Comparing MPGs: Tire Diameter VS Weight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by C_loww, May 7, 2020.
  1. May 7, 2020 at 4:14 AM
    C_loww
    C_loww [OP] New Member
    Craig
    2019 TRD OffRoad DCSB
    Hey guys, new to the forum here. I have looked far and wide without much of a clear answer. I’m trying to decide between 275/70 17, and 285/70 17 in the Falken Wildpeak at3w, however the 275 is a C rated tire coming in at 57lbs each. The 285 that I’m looking at is P rated, and only 50lbs.
    I spend most of my time on the highway in my daily commute to work, so MPGs are pretty important, but I do want to look cool also, which is why I’m upsizing!
    So the question is; would I get better MPGs out of the 285s, being 7lbs less per tire, or the 275s because of the 0.6” height difference? Thanks in advance!
  2. May 7, 2020 at 4:28 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Yup, that's a hard question.juat to give an idea for the weight catagory. I have 235/75/15 and I went from a 25 lb tire to a 36 lb and my mpg dropped by 3, 22-19
    C_loww[OP] likes this.
  3. May 7, 2020 at 4:31 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've been buying tires since the 1970's and have never noted a correlation between tire weight and fuel mileage. I have noted a difference with wider tires and tires with more aggressive tread losing 1-3 mpg compared to narrow tires with a less aggressive tread. Taller tires also effectively change the axle ratio and force the engine to work harder. But in my experience as long as you stay within 1-2" of the stock size the difference is minimal.
    My Tacoma came with P rated 265/70/16 tires that weighed 38 lbs each. I've been running E rated LT265/75/16 tires that weigh 53 lbs each for several years. The E rated tires are 1" taller, same width, and with a similar mildly aggressive All Terrain tread. My fuel mileage is exactly the same as it was 13 years and 204,000 miles ago.
    In my experience expect 1-3 mpg fuel loss with either tire. Both are wider and taller than stock with a more aggressive tread. I doubt if it would make much difference, but the wider 285 will probably hurt fuel mileage the most. Seven pounds of weight is a non-factor
    LoveableWerewolf likes this.
  4. May 7, 2020 at 4:32 AM
    LoveableWerewolf
    Nashville
    This answer seems very correct. I didn't even think about my more aggressive tread.
  5. May 7, 2020 at 4:46 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I went to 285s and I gained mpg :anonymous:
    GHOST TACO, C_loww[OP] and cbuccio like this.
  6. May 7, 2020 at 5:15 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    @ 28 lbs diference, I'd be like having your dog with you on the trip!
    I'm guessing the wider the tire, the more drag.....
    C_loww[OP] and zoo truck like this.
  7. May 7, 2020 at 5:23 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Difference is that it is rotational and unsprung weight and it acts very different. Think of it like wearing a 28lbs backpack going for a jog vs having 28lbs weights strapped to your ankles.
    C_loww[OP], beergeek and Thatbassguy like this.
  8. May 7, 2020 at 6:13 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I do not think anyone can accurately answer your question unless they have tested fuel economy with both tires. I also think people put too much emphasis on tire weight and diameter. A rolling tire heats up when it flexes and this energy is then dissipated into the environment; much like a brake. The amount of energy loss is a function of many things including rubber compound, amount of rubber, tread design, etc. Weight by itself does not affect this, but it can be correlated with the amount of flexing rubber in the tire.
    It's true that since a tire is rotating that it contains both translational and rotational energy unlike the non-rotating parts of the truck, but the tires are very light in comparison to the entire truck. Also this energy is not really lost until you hit the brakes.
    Here is some discussion of the topic.
    https://ecomodder.com/forum/showthread.php/effects-wheel-tire-rotational-energy-25197.html
    NHTSA Tire Fuel Efficiency Consumer Information Program Development: Phase 2 – Effects of Tire Rolling Resistance Levels on Traction, Treadwear, and Vehicle Fuel Economy
    https://www.nhtsa.gov/DOT/NHTSA/NVS/Vehicle Research & Test Center (VRTC)/ca/Tires/811154.pdf
    With that said, I’ll take a guess and say the p-rated tire will provide better fuel economy than the c-rated because it’s likely to have less rubber that is flexing per distance traveled.
    C_loww[QUOTED][OP] likes this.
  9. May 7, 2020 at 6:35 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    OP, If you are not lifted, I'm pretty sure those tires will rub.
    G.
    C_loww[OP] and Thatbassguy like this.
  10. May 7, 2020 at 6:39 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Aside from what's been said so far, this will depend on how you drive. If you're doing a lot of highway driving, and don't accelerate aggressively, you might not notice a big difference with either tire.
    On the other hand, if you do a lot of stop and go driving, and always flooring it to get up to speed, you will notice a big difference.
    I just switched from 265/70/17 KO2's @ 45.55# apiece to 285/70/17 Toyo Open Country AT3's @ 55# apiece. Around the city, I seem to have lost about 2 MPG. On a mini road trip last weekend, I got pretty close to normal fuel economy as measured by the odometer, which is impressive considering they're 1.1" taller and 10# heavier than the KO2's.
    This is just my experience so far. YMMV
  11. May 7, 2020 at 6:53 AM
    P-Dawg
    P-Dawg Factory 2 Seater
    Pete
    Chicago
    2020 SR AC MGM Utility Pckg.
    For highway driving a wider tire will get less mileage , a taller tire will get less mileage and make your truck less stable. Keep in mind tires with less offset (sticking out farther) hurt highway mileage as well. If you don't need the clearance for off roading consider something less extreme, you can make your truck look much cooler with a mild size upgrade without losing too much mileage or stability on the highway.
  12. May 7, 2020 at 6:55 AM
    P-Dawg
    Pete
    Chicago
    According to your Taco's readout or actual measurement?
  13. May 7, 2020 at 7:04 AM
    Anchovy
    TRD Ferguson
    Actual measurement. I drove X amount of miles and used X amount of gallons of gas. When I did the math, the readout was almost 2 mpg less than what I actually got
    I used GPS to find out how many miles I actually drove, not the trucks readout
    C_loww[OP] and P-Dawg[QUOTED] like this.
  14. May 7, 2020 at 7:11 AM
    calebc
    calebc Well-Known Member
    Close but put it a little more in perspective, 28 lbs on a 4000 lb truck vs ~1.4 lb strapped to a 200 lb man's ankles...it's not noticeable.
  15. May 7, 2020 at 7:20 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I went from 245/75/16(3ply) to 235/85/16(10ply) and lost 4mpg.
  16. May 7, 2020 at 7:21 AM
    Clearwater Bill
    Billy
    Largo Florida
    Then Michelin Defenders, in OE or +1 size is where you want to be.
    Sometimes not all the boxes can be checked. In this case the 'cooler' you look the more TCO will rise.
  17. May 7, 2020 at 7:30 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    1.4 pounds strapped to a 200 lb man is not noticeable? I would have to disagree. Since I started competing in triathlons a few years back and I have become aware of every ounce or gram of weight I am carrying.
    Thatbassguy and C_loww[OP] like this.
  18. May 7, 2020 at 7:45 AM
    calebc
    Again, are we talking about a track car that every ounce is noticeable or a 4x4 truck that will end up with more than the weight of the tires easily in worthless upgrades? Yes, every pound counts, but get real, a couple pounds at each tire isn't going to dramatically impact fuel mileage. As mentioned earlier, the extra width, which creates extra friction will impact mileage more than anything.
    CaptainBart45[QUOTED] likes this.
  19. May 7, 2020 at 7:50 AM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    I think any difference in economy from tire weight for the same diameter at highway speeds is more likely from tire stiffness. If the tire is rated higher, it's stiffer and more energy is lost as the contact patch makes its way around the tire - effectively squaring off a circle. More aggressive treads do the same thing with the blocks of tread causing local spots where its stiffer compared to the space between treads. A wide tire means a larger contact patch = more deforming rubber every rotation, more energy loss.
    You can tell tires lose energy because they "warm up" with use - literally energy from your engine imparted into the tire.
  20. May 7, 2020 at 8:01 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If your worried about 1-3 mpg you have no business getting bigger tires, it comes with the game except it or don’t.
    C_loww[OP] and AG-TACO like this.
