Compass/Temp Out - Under Warranty?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jkc, Mar 27, 2012.
  1. Mar 27, 2012 at 7:05 AM
    jkc
    jkc [OP] Member
    Baltimore
    06 TRD Double Cab
    My compass/temp gauge went out, ironically right after I had an emissions test done. Dont know if or how they could be related but anyway its not working anymore. I checked the fuses, according to the book it looked like like #2 in the engine box or #26 under the dash. Both were fine.
    I read the post on what the usual problem is and how to fix it. I can do that but has anyone had this replaced under warranty? If I try to fix it and it doesnt work I'm pretty sure that would void the warranty. I called to ask if it would be covered and they couldnt tell me yay or nay. I have to bring it in for them to determine. If it is, good I'll happily pay the $50 deductible, if not I dont want to pay that $50 dollars for them to tell me its not covered when I can possibly fix it with some solder.
    Thanks
  2. Mar 27, 2012 at 7:19 AM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    extended warranty? yes I would think it should be covered, that wouldn't be considered a wear and tear item and if they say no, I would just complain until you get it, for the money you paid for that warranty I think they can order you a new mirror
  3. Mar 27, 2012 at 7:31 AM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    Its most likely the resistor in it, 501 I think. There is a thread on it. I'll look for it. I did it for a buddy and worked great.
  4. Mar 27, 2012 at 7:33 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    He knows and already read it.
  5. Mar 27, 2012 at 7:34 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
  6. Mar 27, 2012 at 8:19 AM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Mine was replaced under warranty.
  7. Mar 27, 2012 at 8:37 AM
    jkc
    jkc [OP] Member
    Baltimore
    06 TRD Double Cab
    Thanks everyone, Im going to take it in. Couldn't remember which extended service I bought so I called and it was the best one they offered which covers everything except normal wear and tear and for the cost of it they better not try to tell me that looking at is normal wear and tear.
  8. Mar 27, 2012 at 10:29 AM
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    If its not under warranty just fix it yourself. I had to do this a couple months ago and its real easy to do all you need is a soldering iron, and follow that thread that the guy gave you a couple posts ago. Its gonna most likely be that 501 resistor thats just popped off. You just solder it back on.
  9. Mar 29, 2012 at 8:52 AM
    jkc
    jkc [OP] Member
    Baltimore
    06 TRD Double Cab
    Took it in this morning. Had a couple other things done that I think I will do on my own next time since the labor was 3 times the cost of the parts. They tried to tell me that the compass wasn't covered under my extended warranty. They told me I had a powertrain only warranty which I knew was not the case. Come to find out each dealer may use a different extended warranty for the certified-used vehicles. (bought an 06 with 25000 on it and the waranty i purchased was for 3 years or 100000). The dealer I was at this morning (closer to work) doesn't use the insurance I bought from the other dealer and apparently no record in the computer system. Good thing I kept that little pamphlet. They called the number and sure enough it was covered. Lesson from this, buying a vehicle can be overwhelming with many decisions. Know what you buy and hang on to the paperwork.
