Common places coolant will come from
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenMara, Dec 23, 2024.
  1. Dec 23, 2024 at 3:11 PM
    BenMara
    BenMara [OP] That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    So I've been chasing a coolant smell for 3 weeks. There are no indications on the driveway or in the cab. I looked on the engine, the radiator, the water pump, and heater core connection. No indications. No indications it coming from over fill tank either. Im stumped.
  2. Dec 23, 2024 at 3:35 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    are you actually losing coolant? or just smell it?
  3. Dec 23, 2024 at 3:38 PM
    Bishop84
    Bishop84 Well-Known Member
    Cylinder head gaskets will make this smell, also seeping hoses, so you gotta check for crusty pink.
    Flori-duh Taco and MSgt O like this.
  4. Dec 23, 2024 at 3:46 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    smell
  5. Dec 23, 2024 at 3:51 PM
    MSgt O
    2013 Tacoma
    like Bishop said, look for crusty pink around hoses and heads if you can smell it, its hot
  6. Dec 23, 2024 at 3:53 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Cylinder head crossover pipe?
  7. Dec 23, 2024 at 4:00 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    The dummy temp gauge is in the normal position, in the middle.
  8. Dec 23, 2024 at 4:02 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Coolant overflow is open to atmosphere.
    TheWildMan likes this.
  9. Dec 23, 2024 at 9:12 PM
    Waasheem
    Waasheem
    2007 xrunner
    You should do a pressure test with a coolant system pressure tester. If you don’t own one, or know someone with one, you should be able to rent one from a chain auto parts store.
    Use common sense and don’t open the radiator cap hot. Make sure the radiator is full to the top. Don’t over pressurize, 15 psi is enough. Using an inspection mirror and flashlight is helpful.
    BenMara[OP] likes this.
  10. Dec 23, 2024 at 9:18 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Check your water pump weep hole, if there is one?
    This is a different application but had something like this on my old T-100. It was a failing seal between the aluminum body of the radiator and where the plastic tanks were clamped onto the sides. It was just weeping a little and would leave a drop on the ground when it was really cold.
    You might have to pull the fan shroud and skid plate. Roll around under it with a good flashlight. I find it's better to do this in a darker garage so the light does you more good.
  11. Dec 24, 2024 at 1:40 AM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    I havent noticed any coolant level change. Will look into pressure testing the system.
  12. Dec 28, 2024 at 9:28 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    keep us posted on what you find. I am having a similar problem on another vehicle
  13. Dec 28, 2024 at 10:52 AM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Check overflow hose. I needed to add a clamp to mine to stop a small leak. Really easy.
  14. Dec 28, 2024 at 1:00 PM
    TacoTuesday1
    FL
    What kind of pressure tests have you done
    Flori-duh Taco likes this.
  15. Dec 28, 2024 at 5:14 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    No updates as of yet. I am enjoying driving my Evo X while on holiday vacation. I will get back on the search when I return.
  16. Dec 29, 2024 at 6:28 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I was seeing very small changes in the coolant level in the overflow tank. I decided to replace the original 14 year old radiator cap, after which the level in the overflow tank has been steady.
    Flori-duh Taco and BenMara[OP] like this.
