Combine Bilstein 5100s with small spacer for softer ride at 2.5in of lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SouthernWild, Oct 5, 2021.
  1. Apr 6, 2023 at 3:23 PM
    Tacomabro7
    Tacomabro7 Active Member
    2016 Red Tacoma TRD Off-Road 4x4 Automatic
    Hi-line front bumper 305/60R18 tires
    So after all my research, it goes like this, right?
    for Bilstein 5100s:
    lower notch (less lift) = more down travel and less up travel availability in the shock
    higher notch (more lift) = more up travel and less down travel availability in the shock
    Problem with spacers: if you don’t have enough up travel, you risk fully collapsing the shock before hitting the bump stops, which can severely damage the shock.
    therefore, if you use spacers with the Bilstein 5100s, you need more up travel to ensure you hit bump stops before collapsing the shock. Therefore, it is better to use spacers with a higher notch setting because it gives more up travel.
    but what gets me is that in the Bilstein 5100 instructions, it says if you are on the highest setting (the most lift) you use washers to shim up the bump stop implying that you’ll bottom out the shock before hitting the bumpstop. What??
    johnnytwotimes likes this.
  2. Apr 6, 2023 at 3:51 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The 5100 is longer than stock for more droop. getting at or near the max angle of certian things (CV joints, tie rod ends, ball joints). Putting much more than a 1/4in lean spacer in will make the truck try to droop out past the limitations of the mentioned. You will also bottom out the shock before hitting the bumpstop.
    Like i mentioned, do not stack a 3in lift spacer and a 5100 front shock.
    Clip setting does not change the position of the shock relative to the suspension components. It simply changes the preload of the spring to raise or lower the truck within the travel of the shock.
    Tacomabro7[QUOTED] likes this.
  3. Apr 6, 2023 at 4:05 PM
    Tacomabro7
    would you agree with my previous post sort of trying to summarize everything?
  4. Apr 6, 2023 at 8:31 PM
    nd4spdbh
    SoCal
    Partly yes partly no as mentioned above.
  5. Apr 6, 2023 at 8:35 PM
    Tacomabro7
    If I put the Bilstein shocks to the highest setting, that gives me a lot more upward travel availability in the shock. If I couple that with say a 1” spacer lift (0.5” thickness), since I have that extra up travel, I’ll hit the bump stop before fully collapsing the shock correct? I should be good to do that right?
