Colorado In March?
Discussion in 'Colorado' started by RookTRDOR, Feb 13, 2021.
  1. Feb 13, 2021 at 3:21 PM
    RookTRDOR
    RookTRDOR [OP] New Member
    2020 Cement Tacoma TRD OffRoad
    Hey everyone! I'm driving to Denver, Colorado from Texas on the third week of March. Itll be my first time going in my Taco and I was hoping to get some advice in terms of roads and weather conditions? I drive a stock 2020 TRD Offroad and I'm pretty nervous about the snow/ice. Any advice is wanted and will be extremely appreciated!!
    Also does anyone have some off road trails a stock Taco and newbie offroad enthusiasts can do?
  2. Feb 13, 2021 at 3:48 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Watch www.cotrip.org all the time.
    Avalanche danger is high and will be for a while.
    psychic_legume and RookTRDOR[OP] like this.
  3. Feb 13, 2021 at 3:53 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    Put faith in the Tacoma and just go! Leave all worries in Texas
    RookTRDOR[OP] and boston23 like this.
  4. Feb 14, 2021 at 4:10 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Well it is the snowiest month of the year...:D
    RookTRDOR[OP] and CO MTN Steve like this.
  5. Feb 14, 2021 at 6:26 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    720-722-1204 connects you to Colorado 4x4 Rescue and Recovery who will recover you for free if you get yourself stuck badly on a trail. If you're within a couple hours of Denver or Colorado Springs, you have a good chance of them helping.
    Colorado has a couple of enforcement codes during inclement weather: Code 15 (the first to be enacted, usually) and Code 16 (last resort before closing the highway). Can't say I've heard of Code 16 getting enacted in the very general Denver area; if the highways around here get that bad, they just shut 'em down. If your tires have at least 6/32" of tread depth then you're fine if Code 15 gets enacted.
    Typical trick (which I don't do, but it works) is to throw weight into the bed to increase the rear tires traction. If my rear tires slip, then the conditions are probably good enough for 4wd. Reduce your speed, leave a larger gap between you and the vehicle ahead, and don't do anything suddenly or aggressively (like stabbing the brakes, whipping the steering wheel, mashing the gas pedal). Bags of sand are preferred as bed weight since they double as a traction adder if you're stuck and the tires are slipping; throw some of it down to get unstuck.
    If you want to explore off pavement, stick to maintained dirt roads. They'll be plenty enjoyable to you with some snow on them. Tackling a real trail in March requires a whole lot of prep: tons of recovery gear, and keep-you-alive gear. I'm a huge proponent of chains; I haven't owned recovery boards and unless you have a half dozen of them, my first hand experience helping someone use them to get unstuck is that you make very slow and tiring progress... A winch and chains have got me through many challenging situations over the years.
  6. Feb 14, 2021 at 10:53 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    If you don’t plan on coming to the mountains I wouldn’t worry too much about the snow, the front range is typically pretty mild. If it does snow follow @JDM advice.
    RookTRDOR[OP] likes this.
  7. Feb 15, 2021 at 5:22 PM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    It doesn't snow here anymore. Texas took it all.
  8. Feb 19, 2021 at 12:24 AM
    HighCountryTacoma
    Colorado
    They’re taking all of the real estate as well.
    Kolter45 and Rock-N-Roll like this.
  9. Feb 19, 2021 at 12:27 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
  10. Feb 21, 2021 at 10:29 PM
    RookTRDOR
    Thank you all! Im fairly new to this so I dont know how to reply haha. I will keep all of this in mind and I'm ready to give CO back their snow
  11. Mar 21, 2021 at 7:13 PM
    psychic_legume
    psychic_legume Well-Known Member
    2002 White Tacoma TRD
    I think they shipped it all back last week. I measured at least 2.5' in Golden.
    Tried to get back into my garage after being out all day and got stuck for my troubles :)
