Common problems?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shuffstatler, Nov 2, 2018.
  1. Nov 2, 2018 at 10:44 AM
    shuffstatler
    shuffstatler [OP] New Member
    Curt
    2019 Tacoma SR 4x4
    265/75/16 kpatos M/T tires
    So I recently purchased a brand new 2019 Tacoma SR access cab 4 cylinder. 3 days after buying it, I had to take it back to the dealership and I’m curious if its common for others to have these problems.
    1. There doors have to be slammed in order to close completely.
    2. There’s a major rattling noise coming from the back passenger side of the cab when hitting a bump or stopping.
    3. The cover behind the steering wheel is loose.
    4. While my new truck is being worked on, the dealership put me in a used double cab 4 cylinder from 2017 I believe and I’ve noticed a huge power difference in it and my new truck.
    Anyone have/had the same issues or any thoughts?
  2. Nov 2, 2018 at 10:49 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I would think if the dealer let u have the truck for 3 days (free) they must be trying to sell it bad for some reason ive never had a car dealer allow me to take a vehicle home until I purchased it.
    BSFord and tcjacado like this.
  3. Nov 2, 2018 at 10:53 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    It’s called an extended test drive. I’ve had a few dealers from different brands offer me an extended test drive
    shakerhood likes this.
  4. Nov 2, 2018 at 10:54 AM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    He brought it back to the dealer after 3 days for the issues he explained.
    2016Tacoman and shuffstatler[OP] like this.
  5. Nov 2, 2018 at 10:59 AM
    BillsSR5
    bill
    2014 SR5
    not in the area I live, they would never see the truck back again
  6. Nov 2, 2018 at 11:00 AM
    shuffstatler
    Curt
    2019 Tacoma SR 4x4
    I’ll edit the language in the initial post so my message will come across a little more clearly.
  7. Nov 2, 2018 at 11:02 AM
    jamestown
    jamestown Well-Known Member
    NB, Canada
    2017 DCLB TRD Sport 4x4 AT Silver Sky M
    Off road wheels Factory HT tri fold tonneau
    Took my 2017 home for the weekend prior to my purchase.
    When you say power difference...do you mean the 2017 had more power than the 2019, or vice versa?
    The back doors on my crew cab do require a bit more umph to close all the way. Especially when all the windows are up. I thought they would loosen up over time. To this point they remain the same. They don't get used much either.
    As for the rattles....you learn to live with a few of them.
  8. Nov 2, 2018 at 11:04 AM
    shuffstatler
    Curt
    2019 Tacoma SR 4x4
    Yes, the 2017 feels like it has more power than my 2019 and the 2017 I’m in is a double cab while mine is an access cab.
    Also the 2017’s doors close with ease without having to slam them. I noticed the doors on the 2019 TRD also close easily when I test drove it.
  9. Nov 2, 2018 at 11:38 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You can get overnight and extended test drives if you are a serious buyer, Dealer let me choose a 3rd Gen Off the lot and take it for 3 days
  10. Nov 2, 2018 at 11:40 AM
    shakerhood
    Southern Ohio
    My last access cab doors banged over bumps, it was the latch and striker that needed adjustment
  11. Nov 2, 2018 at 11:42 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    1. Nope.
    2. Nyet.
    3. Nein.
  12. Nov 2, 2018 at 12:54 PM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    1. Tacomas are tight...there are extra seals between door and body panels, like old VW bugs. Compare that to competition.
    2. Rattling may be the jack in the compartment below the right rear passenger seat.
    3. Cover is warrantee.
  13. Nov 2, 2018 at 1:03 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Did they do the ECU fix on your 2019? To help with the shifting?
  14. Nov 2, 2018 at 2:31 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I also bought a tacoma sr 4 cyl but 2018. Yes, I have to nearly slam the door to close it and I tell the passengers always to close the door again because they didnt close it all the way. I got it this way and just accept it.
  15. Nov 2, 2018 at 2:50 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    My AC front doors take a little more gusto to get closed than my GTI doors did. I even checked the alignment of the latches to make sure everything lined up, looked fine.
