Communication is Key | 3rd Gen Hood Antenna Mount
Discussion in 'Victory 4x4' started by victory4x4, Mar 5, 2019.
  1. Mar 5, 2019 at 1:10 PM
    victory4x4
    victory4x4 [OP] Member Vendor
    Portage, MI
    Communication is key, and this is a great place to mount a HAM, GMRS, or CB antenna to your Toyota Tacoma.
    • Designed to use thick NMO mounts like the Laird Technologies Part #: MABTO or the PCTEL Part #: BMATM3-NC, among others.
    • Laser cut from .190 thick aluminum, uncoated to allow for an electrical ground. Must use an NMO style antenna.
    $29.00 (free shipping)
    https://www.victory4x4.com/product/VT3CB-BARE.html
    Antennas emit radiation. You are responsible for making sure that your setup stays within safe levels. These levels can vary based on output power, antenna gain, and your distance from the antenna while transmitting. We are not responsible for doing this research or evaluating the safety of your setup. More information provided by the FCC can be found here: https://transition.fcc.gov/bureaus/oet/info/documents/bulletins/oet65/oet65b.pdf
  2. Oct 13, 2019 at 7:16 PM
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    This looks great! How do you get the antenna wire into the cab?
    TomTwo likes this.
