Common Tacoma Problems? F150 owner looking to switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rhyno37, Oct 25, 2013.
  1. Oct 25, 2013 at 7:50 PM
    Rhyno37
    Rhyno37 [OP] Member
    Hey guys, first post on the forums here.
    A little background, I currently am going to college and working part time at a Ford dealership as a detailer. Ended up trading in my 03 Silverado and getting an 06 F150 Lariat. Worst purchase ever, the 5.4 is the worst engine ever designed. I have the dreaded cam phaser issue, and it's about $2k on the dot with my discount to correct. Talk to the GM, and since I've had the truck for less than a year I'll be cut a deal on a new truck.
    That being said, an '11 Tacoma caught my eye. Here it is:
    http://www.mangoldford.com/2011_Toyota_Toyota_Eureka_IL_212785673.veh
    Now, I know I'll be downgrading a lot, but it's worth it to me to have a newer truck with low miles and a factory warranty (current is 89k), especially being a college student. The better mpg is a plus.
    So, what are some common problems I should be aware of for this specific year and configuration? (2011 base 4x4 tacoma)
    For comparison, the 04-08 5.4 F150's are notorious for the spark plugs breaking off, and costing an arm and a leg to take out and replace. Same goes for cam phasers, VCT solenoids, and lifters, starts to make the truck sound like a diesel.
    I want to be aware of what I'm getting into; did Toyota correct the rusted frame issues?
    I appreciate any and all help, and look forward to being a member if all goes well! :)
  2. Oct 25, 2013 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome!
  3. Oct 25, 2013 at 8:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Calling it a downgrade to go from an F150 to a Tacoma is fightin words round here
    We don't take kindly to Panda Bears that don't take kindly round here
  4. Oct 25, 2013 at 8:18 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Worse thing about Tacomas is you keep having to put gas in them. They just keep going and going and going.
  5. Oct 25, 2013 at 8:18 PM
    OZ-T
    Peter North
    British Columbia
    Oh and Welcome to TW from BC
  6. Oct 25, 2013 at 8:20 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Oct 25, 2013 at 8:39 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    No, Toyota did not take care of the rusted frame issue. Metal still rusts, no matter who made it. The key is to treat it. I have a 1950 dodge with no frame rust. It has been coated in used motor oil and will last another 50 years no problem. It really is not an issue if you wash it every once in a while and spray it every few years with whatever rust prevention coating you like. Like I said, used motor oil works good, and it's free. There are a few very minor issues with tacoma's, but nothing that will keep you from getting to work. There are some random squeek complaints, but it's easy to fix. Overall, it is the most reliable truck you can buy right now, and has the highest resale value if you change your mind in a few years. If you want a truck that will last 300,000 miles or more, get it.
  8. Oct 25, 2013 at 8:44 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Oh a "downgrade". I am not sure if I am too inclined to help you now. :)
    Honestly though. Tacoma's are still known for rust issues. Members have been using Fluid Film. I've never used it so I can't say if it works, other members can chime in about it. It squeaks, ticks, it has little annoyances(noise wise) but it's not going to stop anyone from buying it(at least for me).
    Compared to the F-150, there isn't big issues with Tacoma. As long that you do your regular maintenance you'll have a reliable Tacoma for the long term. It may not have all the bells and whistles compared to F-150, but you can add some of those bells and whistles if you wish. You may have a "downgrade" on the luxuries but you're going to have the upgrade of reliability and knowing you're not paying out of the butt for things like you have on the F-150.
  9. Oct 25, 2013 at 8:50 PM
    gb42
    gb42 Well-Known Member
    Geoff
    WA State
    2016 MGM TRD OR DCSB MT
    Squeaky leafs, chirping blower motor, loose steering when going over bumps, weak paint, no heated mirrors (oz <3), last but not least no turbo diesel option lulz.
  10. Oct 25, 2013 at 9:01 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You must be young, comparing the inadequacies of a ford to a Toyota. You should have seen the downfall of the big 3 during the financial crisis due to their inferior product.
  11. Oct 25, 2013 at 9:35 PM
    Rhyno37
    Rhyno37 [OP] Member
    Let me clarify, downgrade in the fact id be going from an extended cab lariat with all the bells and whistles to a truck with no power windows or locks, big downgrade. Second, I always liked the look of tacos but was iffy because of the rust issues. The whole ordeal with sudden acceleration really put a bad taste in my mouth in regards to Toyota, mainly failing to take responsibility. I do want a Tacoma because of the resale value, and would like to try out a small truck
  12. Oct 25, 2013 at 9:36 PM
    OZ-T
    Peter North
    British Columbia
    The unintended acceleration thing was all a driver error bullshit media witch hunt
  13. Oct 25, 2013 at 9:38 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    @Rhyno37: The whole powertrain is solid on that truck with no reliability issues.
    There are annoyances like squeaky leaf springs and chirping heater blower. The latter you can take to a dealer to get an updated blower installed.
    I see you are eyeing a base model. You can get cruise control and variable intermittent wipers by buying the appropriate steering column stalks from the dealer or online - the truck is already wired for it.
    Rust protection on '05+ trucks is better than the previous generation - Toyota changed frame manufacturer from Dana to Hino (you know, real trucks...). The change in frame design from fully-boxed to double-walled C-channel also deters internal rotting. My frame is in good condition after three salty winters.
    Toyota unintended acceleration is as much bullshit as Ford unintended acceleration, for which there are lawsuits also: http://blogs.cars.com/kickingtires/2013/04/ford-lawsuit.html And yes, your '06 F150 is included.
  14. Oct 25, 2013 at 9:41 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    What unintended acceleration? images_a6a0b041a6005be610b843bbb9c0d2e2765ad17f.jpg
  15. Oct 25, 2013 at 10:03 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Dude get a Tacoma and love it like we all mostly do. Plus ford lacks the reliability of a Tacoma. If I were you I would get a double cab SR5 with power options
  16. Oct 25, 2013 at 10:08 PM
    Rhyno37
    Rhyno37 [OP] Member
    Good to know, do you know off the top of your head how much it is for the cruise control and variable interment wipers? And would installing these parts void the factory warranty?
  17. Oct 25, 2013 at 10:15 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    It is obvious what most people on a TACAOMA forum will be telling you, but it is honestly up to you.
    I almost got an exact clone to that tacoma you linked....same color, same year, bucket seats, and an auto. But i chose the v6 for the slightly better resale value and because i live in a very hilly area and didn't want to be pounding a 4cyl up every hill. That being said, i would have been very pleased with that little 4cyl having driven a friends but i am damn glad i have the v6.
    If i needed a commuter truck in a flat area, that truck would be absolutely perfect, i'd get an aftermarket airfilter for it, vent visors, some floor mats, and color match all the outside plastics (flares, bumpers, grill) and it would be an awesome truck. I would definately be happy with that tacoma over your current f150. I hadn't liked the f150 AT ALL until they put the ecoboost v6 in them...and they still don't get good enough milage in my opinion.
    Again, it is up to you. Best of luck!
  18. Oct 25, 2013 at 10:28 PM
    Jimmy Bachar
    Jimmy Bachar Active Member
    Jimmy
    Oklahoma
    13 TSS Double Cab 4X4
    Do yourself a solid and get the taco. The only problems with tacomas is that once you buy one mod for them you cant stop and then you turn into an addict
  19. Oct 25, 2013 at 10:36 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Tires................... we have traction problems do to all the VVTi POWA
    I keed I keed............... well, some of us do
  20. Oct 25, 2013 at 10:47 PM
    JohnnyWayne
    JohnnyWayne The Past Through Tomorrow
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Look out for snakes in the grass guerrilla marketing.
    Only common problem I have had with mine is the negative balance to my bank account after getting bitten by the mod and suspension bugs :D
    Get one, you won't regret it and welcome
