Colorado high altitude driving...no power, help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trdchic, May 14, 2018.
  1. May 15, 2018 at 8:24 AM
    #41
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    No sir, elevation is absolute. You are on the ground, 10,245 ft above sea level. Altitude is a reference of atmospherice pressure for almost all accounts. So at 10,000 ft on a 105°f day, the pressure altitude may be 11,900, while you are physically only 10,000 ft in elevation.
  2. May 15, 2018 at 8:24 AM
    #42
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    That’s so funny I spat out my coke.
    o0oSHADOWo0o[QUOTED] likes this.
  3. May 15, 2018 at 8:45 AM
    #43
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Cat may be eating too high of an octane if a butt scoot lights up.
  4. May 15, 2018 at 8:49 AM
    #44
    Shelf Life
    Rob
    Central Oregon
    I'm spoiled in Oregon. Mid grade is 89. I've been running it for years.
  5. May 15, 2018 at 8:52 AM
    #45
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    It's just static due to the cold dry air at altitude. :rolleyes:
  6. May 15, 2018 at 11:11 AM
    #46
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    As opposed to "at elevation".
  7. May 15, 2018 at 12:09 PM
    #47
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Its not confusing. Less atmospheric pressure equals lower air charge in a natural aspirated engine. Lower air charge equals lower maximum compression (WOT), allowing use of lower octane fuel without detonation. I am not sure about the "higher octane equals less power" statement. I know high elevation equals less air, less air equals less compression, and with less compression you can run lower octane without the risk of detonation you would have at normal elevation.
  8. May 15, 2018 at 12:23 PM
    #48
    Pigpen
    Dan
    Northwest Montana
    I always run 85 when I'm in higher elevations. Up here in the low country, it's not even available. I live at 3000 feet.
  9. May 15, 2018 at 2:20 PM
    #49
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not if you know what you are doing...
  10. May 15, 2018 at 2:21 PM
    #50
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    If somebody uses altitude in normal conversation when they mean elevation and you call them out on it you might be right but also nobody in the room likes you
  11. May 15, 2018 at 5:00 PM
    #51
    81shark
    81shark Well-Known Member
    I always seem to get high in co
    TomTomBikes likes this.
  12. May 15, 2018 at 10:10 PM
    #52
    crx7
    crx7 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    I live in Grand Junction. The trick is heavy foot. Floor it and let it down shift. Otherwise URD long tube headers and/or supercharger.
  13. May 16, 2018 at 9:08 AM
    #53
    Shelf Life
    Rob
    Central Oregon
  14. May 16, 2018 at 9:14 AM
    #54
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    I have a house at 9300' and travel two higher passes to reach it. Stock tires, MT and no extra weight certainly help. There's a reason turbo cars and trucks (think Subaru and turbo-diesel) are so popular around here.
