Colorado Trip Reports
Discussion in 'Colorado' started by NativeTaco, Nov 24, 2012.
  1. Feb 9, 2019 at 9:22 PM
    #4081
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Your retired brother sells a vet and then you let him buy a Heep to learn about four wheeling?
    Just when you think you know somebody they turn around and then go and do something like this. It’s a shame.
    Make him air down.....
    JWaldz, CO MTN Steve, bot102 and 4 others like this.
  2. Feb 9, 2019 at 9:34 PM
    #4082
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    FYI - with my stock 2003 TRD with OME suspension and 31.8" tires, PA Gulch was kind of boring to me. I have some (not a lot) of experience driving fairly technical rocky bits in Death Valley/Nevada areas with no spotter.
    In a bigger truck (like a 2nd gen, haha) or not having experience off-road, it would be tougher/nail-biter. I went up when it was wet and a bit muddy and had no problems. I didn't even use my locker. Smooth throttle and 4 Low is more than enough to make it up that trail.
    I was up there today helping my buddy rescue his LMTV from a spur off Switzerland/Gold Hill road...
    https://www.instagram.com/p/BtrWyaAlr4o/
    Winkle99[QUOTED] likes this.
  3. Feb 9, 2019 at 9:40 PM
    #4083
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
    While I failed to convince him about the jeep thing, I did convice him not to air down today. He did notice the 3 Colorado 4x4 Rescue and Recovery Jeeps’ 37s were aired down however.:oops:
    johntoyota[QUOTED] likes this.
  4. Feb 9, 2019 at 9:44 PM
    #4084
    Winkle99
    David
    CO
    We were up there around 10:00 am. Would have been cool to see you.
  5. Feb 9, 2019 at 9:50 PM
    #4085
    JasonLee
    15 TRD OffRoad
    I was the asshole parked in the MIDDLE of the USFS road off Gold Hill road (here) since there was a 4' deep drift just past there that nobody would have made it through without a snowmobile or snowcat. We hiked the 1/4 mile up to the LMTV (here) and then did our work and drove out the other way. I did see a MGM 2nd gen parked with nobody in it right here: https://goo.gl/maps/kim729o2whP2
  6. Feb 9, 2019 at 10:00 PM
    #4086
    Winkle99
    David
    CO
    I did see your truck parked there.
    I recall passing by that 2nd gen.
    JasonLee[QUOTED] and johntoyota like this.
  7. Feb 9, 2019 at 10:04 PM
    #4087
    JasonLee
    15 TRD OffRoad
    I should have shown up since it looks like it was mostly a 3rd gen party.
  8. Feb 9, 2019 at 10:32 PM
    #4088
    johntoyota
    Down yonder in TN
    16 truck
    2 third gens and 2 second gens.
  9. Feb 10, 2019 at 12:25 PM
    #4089
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Sounds like an ABS sensor fault, maybe due to the snow bashing. My 12' Tundra would do this once in a while in deeper snow. Probably nothing to worry about.
    Stig[QUOTED] likes this.
  10. Feb 10, 2019 at 1:48 PM
    #4090
    JasonLee
    15 TRD OffRoad
    ABS Sensors are Hall effect sensors - they measure magnetic field, which permeates snow and water. The sensor is pretty well sealed into the knuckle, so the other place to inspect is where the wires go to the nearest plug that connects into the rest of the vehicle harness to see if the snow pulled at it and caused a loose or fully disconnected plug. It is also possible that the wire got snagged on something or pushed to hard by packed up snow and is frayed or broken internally.
    ColoradoTJ likes this.
  11. Feb 10, 2019 at 3:51 PM
    #4091
    johntoyota
    Down yonder in TN
    16 truck
    And everybody else on the trail. :D
  12. Feb 10, 2019 at 4:17 PM
    #4092
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    It was fine after i restarted it and hasn't happened since. Haven't tried to send it into any such snowbanks since though.
    ColoradoTJ[QUOTED] likes this.
  13. Feb 10, 2019 at 4:19 PM
    #4093
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Older Toyota sensor like your Tacoma uses are reluctance sensors, not really Hall Effect. https://en.wikipedia.org/wiki/Variable_reluctance_sensor
    His Tundra uses the recently adopted MRE Sensor that can more accurately measure wheel direction and lower speed. https://www.searchautoparts.com/aut...ning/understanding-magneto-resistance-element
    Now why mention that? Fault detection has become so good to the point of detecting non faults. Wheel speeds while stuck or being recovered can vary from the programmed expected and set false codes. Mainly these codes will set in high range because the parameters are tighter knowing more wheel slip conditions will occur in low range operations.
  14. Feb 10, 2019 at 4:19 PM
    #4094
    ColoradoTJ
    Colorado
    For research purposes only, that sounds like you should go do some testing with friends....
    Just a suggestion.
    Stig[QUOTED] and WarFab Armor like this.
  15. Feb 10, 2019 at 5:48 PM
    #4095
    ColoradoTJ
    Colorado
    Yep. I was the only one that day that made that obstacle. The exit made me run out of talent.
    WarFab Armor[QUOTED] likes this.
  16. Feb 10, 2019 at 6:37 PM
    #4096
    ColoradoTJ
    Colorado
    In Colorado?
  17. Feb 10, 2019 at 6:59 PM
    #4097
    ColoradoTJ
    Colorado
    Make sure you take him to 10 Falls in Gypsum. Lol. Good luck.
    Boggers on rocks. LMFAO.
    CO MTN Steve and johntoyota like this.
  18. Feb 10, 2019 at 7:15 PM
    #4098
    ColoradoTJ
    Colorado
    Holy mother of god. 6700 lbs? That’s 1000 lbs less than my one ton diesel. My fat ass TJ is 4900, and going on a diet.
    If you would sir, let me know when this is taking place. I will be doing anything else other than being on that trail he’s on.
  19. Feb 10, 2019 at 7:30 PM
    #4099
    JasonLee
    15 TRD OffRoad
    I guess I learned something else new today.
    "The speed sensor detects wheel speed and sends the appropriate signals to the ECU. These signals are used for control of the ABS control system. The front and rear rotors each have 48 serrations. When the rotors rotate, the magnetic field emitted by the permanent magnet in the speed sensor generates an AC voltage. Since the frequency of this AC voltage changes in direct proportion to the speed of the rotor, the frequency is used by the ECU to detect the speed of each wheel."
    ColoradoTJ and thefatkid[QUOTED] like this.
  20. Feb 11, 2019 at 6:01 AM
    #4100
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Damnit I did not get a single video of you guys doing that last hill climb.
    Great to see you guys and meet some of you for the first time.
