Compass in rear view mirror incorrect
Discussion in '3rd Gen. Tacomas (2016-2023)' started by z1288, Sep 16, 2021.
  1. Sep 16, 2021 at 8:12 AM
    z1288
    z1288 [OP] Active Member
    Hello,
    I have a 2021 OR with the compass in the rear view mirror. Since I bought the truck it hasn't read correctly. Is there a way to calibrate it?
    Thanks.
  2. Sep 16, 2021 at 8:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. There are instructions in the OM. The biggest deal to be sure that it is set to the correct region.
  3. Sep 16, 2021 at 8:13 AM
    Tacospike
    Two Trucks
    Just curious, is it different from the center cluster compass?
  4. Sep 16, 2021 at 8:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The center cluster compass is most likely based on the GPS signal, but I do not know fo sho.
  5. Sep 16, 2021 at 8:22 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The earth's magnetic field is shifting due to the movement of the tectonic plates plus the dispersal of all the metal ores being mined and made into products. In a few years, North will be shifted to what is now East.
    <edit> Sorry, North is shifting to what is now South.
    davidstacoma likes this.
  6. Sep 16, 2021 at 8:31 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    True North and magnetic north aren't exactly the same. Depending on where you live you may be close enough to not matter, in other places you can be off significantly. You just have to know where you are and compensate. Where I live is only off by about 4 degrees, which isn't a huge deal. But when I travel to other parts of the USA it can be off significantly.
  7. Sep 16, 2021 at 9:24 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    That flippy-floppy polar thing takes way longer than a few years, though I did read that the relative movement has accelerated over the last decades. My understanding is that it’s mostly the earth’s fluid ferrous core (or whatever it’s called) that is responsible for the magnetic field. Where did you read that our surface mining may be contributing to the effects?
    tonered and davidstacoma like this.
  8. Sep 16, 2021 at 9:27 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I assumed he was joking. Hopefully lol. Either that or he’s reading The Woke Pseudo Science Times.
  9. Sep 16, 2021 at 9:29 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I thought that may be the case, but our understanding of geomagnetism is so imperfect that it’s hard to know!
    Skydvrr and davidstacoma[QUOTED] like this.
  10. Sep 16, 2021 at 9:36 AM
    davidstacoma
    David
    NC
    I don’t have a compass in my SR. Doesn’t anybody else use dead reckoning and the sun and shadows anymore?
    BamaBillENC and Roberto123 like this.
  11. Sep 16, 2021 at 9:44 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The poles have been shifting for eons. There’s evidence based on old lava flow on the bottom of the ocean and judging by that evidence, we are overdue for a pole shift
    brandon78lusch likes this.
  12. Sep 16, 2021 at 9:58 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I thought it was well under way?
  13. Sep 16, 2021 at 10:10 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Yes. Movement also varies across the US. For example, The Washington monument in DC moved northeast 28.8 meters between the years of 1927 and 1987, where as the dome on the state capitol in Sacramento (CA) moved 91.7 meters southwest. This is movement based on continental shift, not absolute location (coordinates).
    Malvolio likes this.
  14. Sep 16, 2021 at 10:12 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’m just glad to see any sort of productivity coming out of the capitol building!
  15. Sep 16, 2021 at 10:14 AM
    brandon78lusch
    Brandon
    LOL
    ConantTaco and Malvolio[QUOTED] like this.
  16. Sep 16, 2021 at 10:20 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Super easy to do in a new city on a cloudy day. /s
    OPs truck's compass isn't working correctly. They weren't asking if your SR has one or if there is another way to navigate.
    Kev250R likes this.
  17. Sep 16, 2021 at 10:25 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The odd number interstates are north-south (e.g., I95). Even numbers are east-west (e.g., I70).
  18. Sep 16, 2021 at 10:25 AM
    davidstacoma
    David
    NC
    It was humor, appears to have escaped you lol.
  19. Sep 16, 2021 at 10:26 AM
    brandon78lusch
    Brandon
    This is good advice
    Honda2Toyota likes this.
  20. Sep 16, 2021 at 10:28 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    Ha. I suppose.
    It wasn't a reach for me to assume some old guy was complaining about the kids using a digital compass.
    Turns out I'm the crotchety one. I'll log off and go watch Matlock.
    RushT, Kev250R and Malvolio like this.
