Common Points for Vacuum Leak 2007 Tacoma V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zdosse935, Mar 8, 2024.
  1. Mar 8, 2024 at 7:06 AM
    Zdosse935
    Zdosse935 [OP] Well-Known Member
    Would someone show me common points where I can spray brake cleaner to detect vacuum leak please? If you have pictures that will be better, thank you. It’s 2007 Tacoma V6
  2. Mar 8, 2024 at 7:15 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There's not really many places it can leak, just a few hoses and the upper intake gaskets.
    Why do you suspect a vacuum leak?
  3. Mar 8, 2024 at 7:24 AM
    Zdosse935
    I notice that when park in the parking lot and my engine idling around 600~ RPM. While idling, I usually feel vibration when sitting in driver seat and this happens constantly which irritate me.
    What I’ve done so far to diagnose the problem:
    - Changed spark plugs
    - Cleaned throttle body, but problem still persist so I replaced it with an OEM.
    So as of right now, the problem still persist.
  4. Mar 8, 2024 at 8:13 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    2.7L or 4.0L engine?
    If it's the 2.7 those vibrate a bit more at idle than the 4.0.
    If you have a scan tool look at fuel trims, if they are +/-10% at idle you most likely don't have a vacuum leak.
  5. Mar 8, 2024 at 1:24 PM
    Zdosse935
    It’s 4.0L V6, I have the BlueDriver scan tool, will absolutely try that.
