Colored Map Lights
Discussion in 'Lighting' started by dj08med, Jan 2, 2010.
Who would win in a fight between Batman and Halo's Master Cheif?
Poll closed Feb 1, 2010.
  1. Batman
    3 vote(s)
    11.5%
  2. Master Cheif
    23 vote(s)
    88.5%
  1. Jan 2, 2010 at 12:23 AM
    dj08med
    dj08med [OP] New Member
    FT Bragg
    4x4 blue
    When im driving, and I have to use the touch driver/passenger map lights, it always takes me a little while for my eyes to adjust from the white light back to driving in the dark. Dose anyone have any ideas about changing the color of the lights to a red or blacklight color like the militay has in the aircraft, so the change is not such a shock to the eyes?
  2. Jan 2, 2010 at 12:45 AM
    erik_found
    erik_found Legendary
    Erik
    Flagstaff, AZ
    99 reg cab
    Red would probably be the easiest on your eyes.
  3. Jan 2, 2010 at 3:20 AM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    i have white lights in mine, and with my young 20/20 vision eyes im fine.
  4. Jan 2, 2010 at 7:16 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    For you, prob red or amber like the gauges.
  5. Jan 2, 2010 at 8:57 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Red is easiest on the eyes in low light situations. However, maps and other colored text can appear 'washed out' under red light (even to the point of some things being near invisible on the page).
    I'd suggest an orange or amber to be easy on the eyes and still have visual discrimination across the color spectrum.
    A soft green is also easy on the eyes in low-light environments, but it's hard for reading.
  6. Jan 2, 2010 at 9:04 AM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    some bmws do amber-red. so they must be on to something.
  7. Jan 2, 2010 at 9:35 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    in my truck theyre the normal white light...however in my patrol car i have a semi-blue mixed with white that essentially looks like a soft green
  8. Jan 2, 2010 at 9:55 AM
    Drakken
    Drakken Well-Known Member
    Tennessee
    Silver Streak Mica 2006 AC 4X4
    Easy solution is to have one red and the other leave white. Or simply turn the map lights red and leave the overhead white. That way you have the best of both worlds and can choose. Just my .02.
  9. Jan 2, 2010 at 10:13 AM
    ianham
    ianham Active Member
  10. Jan 2, 2010 at 5:08 PM
    cmfranks
    cmfranks Well-Known Member
    Craig
    Austin,TX
    08 DC Pre-Runner 6in Pro Comp Lift
    BHLM, Pro Comp Skid Plate, AFE Drop in Air Filter, Tint, Pioneer AVH 4000 DVD,Polk Audio 6.5 components, Polk 6.5 co-ax's, Polk Audio 400.1 amp, Polk Audio 500.1 amp, (2) Polk Audio 10 in Momo subs, Mr Marv sub box, Sockmonkey decals, Redline Elite hood struts, Bak Flip tonneau cover, N-Fab Nerf bars, Painted Center Console & Window/Door Lock Panels Black, Amber LED Dome/Map Lights
    i ordered amber ones from superbrightleds.com. they look awsome with the rest of the interior amber lights. they are alittle more dimmer than the white lights.
    cost maybe $7.00
  11. Jan 4, 2010 at 8:22 PM
    puddlejumper
    puddlejumper Well-Known Member
    Jeff
    South Texas
    08 Tacoma Rugged Trail Edition
    Homemade Rear Hi-Clear. Rear Bumper, ARB Front w/Fog Light Option. Superwinch EPi9.0s with Amsteel Blue. Going to make sliders, skids and bed cage/box, I have a camper shell for long range travel. Vision X Tantrum Lights for being a "pimp in the bush", Cobra CB, lots of tools and random junk that helps to add traction due to weight.
    I put a red bulb in the driver's side map light and left the pass. side white/clear. I did a lot of night driving in my last job and the red light did make it easier to see things in the cab without blinding me. Probably one of my most useful-and easiest modifications I have done.
  12. Jan 5, 2010 at 8:04 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Go with red... here is the reason why (based on what I understand of night vision):
    First, one should understand that every object, when hit by light, absorbs a range of the visible light spectrum (Red, Orange, Yellow, Green, Blue, Indigo, Violet). Every object also reflects a range of that spectrum, which when received by the eye, is what gives an object color. And lastly, white light is made up of all of the colors in the visible spectrum.
    The eye: The retina of the eye contains two types of receptors - cones and rods.
    The rods (which are more sensitive to light) outnumber the cones (which are less sensitive to light).
    To see, both cones and rods "fire" electrical impulses which must reset to fire again... thus enabling vision (day or night). The cones reset this firing sequence of electrical impulses much faster than rods reset... Light adaption is thought to occur by adjusting this reset time.
    Cones are used mostly for daylight vision and the rods for night vision... and the reset times explains why it takes so long for your eyes to adjust to normal night vision after being exposed to light. The golden rule is that it takes 30 minutes for your eyes (the rods) to adjust (reset the firing sequence) to normal night vision.
    Something else that is important... If you look at the visible light spectrum - red is on one side and blue is pretty much on the other with indigo and violet. When a rod receives the light reflected off an object, the closer that reflected light is to the red side, the less it responds (or the less of a chance it will need to reset the firing of electrical impulses).
    Therefore, if you were to be flashed in the eyes with a flashlight at night... your eyes would need to reset before you could see again at night. That reset would take a certain amount of time, because it heavily impacted the sensitivity of the rods.
    Red light does not cause the rods to react as much... therefore the reset time for the electrical impulses is greatly reduced.
    Green is another choice for color at night - and there is a debate over which is better. IMO, red is better because green is made up of yellow and blue wavelengths and further from red in the visible spectrum.
    Hope that helps you some...
    P.S. If you have topographic maps, some will say "red light readable" which means that you can see the map using a red light. (I was a Cartographer/Surveyor/Geospatial analyst for 6 years).
  13. Jan 5, 2010 at 11:16 AM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I've got all the interior lights on my other car replaced with red LEDs. It's great for not killing night vision, but it can be tricky to read some things under the red light (not sure if there's a low output intensity or if the wedge LEDs just don't line up with the reflectors in the mounting)
    With the covers on the taco map lights a red LED should work better though and there shouldn't be any real alignment/reflector issues. I like the idea of swapping the driver's side for red and leaving the passenger and overheads white/stock, or you can pick up a cheap little 5-9 LED flashlight at most auto parts stores that'll fit in any of the little compartments around the dash/overhead console (I got one at Kragen that uses 3 AAA's for $2.99).
    Do the taco map lights just use standard 194 bulbs?
  14. Jan 6, 2010 at 10:15 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Well Said! On submarines, in the 70s and 80s, the control room would be rigged for "RED" (filters on light fixtures) between sunset and sunrise.....and then lights off before coming to periscope depth. In the 90s, the same procedure applied, but the filters were changed to blue.
  15. Jan 6, 2010 at 10:21 AM
    Agent475
    Waldorf, MD
    2006 Red TRD Sport
    That's crazy!! I've been to Iraq, but I don't think I'd ever serve on a submarine.
