Combining STS turbo kit and TRD S/C kit
Discussion in 'Performance and Tuning' started by 308Cowboy, Nov 19, 2014.
  1. Nov 19, 2014 at 4:07 PM
    308Cowboy
    308Cowboy [OP] New Member
    06 Stock SR5 V6 6-Speed
    So I have a predicament. While driving my Tacoma, I have decided I want some boost. But of course this begs the question of what kind of boost. I already turbo'd the KA-24 in my 240SX, so I was thinking of doing S/C just to get the experience, but turbos are so fun. But S/C's make more useful power, or at least you have to think less while driving them to get useful power. But a turbo can haul more at highway speeds, and as this truck is my primary method of moving everything I own, that matters. Dyno charts from both show a far better looking curve from a S/C below 3k, but a turbo's gains are substantial over that. And there are numerous arguments between them. Two kits I've found seem relatively plug and play, as far as boosting a stock NA engine goes, so difficulty for either is a wash. Efficiency is very similar between them. So ultimately it's which power curve looks better.
    Which leads to using both power curves. Basically using the S/C to maintain boost up until about 2750 RPM. Once I hit that, both of them make about the same power, because both can maintain the boost level at 6 psi. Then the turbo takes over once the S/C starts to choke out at 4600 RPM. The S/C's drag at that point goes away more or less, because the pressure change across the compressor goes to near zero, so it's just free spinning with air blowing past it. On the other side this makes the turbo a slight choke at low RPM, so while your boost will be full, you'll have a slight drop in power at the wheels. I feel like there's a way to get around that by cleverly repurposing a wastegate to act as a bypass for the drive turbine. I'll get to that later.
    The whole concept of the project is to take two kits that are relatively independent and easy to install, and merge them together with minimal extra tinkering. I've boosted a car before that wasn't made to be boosted, so I understand the relativity of "minimal extra tinkering" when twin charging a motor. However, since the turbo is remote mounted, and the supercharger sits right on the engine, the two don't get in the way of each other. The S/C takes air from the same spot the turbo drops it off, so the two should merge together nicely.The only thing that really seems problematic is if the fuel system can handle it, though leaving it at 5 psi seems to be working for people on both S/C's and turbos, and since max boost isn't changing, I don't expect air flow to change much, and thus not much change in the fuel requirements, just a more flattened out torque curve.
    However, one thing to consider. I haven't seen many people running intercoolers on their turbo'd trucks, I've seen zero engine bays with water-air intercoolers on their S/C's. This is probably because of the low boost and the lack of need, but if you run air through two compressors instead of just one, you'll get an extra heat load that you need to account for. There's still enough space in the front to be able to put an intercooler, which is where the people that use them have mounted them. But this turbo kit has it's pipe to the throttle body on the passenger side. This is the same side as the S/C's intake, which means that I'd have to run the air back to the driver's side to feed into the IC. It'd be nice if instead the pipe up to the front just ran on the driver's side, but this may not be viable. I'm not sure on the clearance or spacing available to run pipes. I don't think it'll be as easy as rotating the compressor housing, but if it is that would be great. If someone's got this turbo kit installed and could eye up the clearances that would be great.
    Also being considered as a solution to this conundrum is just running another pipe directly on top of the IC to get air back to the other side, or even using a second IC mounted behind the radiator with air flowing in the opposite direction, though I don't think there's clearance for that and mounting it would be a pain.
  2. Nov 19, 2014 at 4:12 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    :popcorn:Welcome to TW. Sounds interesting.
  3. Nov 21, 2014 at 8:41 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Well that's a hell of a first post... Someone actually did this years ago; installed a TRD blower and APR back mount turbo. Not sure how that combo ended up. Think he finally folded after so much money was invested.:rolleyes:
  4. Nov 21, 2014 at 11:52 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI TRD blower has water to air innercooler.
  5. Nov 21, 2014 at 12:12 PM
    1SportyTaco
    1SportyTaco New Member
    Neil
    North Jersey
    '14 Tacoma Sport DCSB
    Correct me if I'm wrong but doesn't the sts turbo kit essentially put a turbo where the muffler was? With that being said the mufflers on the Tacoma are on the passenger side of the truck/drivetrain so my guess is that's why the kit sends the air back up that side of the truck. I would think moving the sts Kit the the other side of the truck would be a project in itself let along adding a TRD supercharger to the mix. In any event good luck and welcome to the boards!
  6. Nov 21, 2014 at 3:39 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    ur looking at 900RPM of turbo time in that case :confused:
  7. Nov 21, 2014 at 3:56 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    google "m90 compound boost"
  8. Nov 21, 2014 at 4:08 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Your theory is flawed, particularly the bolded part. The S/C will compound the turbo's boost (and compound the heat as well). Your mid range power will be impressive but as RPM's raise. the boost will be limited by the S/C.
    Ultimately for this to work like you want it to, you need to do a few things:
    1st, get an oil-less turbo because the STS's oil scavenging design sucks.
    2nd, you will need to install a bypass for the S/C for the higher RPM's.
    If you want the best of both worlds, the URD S/C kit the kit you want.
  9. Nov 21, 2014 at 4:36 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    IIRC u cant even check ur oil with it.............renders dipstick useless I think
  10. Nov 21, 2014 at 4:48 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  11. Nov 21, 2014 at 5:10 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    The replacement for displacement is forced induction, but as the cubes go down, the cost goes up!
    Twin Charged 4.7l Tundra by Lextreme
    03 4.7l non-VVTi
    8.5:1 Comp
    4 bolt main conversion
    STS Turbo System
    TRD Supercharged System
    Direct Port 200hp Nitrous system.
    DG92071 likes this.
  12. Nov 21, 2014 at 5:24 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  13. Nov 21, 2014 at 5:24 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    :notsure:
    Bad ass :thumbsup:
  14. Nov 21, 2014 at 5:32 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  15. Nov 21, 2014 at 5:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I believe that most of the things your referring to, OP, as far as no intercoolers, is primarily on the 1st Gen Tacomas.
    I know of a guy who has a turbo kit for sale right now. Beautifully built by my old friend from PowerFab.
    I also have pictures of the twin charged XR, on my laptop. Uses a water to air intercooler for the turbo. They were making 16-18 psi, on the gauge, at around 3k rpms....Don't quote that though, it has been a long time since I have seen the video. Depending on which size turbo, and specs of turbo, it could very well flow much more per psi than the s/c. You know this. My BW EFR turbo breaks the boost threshold in the low 2k rpm range. No S/c necessary. Your idea though, go with it.
    Rock lobster, get a V8 and do a damn swap already, man. Seriously.
  16. Nov 21, 2014 at 6:13 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
  17. Nov 21, 2014 at 6:19 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Sure thing.
  18. Nov 22, 2014 at 4:43 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  19. Nov 22, 2014 at 8:53 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  20. Nov 22, 2014 at 10:27 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Nice to know. Let us know the results :thumbsup:
