Compass/temp gauge question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mstacoma, Sep 27, 2011.
  1. Sep 27, 2011 at 6:38 AM
    Mstacoma
    Mstacoma [OP] Member
    06 Trd Sport
    I recently purchased an 06 TRD Sport. Did not notice until I got it home that it had the temp and compass display. I just assumed that it maybe did not have the installed option but after doing some reading I would now think if it did not have the option installed it would have the garage door opener slot instead and maybe I have the well documented solder problem most have with the compass and temp gauge. Would this be correct that the compass and temp probably would not be there if this was not a factory install? Thanks your thoughts on this.
  2. Sep 27, 2011 at 7:04 AM
    D4D Hilux Dude
    D4D Hilux Dude Well-Known Member
    Darren
    Arvada, CO
    2011 4x4 Double Cab TRD Offroad
    TRD Supercharger TRD Catback Exhaust Ziebart Rust Proofing Additional Bed Ties 2012 Indicator side mirrors
    Post a pic of it...
  3. Sep 27, 2011 at 12:18 PM
    Mstacoma
    06 Trd Sport
    Sorry, it is not letting me upload for some reason? It is like many i have seen posted on this website and others with the blank screen and button in front. I press the button but no response. Thanks
  4. Sep 28, 2011 at 7:28 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you have a TRD model and the display, it is wired for it and should work. Like you've already said, I would take it down and see if it's the resistor that needs soldered.
  5. Sep 28, 2011 at 12:26 PM
    Mstacoma
    06 Trd Sport
    Thanks, that is kind of what I was thinking. I would not think Toyota would go to the expense to install that feature and not wire it or hook it up. I will be checking the solder issue out this weekend.
