Committed to 17's- what are my 33 options?
Discussion in 'Wheels & Tires' started by Col4bin, Dec 19, 2019.
  1. Dec 19, 2019 at 1:57 PM
    Col4bin
    Col4bin [OP] Well-Known Member
    Maine
    2018 TRD OR Double Cab
    I have seen so many "you can fit 33' on a stock suspension with no lift" posts but they are all referencing 16" wheels. I picked up 17" SEMA wheels- now trying to find the equivalent of "what will fit on stock suspension with no rubbing" kinda thing.
    going with KO2's...fwiw.
    Thanks
  2. Dec 19, 2019 at 2:00 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    285/70/17 will be your “33” size option for a 17” rim.
    El Taco Diablo likes this.
  3. Dec 19, 2019 at 2:02 PM
    tcjacado
    tcjacado Well-Known Member
    255/80/17 will work also
    Funzy, Rexfordian13, sdsurfer and 3 others like this.
  4. Dec 19, 2019 at 2:02 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id expect some rubbing on stock suspension with 285s. Its not the height that gets you, but the width. A 255/80/17 would be a good option that probably wouldnt rub
  5. Dec 19, 2019 at 2:05 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yes I forgot about pizza cutters. The other 33” size is 255/80/17
    BassAckwards and Col4bin[OP] like this.
  6. Dec 19, 2019 at 2:07 PM
    Col4bin
    Maine
    hugely thankful... now what about load rating if I have a choice? not doing any heavy hauling.
    BassAckwards likes this.
  7. Dec 19, 2019 at 2:07 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    People are reporting no rubbing with 275/70-17’s. Not quite a 33 :notsure:
    Col4bin[OP] likes this.
  8. Dec 19, 2019 at 2:09 PM
    BassAckwards
    If you can find a 33" in a standard load (p-rated) then id go with that. There is no need for e-rated unless you are offroading a lot and want to air down. Heavy tires are the biggest performance killer you can do to these trucks, so try to find the lightest one possible imo
  9. Dec 19, 2019 at 2:10 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    You will be constrained to what load ratings are available in the KO2s in the size you want. I'm pretty sure anything in a 33" tire will be load rate "E"
    Col4bin[QUOTED][OP] likes this.
  10. Dec 19, 2019 at 2:14 PM
    BassAckwards
    Falken makes the wildpeak at3w in a 285/70/17 standard load that weights 50.5lbs per tire.
    For reference my 295/70/17 (33.23") Cooper ST maxx E-load weigh 66lbs per corner
    MattCowsmasher and Col4bin[OP] like this.
  11. Dec 19, 2019 at 2:32 PM
    Col4bin
    Maine
    Thanks for that. The KO2 doesnt come in the 255/80/17 unfortunately so your suggestion may be the next best thing if I want to stick with a skinny close to 33" huh?
  12. Dec 19, 2019 at 2:40 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    I had 275/70/17 KO2s for a year or so and loved them. The only reason I got rid of them was to go with the 255/80/17 Cooper ST Maxx. I love them, as well. You won't go wrong with either choice but it sounds like you're committed to the KO2s. You may have a bit of rub with the 275/70/17s but getting your alignment right (need caster to be around 3.0+) and a little bit of trimming should resolve any issues.
  13. Dec 19, 2019 at 2:45 PM
    Col4bin
    Maine
    I appreciate hearing that- annnnd you taught me something I didnt know and that was I need an alignment after this! gah. BUT I guess I understand that.
    I am committed to KO2's only because I have had really good luck with there in Maine environments. pavement, snow etc always been a solid tire for me even though they are pretty spendy. Im sure some of the other manufacturers are just as good or better ya know. I guess I just figured Id stick with whats worked for me kinda thing.
    Very much appreciate the input!
    DavesTaco68 likes this.
  14. Dec 19, 2019 at 2:47 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    They have a C load 51.3 lbs
  15. Dec 19, 2019 at 2:58 PM
    Col4bin
    Maine
    the 275/70's? bfg is only showing e rating
    sdsurfer likes this.
  16. Dec 19, 2019 at 3:08 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    That weight 51.3 lbs is for the 285 70 17 C load KO2
    Says it’s diameter is 32.8 inches on BFs website.
  17. Dec 19, 2019 at 3:33 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Always like to help when possible... BTW... You really only need a new alignment after a lift or other suspension changes. That said, if you increase caster in your alignment settings it will provide more clearance from the cab mount for your wider and taller tires, which is the usual area that you will have rubbing. Good luck with your new tires once you pull the trigger.
  18. Dec 19, 2019 at 9:02 PM
    JCWages
    JCWages Well-Known Member
    Grass Valley, CA
    2018 GMC Canyon SLE 4x4
    King 2.5 coilovers, 33s, steel bumpers and stuff.
    There is also the Kenda Klever R/T 33x10.5x17 which is just shy of 33".
  19. Dec 20, 2019 at 6:28 AM
    Col4bin
    Maine
    im just wondering now if I should stick with 16's...seems like better options...ugh LOL
  20. Dec 21, 2019 at 11:22 AM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    Most of the 16" 33's I've seen are E rated
