Colorado high altitude driving...no power, help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trdchic, May 14, 2018.
  1. May 14, 2018 at 8:46 AM
    trdchic
    trdchic [OP] Well-Known Member
    Erie CO
    07, TRD Sport, 4x4, SR5, V6, Access Cab
    I'm in Boulder and spend a lot of time in the Rocky's. Driving up the 70 through Vail pass, my truck is embarrassing. Feels like I have NO power. Granted this is 10k feet...but still I don't like being passed by everyone....or driving at 4000+ rpm all the time.
    Any suggestions?
    I'm at about 200k miles so nothing crazy like supercharging. Does my girl just need more air?
  2. May 14, 2018 at 9:04 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I have noticed this when I was in Colorado, but I had a trailer with a sxs on it. Felt like she was down on power through the continental divide as compared to flat, lower Texas, I just figured it was weight and steep grade and thin air. I had problems breathing, I could only imagine my motors trouble. Houston Texas air is like breathing soup compared to Colorado when I went up there
  3. May 14, 2018 at 9:13 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Could be a faulty o2 sensor or something easier like a dirty air filter. I vacationed in Colorado a couple years ago and I had to downshift more than usual on some of those insane passes. In some parts of Colorado 10,000 feet is a valley.
  4. May 14, 2018 at 9:14 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Yeah, try it with a 4 banger. I did it for years. Getting passed by 18 wheelers full of barbie dolls. Do you even know what that does to a man's testosterone levels??? I am not sure there is any answer other than forced air, besides gearing down or going smaller on tires
    obhuan, kidthatsirish and 2ski4life7 like this.
  5. May 14, 2018 at 9:28 AM
    Shelf Life
    Rob
    Central Oregon
    I noticed the gas is lower octane in parts of Colorado too. Lower air pressure, you can run cheaper gas, but it robs power.
  6. May 14, 2018 at 10:18 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Gravity and altitude is the culprit here!
  7. May 14, 2018 at 10:20 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Altitude robs power OP. I googled around to see if I could figure out how much, various rules of thumb reveal you could be losing 70-95 horsepower driving at 10,000 feet just due to thinner air. That's pretty high. It's normal for engines to struggle big time at those altitudes.
  8. May 14, 2018 at 10:23 AM
    Bebop
    Nick
    Forced induction is probably the only cure to this problem
    ItalynStylion, kidthatsirish and jsi like this.
  9. May 14, 2018 at 10:24 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    It's a Toyota. This is normal. Getting a supercharger is really only way to get more air.
  10. May 14, 2018 at 10:38 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Hmm I’m in the same areas sometimes..
    I feel like I have plenty of power
    My truck is about the same..
    Has it always been this way or a recent change?
    Are you stock or lifted?
    Bigger tires?
  11. May 14, 2018 at 10:40 AM
    Nomad_Pilot
    Clay
    Ft Collins
    To combat this, some small airplanes have what they call a turbo normalizer. It's basically a turbo with the waste gate set at 14.7 psi. So at sea level it's not doing anything for the engine, but as you climb in altitude, it gets sea level performance all the way to cruise altitude.
    trdchic[OP] and Bebop like this.
  12. May 14, 2018 at 10:56 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    My folks live in higher altitude CO when I go visit with the 85 octane combined with altitude my truck feels like it won’t pull a greasy string out of a cats ass.:bananadead:
    trdchic[OP] likes this.
  13. May 14, 2018 at 11:42 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    85 is actually giving you more power, its easier to burn and because of the less compression pressures you achieve you can run a lower octane and not have spark knock. If you ran a higher octane you will make less power.
    OP. its altitude. you loose 3-4% of power every 1000ft above sealevel. 10kft you are looking at 30-40% down on power, thats 70-95hp down from claimed figures.... yeah its gonna feel slow.
    Just let her rev is all you can do.
    skier and MattCowsmasher[QUOTED] like this.
  14. May 14, 2018 at 12:15 PM
    Pigpen
    Dan
    Northwest Montana
    Nobody asked what maintenance has been done to the truck. Change your air filter and spark plugs, if you haven't already.
    What size are your tires? What load range are they? What tread type? 33" load E mud tires will kill fuel economy and power.
    These trucks aren't race cars, but if you aren't hauling weight or on huge tires, it should be able to keep up with traffic.
    I lived in Summit County and drove a 4 banger Nissan pickup. I know all about revving high and still getting passed on 70.
    Edit: Looking at your avatar, I see you have a lift, aggressive tires, and a plate bumper. Any more armor? All of this will reduce power and fuel economy.
    303tacoma likes this.
  15. May 14, 2018 at 12:22 PM
    spitdog
    Well I lived in Arvada Co. for over 35 yrs and would make weekend trips into the mts. I also had a v6 tacoma never had the problem you described. You can’t approach vail pass or the Tunnel at 50 mph on the climb and expect a snap response. You have to use the declines and low spots, as a time where you gain momentum through acceleration for the approaching climb. You anticipate all your moves in the mts. because the mts. and altitude will rob you of your speed. The Tacoma v6 will do fine,it ain’t no v8, but in the mts. you need to work with what you got and give it a little help.
    mcgov303, kimo and 303tacoma like this.
  16. May 14, 2018 at 12:49 PM
    trdchic
    Erie CO
    smaller tires?!?! no way lol
    MattCowsmasher likes this.
  17. May 14, 2018 at 12:52 PM
    trdchic
    Erie CO
    The armor isn't excessive, the bumper is AL so not much heavier than what I took off. Same with the rear bumper. But I do have full belly skids and now a camper shell...
    The lift is only about 2 1/2- 2 3/4" and the tires are 33" MT...so ok I am starting to see the trend here. All my fun/sexy attire is weighing me down.
    *sigh* well at least everyone can get a good look as I cruise by slowly hahaha
  18. May 14, 2018 at 12:54 PM
    trdchic
    Erie CO
    Interesting on this one... I run 87, that's the min I remember in in NV and CA so I was suspicious of 85 when I moved here
  19. May 14, 2018 at 12:56 PM
    trdchic
    Erie CO
    Ok now I am confused on the 85 situation...going to Google
  20. May 14, 2018 at 1:09 PM
    charcharias
    charcharias Well-Known Member
    Chuck
    Denver
    2013 TRD Sport
    As per the good folks at http://www.wallaceracing.com/braking-hp.php...
    "Your BHP loss computed from your BHP of 236 at sea level and Elevation of 10000 feet is 70.80 HP loss."
    When you're crossing the Eisenhower tunnel...
    "Your BHP loss computed from your BHP of 236 at sea level and Elevation of 11158 feet is 79.00 HP loss"
