Colorado Trading Post
Discussion in 'Colorado' started by NYCO, Mar 30, 2011.
  1. Apr 14, 2020 at 5:52 AM
    RtacomaN
    RtacomaN Well-Known Member
    Taylor
    Colorado
    Especially if you “don’t need to sell so don’t lowball” haha
    JasonLee[QUOTED] likes this.
  2. Apr 14, 2020 at 9:04 AM
    hack4875
    hack4875 1 of 377
    Colorado Springs, CO
    2015 TRD PRO Supercharged
    PM sent.
  3. Apr 14, 2020 at 11:06 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Free 2nd gen Silver Streak Mica bumper with fog lights, bumper support bar, some brackets...pretty much everything that’s removed when installing an aftermarket bumper. It’s getting chopped up for trash tonight so if you want it let me know ASAP. In Colorado Springs.
    Also have the stock TRD OR skid/splash plates and hardware for free.
  4. Apr 14, 2020 at 11:21 AM
    TomTomBikes
    TomTomBikes Does Things "On Purpose"
    ColoRADo
    2015 MGM AC V6 4x4
    none
    Do you have the gas tank straps?
  5. Apr 14, 2020 at 11:21 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    No, just the front skids.
  6. Apr 14, 2020 at 3:41 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Antenna Mounts
    They're in Grand Junction, local is better but if they can get a ride happy to figure it out.
    Two Gamiviti fender mounts, one left and one right. They have Larsen NMO bases with RG-58 cable. The left/driver's side is terminated with a PL259 and the right/passenger lost its connector but the cable is longer. They are universal, should work on most trucks except FJ40/55.
    $50 for both
    Two CBI ditch light brackets for 2005-2015 Tacoma with NMO bases.
    I honestly don't remember what I did to mount them. NMO are usually 3/4" holes and for thin surfaces. So I must have used thick mount NMO but I don't remember if I drilled them to 3/4" or used 3/8". It would only matter if you wanted to use them for lights instead.
    These have RG-8/U coax and you get the corner windshield trim piece cut to fit for you even. Neither of them have connectors currently.
    $60 for both
  7. Apr 14, 2020 at 3:50 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    BPF tow hook. Could probably do with being painted or re-powdercoated.
    Also in Grand Junction
    $65
    The_Black_Pearl likes this.
  8. Apr 14, 2020 at 5:09 PM
    TomTomBikes
    ColoRADo
    2015 MGM AC V6 4x4
    none
    Sold
  9. Apr 14, 2020 at 6:46 PM
    Theetrentmeister
    Theetrentmeister Well-Known Member
    28,000 miles $33,500
    $33,300 without bed rack and winch
    Very Firm on those prices. Once i get lower than that I might as well start to part out the entire truck and sell it in stock configuration
    Accessories:
    Proline 4wd winch bumper
    Smittybilt XRC 12k synthetic winch
    OPT7 Led low beam bulbs
    Anytime backup and front camera
    Custom AUX Fuse panel
    CBI prototype aluminum skid plates
    Welded on rock sliders (Made by a local guy in Colorado springs)
    Aluminum bed bars for Roof top tent
    Front Durobumps bump stops
    Rear Timbren bump stops
    SS Kevlar reinforced braided front brake lines (stock +1")
    SS Kevlar reinforced braided rear brake lines (24")
    Spc Upper control arms
    TRD Pro 4runner Wheels x 5
    285/75/r17 Ko2 x 5
    Cab mount chop
    Suspension:
    ADS Front 2.5" coilovers with remote reservoir and compression adjusters.
    Front 700lbs coil overs (Front sway ha been removed as you do not need them with this set up)
    ADS 2.5" extended length rear shocks with remote reservoir and compression adjusters
    Old Man Emu Heavy Duty Leaf pack
    Old Man Emu Carrier bearing drop kit
    [/QUOTE]
    JKU3000 and thedave1164 like this.
  10. Apr 14, 2020 at 8:17 PM
    jimbo623
    jimbo623 Jimbo
    Pueblo
    11 TRD Off Road
    Grillcraft Grill, Hella Black Magics, ICON shocks w/ remote reservoir, Total Chaos UCAs, Tom Woods Drive Shaft, TSB springs, LED Dome light, Redline Hood struts, Slotted rotors, WheatherTech Mats, Ultra Gauge, and Illuminated 4x4 switch
    I have a set of gas tank straps.
  11. Apr 14, 2020 at 8:35 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
  12. Apr 14, 2020 at 9:16 PM
    Martyinco
    Martyinco Well-Known Member
  13. Apr 15, 2020 at 8:25 AM
    Wulf
    rock raisin
  14. Apr 15, 2020 at 9:15 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
  15. Apr 15, 2020 at 10:19 AM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    2005-2011 tacoma side view mirror glass, not sure if the pattern changed after 2011 or 2012, these COULD fit 2015 and under.
    anyone need OEM replacement mirror glass / sticky material?
    $35 bucks, im in south denver area
    Kolter45 and Wulf like this.
  16. Apr 15, 2020 at 2:37 PM
    XrunnerCO
    XrunnerCO Well-Known Member
    Colorado
    2016 Tacoma TRD OR - DCSB
    Wanted to buy - 3rd gen bolt on rock sliders for a DCSB Tacoma
    Preferably Northern Colorado/Denver area. Finish isn't important... I'm using them for a project (add entry steps) and will refinish them at the end.
  17. Apr 15, 2020 at 3:15 PM
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    Mobtown 3rd gen std clearance with single swing. Bumper is blasted and ready to go, swingarm is still rattle canned.
    SOLD
    30274D45-A7D5-4FD6-97FB-C39298F67170.jpg C7CF2F72-9E60-4549-8C36-7B635DBA243D.jpg 5C3AE86B-E626-4578-8B50-9EAB5550582B.jpg DF7D83FE-EF9F-4FDA-9F0F-3D120BA620D0.jpg
  18. Apr 15, 2020 at 3:32 PM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    :anonymous: "Eye ball's $1200 stimulus check"
  19. Apr 15, 2020 at 3:39 PM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    do it
    YamaDirtrider likes this.
  20. Apr 15, 2020 at 3:46 PM
    odomandr
    Andy
    Fort Collins, CO
    I heard you only had a 100 dollar stimulus.....
    Kolter45 likes this.
