Combination Oil/Transmission Cooler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by damnfingers, Feb 24, 2013.
  1. Feb 24, 2013 at 8:09 AM
    damnfingers
    damnfingers [OP] Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    I'm going to be towing a car/trailer combination that's going to put me just a little over the 3500lb weight limit (3850) so I want to add an oil cooler and a transmission cooler to be safe. Etrailer.com recommended I buy the "Derale Transmission Coolers,Engine Cooler - D15902". I looked this up online and the only mention I can find of it is in...tah dah...etrailer.com ;).
    Has anyone here used this on their Tacoma (or other trucks for that matter), if so do you recommend it and if not, what other combination would you recommend.
    Thanks in advance for your thoughts/advice.
    By the way I have a dealer installed hitch and I've had an electric brake controller installed.
    The trailer I'm going to be pulling is an 18' version of this (with an MGTC, not a Lotus, inside):
  2. Feb 24, 2013 at 8:29 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Do you really have a Lotus in there? I use to have a "Europa" back in the day.
  3. Feb 24, 2013 at 2:22 PM
    damnfingers
    Gene
    Mississippi
    No, read the last sentence: "The trailer I'm going to be pulling is an 18' version of this (with an MGTC, not a Lotus, inside)". However, there is a Lotus in *that* trailer.
    Here's what's going to be in mine:
  4. Feb 24, 2013 at 2:28 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    so your truck didn't come with the tow package? If did, I thought it came with a trans cooler with the package?
  5. Feb 25, 2013 at 6:25 AM
    damnfingers
    Gene
    Mississippi
    No, no tow package. I saw the drop hitch and incorrectly *assumed* it had the tow package which I needed...in fact I traded in a 2011 access cab with a tow package for the double cab.
  6. Feb 25, 2013 at 4:18 PM
    luka
    Kailua, HI
  7. Feb 26, 2013 at 7:23 AM
    damnfingers
    Gene
    Mississippi
    Yep, might do it. Will I need an oil cooler too...or will the transmission cooler suffice?
  8. Feb 26, 2013 at 7:56 AM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    I don't think the TRD's come with an oil cooler so I imagine you would be fine without one. The TRD V6's are rated to tow 6500lbs and I'm pretty sure all we have over you is the receiver hitch (which you added) and the tranny cooler (which you are adding).
  9. Feb 26, 2013 at 2:52 PM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    You also get an oil cooler, 130 amp alternator and a 27F battery with the tow package. The TRD packages just include the tow package features.
    Honestly, not sure how important the oil cooler is as the transmission is the one that suffers the most when towing. The battery isn't all that important either unless you have flood lights on your trailer or something.
  10. Feb 26, 2013 at 3:10 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Oh yep... Forgot about the alternator. haha. Didn't know about the others though.
