's door is opened
    Re-lock doors automatically if you unlock, but don't open a door
    Yes / No
    Re-lock doors automatically if you unlock, but don't open a door within…
    30 seconds / 60 seconds / 120 seconds
    Locking: Beep & Blink
    Beep when locking/unlocking with remote
    Yes / No
    Volume of beep when locking/unlocking with remote
    Off / 1 / 2 / 3 / 4 / 5 / 6 / Max
    Blink turn signals when locking/unlocking with remote
    Yes / No
    Locking: Doors & Alarm
    Unlock doors via remote
    Driver's door on 1st press, all on 2nd / All doors on 1st press
    Unlock doors via physical key
    Unlock doors via smart key (door handle button)
    Max number of consecutive lock/unlock cycles via touch sensor
    Unlimited / 2 times
    Warn (beep) when door can't be locked because it's still open
    Yes / No
    Warn (beep) when sunroof is still open when locking doors
    Yes / No
    Locking: Smart Key
    Stop monitoring for car key signal after…
    0 - 5 days
    After locking with smart key, don't allow re-opening within…
    0.5 seconds / 1.5 seconds / 2.5 seconds / 5 seconds
    Smart key location to start car
    Front seats / Anywhere in vehicle
    Parking Sensors
    Parking sensor beep volume
    Low / Medium / High
    Activate parking sensors in neutral (N)
    Yes / No
    Enable rear parking sensors when in neutral or forward gear
    Rear / Rear corner / Off
    Rear parking sensor range
    Narrow / Wide
    Windows & Sunroof
    Open driver's window using single button press
    Yes / No
    Close driver's window using single button press
    Yes / No
    Open passenger's window using single button press
    Yes / No
    Close passenger's window using single button press
    Yes / No
    Passenger window single-touch-open from driver's switch
    Yes / No
    Passenger window single-touch-close from driver's switch
    Yes / No
    Other
    Panic function on remote
    Enabled / Disabled
  4. Mar 30, 2023 at 1:42 PM
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Thanks Firn,
    I will consider that; however, the option to change the "Lane Changing Flashing Time setting" from the Toyota default 3 blinks to 7 is suppose to be done by the dealer, so gonna elect to stand on principal for the time being and hope another member knows of a Colorado dealer who has made the change for an owner.
    Thanks again for your reply
  5. Mar 30, 2023 at 7:48 PM
    skippyscage
    skippyscage Well-Known Member
    2023 Tacoma TRD Off Road
    I'll be asking the same when mine goes for its first service - 5 blinks from the too short 3, but that'll be some time away I suspect
  6. Mar 31, 2023 at 2:26 PM
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Here's an up date. I found a Toyota pdf called Toyota Personalization; it appears to be a document that at least at one time, was given to a new owner of a Toyota to select the personalization setting they desired to be changed. There are 5 pages. The one my concern is with is "Lane Change Flashing Times Settings". The options given on the pdf are OFF 3, 4, 5, 6, 7.
    I called several dealers, they thought I was talking a foreign language; I called Toyota of Colorado Springs and talked to the service manage, Kevin Whitlock. He listened to my request , check with his Tech Stream guy, had me bring the truck in, and a total of an hour later I was driving home with 7 blinks for lane changes at no charge.
    Thank you Kevin Whitlock of Toyota of Colorado Springs
    Bob
    GoldenBrew, Madjik_Man, Wulf and 3 others like this.
  7. Mar 31, 2023 at 3:09 PM
    skippyscage
    Do you have a link to that PDF?
  8. Mar 31, 2023 at 3:54 PM
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
  9. Mar 31, 2023 at 4:16 PM
    skippyscage
    Thanks. Good ammo for when they say they don’t know
