Commonly Broken Parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Camel51, Jul 15, 2016.
  1. Jul 15, 2016 at 2:19 PM
    Camel51
    Camel51 [OP] Well-Known Member
    Colorado
    2006 DCSB TRD-Offroad
    OME BP51's, Brute Force Fab, BFG KO2's
    When offroading what are the most common parts that break that I should carry a spare for? I'm into Overlanding and not rock crawling and don't want to carry excessive spare parts. Thanks guys & gals
  2. Jul 15, 2016 at 2:58 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I'd love to hear what others say about this.
    I've thought about this a lot since I'm into light "overlanding" myself. Haven't really come up with a great list but there are a few things I've thought about.
    Is it something I can fix on the trail to begin with? If not of course leave it out.
    Is it something that will 100% prevent me from limping the vehicle home? People talk a lot about driveshafts and CV axles. Is it possible to limp home in 4WD without a rear driveshaft? Is it possible to limp with a broken CV axle just hanging out?
    Ball joints and tie rods are brought up a lot. I would probably have a full tie rod and pickle fork in my bag.
    Engines can usually run down 1 or 2 cylinders depending. Because of this I'd leave out anything that's cylinder specific.
    I think the thing you're most likely to have trouble with is the battery. I'd prioritize a second battery.
  3. Jul 16, 2016 at 7:16 PM
    Camel51
    Colorado
    Good thoughts, makes sense
  4. Jul 16, 2016 at 7:38 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would always keep a spare Serpentine Belt, wont take up much space, although its usually one of the pulleys that goes bad.
    Camel51[OP] likes this.
  5. Jul 16, 2016 at 8:15 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    what breaks ?
    the bank
    LOL
    srsly, nothing breaks unless you hambone it into some bullshit
    flats... you need spares
    you hear scraping, get out and look see if it's critical. it won't be, run it, loves it
    KILLINTIME likes this.
  6. Jul 16, 2016 at 9:03 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The fuel gauge - it always wants to read empty, even when it seems you just filled the tank. :)
    Spare fuel gauge sender floatant is definitely a good idea to prevent low power issues.
  7. Jul 16, 2016 at 9:17 PM
    Camel51
    Colorado
    Interesting
  8. Jul 16, 2016 at 9:35 PM
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    I am into both over landing and rock crawling. In my tool box I carry an extra cv axle, upper and lower ball joints, inner and outer tie rod ends, brake fluid, and oil. I also have the back half of the rear driveshaft. As of right I want to add a couple U joints and some coolant. Other wise ever thing else is too much for the trail or I can limp the truck to a maintained road.
  9. Jul 16, 2016 at 9:51 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    And yes, I do carry a spare serpentine belt ( I save the old one when I replace, so the spare is "free", and it has saved my butt in the past.) I also carry a selection of tools, a plug kit and air compressor, some recovery gear along with the winch at all times, booster cables, a 2 1/4 lb quality axe, a shovel, a fire piss can in summer months. As for the battery - I run a group 31 and test it often, and often have a deep cycle battery for my trolling motor along on fishing trips - which can be used to boost in a pinch. I maintain the rest of the truck well and have no worries about busting it in half out there, and if it did, I have the skills to MacGyver my way home or just call for help on my mobile radio. Short of all that, I've got good boots and socks, as well as fire lighting equipment and a tarp to make a shelter, among other things. That fuel sender floatant is a big one though - don't overlook it.
  10. Jul 17, 2016 at 1:01 AM
    andrew61987
    Is it possible to remove all or part of the rear driveshaft on these trucks and still drive with the front wheels in 4WD without fluid leaking out of the case?
  11. Jul 17, 2016 at 2:39 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Just my 2 cents....
    I'm my 30 yrs of exploring, camping, hunting and fishing in the north woods of Maine, with numerous vehicles, I don't think I've ever carried a spare part other than a spare tire. And never been in a position that required the use of a spare part. I do carry a tote with plug kit (used many many many times), compressor, tools & recovery gear.
    If you don't beat on the truck, it'll perform as needed.
    Probably just jinxed myself. o_O
  12. Jul 17, 2016 at 5:48 AM
    Night Eagle
    Leo
    2014 TDR Off Road
    Yep you can remove the whole thing and be fine. If you have to drive in fwd you want to remove the whole thing. The reason I have a spare drive shaft is because I was in moab and smash the crap out of my driveshaft and didn't want to drive 6hrs on the front one.
  13. Jan 26, 2017 at 12:10 PM
    mn_keith
    mn_keith Active Member
    Keith
    Minneapolis
    2014 Tacoma DCLB TRD Sport
    You never had a 3G 4Runner then. :playball: (that's the "throwing LBJ against a brick wall" emoji)
  14. Jan 26, 2017 at 3:46 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    assembled wheel bearing/ hub should be added to the list. I've seen these go out offroading as well as on the road too. The rest of the part list looks pretty complete with what was mentioned above. permatex gasket maker can be used to patch a leaking diff in a pinch and a steel stick putty can be used to patch a hole in a gas tank. small enough to keep in the truck for when you need it
  15. Jan 26, 2017 at 7:02 PM
    badger
    badger Well-Known Member
    07 SR5
    You will find that you need very few spares if you regularly maintenance your vehicle yourself. Most mechanical failures come from things that you can see coming a mile away. Grease your u-joints every oil change, and check for bad joints and play in the pinion bearing. Look under the hood on a regular basis and check for leaks, and bad hoses and belts. check your front end stuff and bearings at every tire rotation. The things that will blind side you are electrical. The number one thing that has stranded me over 40 years of adventure travel is the darn battery. Batteries have sent me walking more often than ruined tires. You can get a shorted cell, and you are dead! Using AGMs pretty much eliminates that worry. Acid batteries don't hold up well to offroad use.
    I carry:
    roll of wire
    roll of self vulcanizing rubber tape
    fuses
    headlight bulbs
    electrical tape
    JB weld
    gorilla duct tape
    serp belt (old used one)
    tire plugs
    carefully selected tool kit
    selection of random metric nuts and bolts
    electrical tester
    I have carried all kinds of parts over the years (axles, u-joints, etc), and never once needed one. One time in 40 years I needed a spare tire. All the rest were fixed another way. Twice I had batteries die without warning. Broken u-joint on a buddies jeep, that I jiggered together well enough to do 25 MPH. Got home at 2 am. I've had to limp a few times but very few situations I could not work around.
    sdpnoy and Pigpen like this.
  16. Jan 26, 2017 at 7:31 PM
    Jonny22r
    Jonny22r KCCO
    Jonny
    Peoria AZ
    2014 DCSB SPORT 4x4
    Kings, Methods, blah blah blah
    Just carry a spare truck.....
    Torspd and kgarrett11 like this.
  17. Jan 27, 2017 at 2:36 PM
    witch doctor
    witch doctor Mycophagist
    2.7l '04 Xcab 5-speed 4x4
    Look no further.
