Colorado Trading Post
Discussion in 'Colorado' started by NYCO, Mar 30, 2011.
  1. May 13, 2019 at 10:43 AM
    Theetrentmeister
    Theetrentmeister Well-Known Member
    Thanks for the info, I am curious if in the future it starts to get worse how much did it cost to have your ARB re-done? I assume it wasn’t cheap haha
  2. May 13, 2019 at 11:13 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Haha yeah it wasn’t cheap...around $400.
  3. May 13, 2019 at 11:17 AM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Paid less for my white arb :eek:60511D4D-F2BA-4516-A849-7F44872D6418.jpg
    EnBoo likes this.
  4. May 13, 2019 at 11:26 AM
    10tacotrooper
    10tacotrooper Well-Known Member
    Andrew
    Thornton ,CO
    2010 Super White Tacoma dcsb offroad
    I’ll take those if he doesn’t want them
  5. May 13, 2019 at 11:31 AM
    EnBoo
    EnBoo Well-Known Member
    Nathan
    Denver, CO
    2018 DCSB Quicksand Sellout
    Gonna pass. All you
  6. May 13, 2019 at 11:42 AM
    50 amocaT
    50 amocaT Well-Known Member
    Jeremy
    H.Ranch Co
    TSB pack with a Toytec AAL installed. AAL has ~40k miles with rarely a load in/on the bed. Cost is some Double IPA goodness.
    I have (4) 40mm ammo cans for sale. I did the ammo can behind seat storage mod that required 2. I was ambitious for buying the others so here I am selling them. Selling for what I paid; $15/each
    Ammo can mod link (https://www.tacomaworld.com/threads/back-seat-storage-40mm-ammo-can.404841/)
  7. May 13, 2019 at 11:43 AM
    r2oh
    r2oh Well-Known Member
    Denver Colorado
    2010 white tacoma trd sport
    Fox 2.5 factory series dsc coil over Fox 2.0 dsc Total chaos uca Total chaos lower control arms Ome dakar Toytec extended break lines Scs stealth 6 gunmetal grey wheels bfgoodrich a/t ko2 tires 285/70/17 Quick stop drilled & slotted rotors Trd cold air intake (1st gen) Trd exhaust Optima yellow top battery Rigid 40" led bar and 4 pods & 20" Retrofit masters custom headlights Rci front,transmission,transfer case skid plates Pilfreybuilt front bumper single hoop Smittybuilt 9000xrc comp winch Factor 55 fairlead InSain fabrication cmc and sliders Total chaos weld on cam tab guests U bolt flip kit Prinsu roof rack Cvj axels Jersey hubs wheel bearings Ecg needle bearing Cvj rack and pinon
    Yeah just let me know
  8. May 13, 2019 at 11:49 AM
    commonsense87
    commonsense87 Well-Known Member
    Noah
    Edwards, CO
    2013 DCLB w/ Flatbed
    35’s and a flatbed ‍♂️
    Bump. Drop to $650 or make me an offer. I need it gone
  9. May 13, 2019 at 12:25 PM
    TJLILMAN
    TJLILMAN Well-Known Member
    Colorado Springs
    '08 Prerunner
    I'll take the leafs :D
    50 amocaT[QUOTED] likes this.
  10. May 13, 2019 at 1:27 PM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I snagged these from Mark, was going to run a tall/skinny tire on them and use them as summer beater wheels. Since, I've been told by the CFO that I'm not buying tires :pout:
    So, they're up for grabs for free. Good used condition, 6 lug (lugs nuts included), 16x8", four (4) caps included, no valve stems. Located in the Springs near I-25 and Fillmore.
    PM me.
    *claimed/pending*
    JKU3000 likes this.
  11. May 13, 2019 at 1:52 PM
    Camtron
    Camtron Active Member
    Cameron
    98 Shitbox
    OME suspension. 33s. Sliders. Bumpers. Skids.
    Anybody have any interest in some brand new <100 mile 31x10.50r15 pro comp mud terrains on factory Tacoma alloys. All 4 with center caps and a factory spare in good shape too 31x10.50
    Slashaar likes this.
  12. May 13, 2019 at 5:11 PM
    Kellan_s
    Kellan_s Well-Known Member
    Utah
    08 Access Cab
    Stuff.. and things
    Anybody have a reliable 4Runner for sale around 10k? Looking for the 3.4, 4.0, or V8. My gal needs a new vehicle and wants a 4Runner :D
    The_Black_Pearl likes this.
  13. May 13, 2019 at 5:20 PM
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    600 14”
  14. May 13, 2019 at 7:28 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
  15. May 13, 2019 at 7:31 PM
    spongejosh
    spongejosh Well-Known Member
    Colorado
    07 TuRD Off Road
    3" lift, 275/80/17, skids, sliders, scratches
    I've got the 2nd gen 6112s on my 2nd gen so it's not totally relevant but..... I have all steel skids front to back including gas tank and bolt on sliders. I have the stock 6112 springs at 5 passenger, 6 driver and 1/4" top plates on both sides and no swaybar. I don't feel like I need any more spring. I will go with 650 springs once I add a winch and bumper in order to get back the lift I will inevitably lose.
    EnBoo[QUOTED] likes this.
  16. May 13, 2019 at 7:42 PM
    spongejosh
    Colorado
    07 TuRD Off Road
    I had some but I just installed them 2 weekends ago :D
    Pro tip: press them 1/8" short of fully seated and check fitment. I pressed mine all the way in and ended up having to wrestle with a pry bar to get the inside washers in. Or you could just measure the brackets if you're fancy like that.
  17. May 13, 2019 at 7:58 PM
    EnBoo
    Nathan
    Denver, CO
    Thanks. If I don't find some, I'll just install with the stock 600# and see how I like it.
  18. May 13, 2019 at 8:06 PM
    mountainmonkey
    Colorado
    Never enough
    What did you use to press the bushings? I haven’t figured that out yet since I don’t have them in hand. It doesn’t look like something a ball joint press would do though due to the lack of surfaces to push against.
  19. May 13, 2019 at 8:53 PM
    spongejosh
    Colorado
    07 TuRD Off Road
    I have a harbor freight press I bought years ago to replace Subaru bushings. I rented a ball joint press kit from autozone just for the cups. The smaller bushing went in pretty easy but the larger one was a pain in the butt. None of the press pieces were the correct size so it took a while to get the larger one in. I'm still undecided if I even got any benefit from the bushings.
  20. May 14, 2019 at 11:51 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    RunsGuns and randyb87 like this.
