Common spare parts to have lying around?
Discussion in '1st Gen. Tacomas (1995-2004)' started by IDtrucks, Dec 4, 2011.
  1. Dec 4, 2011 at 5:22 PM
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    What are some good common spare parts to have stocked with the tools that are most likley to break off roading or just good to have lying around? Specs: 1996 4x4 2.7l automatic 122k miles. Thanks for the suggestions.
  2. Dec 4, 2011 at 5:52 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Fan belt, PS belt, idler pulley, radiator cap, coil, igniter.
    starter rebuild kit, front CV axle assembly.
    Haynes manual. LED flash light. + appropriate tools and supplies.
  3. Dec 4, 2011 at 10:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Unless you go nuts (seems unlikely) when you go wheelin, its unlikely you will break anything so bad you can't get back home.
    Your new truck is pretty much bulletproof for most reasonable off-roading. Now if you decide to join us at Moab and go do some of the "Difficult" rated trails you may want to consider bringing a space CV axle and a u-joint. :rolleyes:
  4. Dec 4, 2011 at 10:53 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    haha thanks for the reassurance. Well the holidays are coming up and im throwing out gift ideas and i wanted to put together a 4x4 box. In my mind i had a big tupperware container with a full set of screwdrivers, wrenches, hex keys, ratchets, extra fluids, common spare parts, and simple recovery gear. It could double as my personal mobile tool box and when i start going on overnight wheeling trips just throw the whole box back there and ive got all of the important stuff with me.
    thanks! Ill go look into those
