Compass stuck in CAL N
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doabbs, Sep 28, 2013.
  1. Sep 28, 2013 at 9:05 AM
    doabbs
    doabbs [OP] Active Member
    I noticed my compass was starting to get out of magnetic alignment. I checked the VAR setting and it was set incorrectly. So I changed the value to 12, which according to the manual is the correct setting for New England. I then put it into CAL mode and drove around per the manual but no matter how many times I drive in a circle it just stays on CAL N. Has anyone run into this before? I've tried changing the VAR back to what it was originally but no matter what value I use or how many circles I do it just won't stop saying CAL N.
  2. Oct 16, 2013 at 5:59 AM
    doabbs
    So I replaced the compass with a brand new one from Toyota and same problem. For the life of me I cannot get a compass to calibrate inside my truck.
  3. Mar 20, 2014 at 5:38 PM
    CBTaco2010
    CBTaco2010 Well-Known Member
    Dartmouth, Nova Scotia
    10 SR5
    Hey man, did you find a fix for this?
    Having the same issue
  4. Mar 22, 2014 at 6:07 AM
    doabbs
    Nope,
    I gave up after weeks of trying every possible thing I could think of. Replaced basically every component, including the thermo sensor just in case. Ended up just putting back the plan old overhead console in.
  5. Sep 28, 2015 at 7:15 PM
    sgoveas
    sgoveas Member
    Just started having the same issue, stuck showing calN :(
    Anyone have a fix for this?
  6. Mar 3, 2016 at 5:27 AM
    bwanamukubwa
    bwanamukubwa Well-Known Member
    Tennessee
    Did anyone of you guys have a fix for this? I got this issue yesterday. Mine started with compass stuck in SE so i verified the location and am now stuck in calN too :cool:
  7. Mar 3, 2016 at 6:00 AM
    CBTaco2010
    10 SR5
    to calibrate it you have to drive your truck around in a circle.
    that's what fixed mine anyway... find a parking lot and do some slow donuts
    ClammyPeach likes this.
  8. Mar 4, 2016 at 5:15 AM
    bwanamukubwa
    Tennessee
    i drove around in a tight right circle going as comfortably fast as i could ten times before i got dizzy and quit :der:
    what speed did you drive at?
  9. Mar 4, 2016 at 5:28 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    nibiru's comin :anonymous:
    theredofshaw likes this.
  10. Mar 4, 2016 at 5:30 AM
    bwanamukubwa
    Tennessee
    did i summon it in the parking lot doing circles??
  11. Mar 4, 2016 at 6:47 AM
    CBTaco2010
    10 SR5
    just in first gear, a little faster then idle.
    you have to go into the compass menu and it gives you instructions on when to do it.
  12. Aug 4, 2018 at 10:03 PM
    Marc2010
    Marc2010 Member
    Marc
    2010 Grey Tacoma 6MT DCSB TRD
    Hey, having the same issue. Drove around many times. No go. Does the compass tell you when to start driving?
  13. Sep 28, 2018 at 10:55 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Hey guys, I'm having the same problem. It just won't get out of Cal N no matter how many times I drive in circles.
  14. Sep 28, 2018 at 11:36 PM
    GLube
    GLube Active Member
    Garrett
  15. Jan 24, 2021 at 12:55 AM
    cd183
    cd183 New Member
    2006 5-Lug Access Cab Tacoma
    Fat bobs lift, 31” Wrangler ATs, Lock-Right No-Slip, Apex Offroad bed rack, Smittybilt Overlander RTT, Retrofits (cruise, overhead compass, intermittent wiper switch), CarPlay Radio, more
    Still a known issue? Having these problems myself and hoping I don’t have to buy a new one just to experience the same thing :/
  16. Jan 24, 2021 at 5:07 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    It’s cause your stuck in a time warp you need to drive 100 miles south 50 miles east 50 miles west then 100 miles north
    Come back to TW and ask the same question
