compatible parts??
Discussion in 'Suspension' started by PPD934, Aug 4, 2009.
  1. Aug 4, 2009 at 6:08 AM
    PPD934
    PPD934 [OP] Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    I currently have the toytec 3" spacer lift which comes in two pieces. like this i AM WANTING TO CHANGE TO THE OME LIFT WITH 885 COILS AND SUCH. WILL THE SMALL SPACERS YOU SEE ABOVE TAKE PLACE OF THE TOP PLATE SPACERS NEEDED TO MAKE IT A 3 INCH LIFT WITH THE COILS OR EVEN THE 1/4 INCH SPACER TO MAKE IT A 2.5 INCH LIFT. THESE ARE THE 1/4 INCH SPACERS
    JUST THINKING IF i CAN SAVE ANY MONEY.
  2. Aug 4, 2009 at 6:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 885 coils will give you 2.5" of lift, or more as is. If the top plate spacer on the Toytec one is 10mm thick, you can re use it on the OME lift.
