Colorado Trip Reports
Discussion in 'Colorado' started by NativeTaco, Nov 24, 2012.
  1. Apr 18, 2017 at 11:27 AM
    #3101
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I know nothing is listed here for Metberry but this is a good resource for trail openings.
    http://www.bushducks.com/tripreps/passopen.htm#mettberry
    josh80[QUOTED] likes this.
  2. Apr 18, 2017 at 11:51 AM
    #3102
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Just went Saturday. Not sure if I know which "hill" you're referring to. Basically half the trail is a hill. Also couldn't tell you about fishing. I've never actually seen anybody in the river down there.
  3. Apr 18, 2017 at 2:41 PM
    #3103
    WillT
    WillT Well-Known Member
    Colorado
    '21 Colorado ZR2 Bison
    Maybe he meant coming back up the Rock slab with nobody up top to pull if he can't get traction.
    CO MTN Steve and josh80 like this.
  4. Apr 18, 2017 at 2:44 PM
    #3104
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Hmm well you may have to hit it right if you have open diffs, but locked I did fine even when I was stock.
    josh80 and 303tacoma like this.
  5. Apr 19, 2017 at 6:47 AM
    #3105
    josh80
    josh80 Well-Known Member
    Josh
    Colorado Springs
    2012 6-Speed
    3 Link Dana 44 SAS With TG Verso Dual Cases.
    Well I was just reading and people were talking about some steep tricky hill on the way out. But yeah thanks.
    :oldglory:
  6. Apr 19, 2017 at 6:52 AM
    #3106
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    there's a climb at the bottom that can be loose. it's a long climb, but usually not too bad as long as you're not running on slicks...snow and ice covered would be a different story, but you'll be fine now
    the slab is the other tricky section to get back up...if you stay right, you usually see the least amount of tire lift...going up and down, just keep an eye on your weight transfer of the truck. as you drop a tire, you don't want to be too sideways when the truck starts to lift.
  7. May 15, 2017 at 9:36 AM
    #3107
    SSSherwood
    SSSherwood Well-Known Member
    07 Blue dbl tacoma sport
    2.5 OME lift. 32in MT, Airflow Snorkel, 4xinnovations sliders
    Ran chinaman gulch on Saturday. With some friends. That trail is a beast for a tacoma on 32s and open diffs. Got the strap once cause I tried to play on the rock garden. Then attempted the v-notch and broke my passenger cv shaft. Made it out in 2wd
  8. May 15, 2017 at 9:41 AM
    #3108
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Yeah, I've heard that's a trail for 33's or bigger and armor
  9. May 15, 2017 at 9:47 AM
    #3109
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    If you're on 35s it means you don't need armor right? Supercharged means you don't need a winch too.
    303tacoma, Zizzle, Littles and 7 others like this.
  10. May 15, 2017 at 9:47 AM
    #3110
    SSSherwood
    Just picking the right lines and sliders I did fine until I got cocky.
    Tacoma SS[QUOTED] likes this.
  11. May 15, 2017 at 9:54 AM
    #3111
    SSSherwood
    Running wheeler lake next month
    NYCO likes this.
  12. May 15, 2017 at 9:58 AM
    #3112
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Ooh that's a fun one!
    CO MTN Steve likes this.
  13. May 15, 2017 at 10:00 AM
    #3113
    SSSherwood
    I thought I was having a bad day Saturday until I got a call from my bro. He came out without a scratch thankfully. Never combine speed and narrow gravel roads.
  14. May 15, 2017 at 10:01 AM
    #3114
    Tacoma SS
    Denver
    I already have all that stuff so I should be golden. And within about a week I will be up and running on 456 gears. Just have to wait until the break-in period is over :frusty:
    Nazupag524[QUOTED] likes this.
  15. May 15, 2017 at 10:01 AM
    #3115
    SSSherwood
    I can't wait and so much history
  16. May 15, 2017 at 10:02 AM
    #3116
    Tacoma SS
    Denver
    :eek:
  17. May 15, 2017 at 10:03 AM
    #3117
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    A supply of spare diffs might be needed
  18. May 15, 2017 at 10:08 AM
    #3118
    SSSherwood
    He just got the sliders from Adventure off road fabrication and he said they held up no damage to them or the bottom of doors and rocker panels. And he flipped 3 times.
  19. May 16, 2017 at 7:12 AM
    #3119
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Ahh, probably not
    Wheeler Lake Pike/South Park 719-836-2031 Mostly closed 5/13/17
    COMMENTS:
    5/13/17 - Trail is blocked by snow within 1/2mi of trailhead. Some drifts are quite deep; I'd estimate it'll be about a month before they are passable by vehicle. Continuous snow begins at treeline.
    Edit adding link to Bush Ducks
    http://bushducks.com/tripreps/passopen.htm
    alee891 likes this.
  20. May 16, 2017 at 7:27 AM
    #3120
    thefatkid
    Brian
    Colorado
    2004 thingy
    I used to be a part of a group of guys that would open that trail. About 2001-2005 was the year range. The snow up there was hard on the top from many freeze/thaw events so you could drive a light Jeep or Toyota across the large drifts. I remember on of the 1st years a Truck fell through and the driver had to climb out the back window. We were digging and winching for 2 days after to free the truck. I don't know if I could squeeze out the back window of a mini truck these days. Middle of June was always the 1st run and most of the trucks were running 40s. I liked the 38x12.50s but my mini truck was sub 3klbs with a 4 cylinder.
