Complete Brake Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MadisonTaco, Mar 3, 2016.
  1. Mar 4, 2016 at 5:51 PM
    #201
    mudrida711
    mudrida711 New Member
    2016 magnetic gray PreRunner
    none yet
    I was reading about it somewhere, but I can't remember where it was
  2. Mar 4, 2016 at 6:49 PM
    #202
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    When you get your truck back try to find a snowy icy parking lot to try to recreate the problem. If it is a similar problem to what my truck does then you should be able to get to happen. Most of the time the ABS will pulsate like its supposed to but maybe 1 out of 20 attempts I can get it to do the no brakes/coasting problem. I believe it happens when all or close to all of the wheels lock up/slide so the ABS kills braking power to all wheels. I now expect it possibly happen anytime I'm stopping in the snow and give myself extra stopping distance. I also don't let anyone else drive the truck in the snow. Better tires also help. I have Toyo Open Country AT tires now and the ABS activates much less than with the stock tires.
  3. Mar 4, 2016 at 7:34 PM
    #203
    MadisonTaco
    MadisonTaco [OP] Well-Known Member
    Madison,WI
    2016 TRD Off-Road DCSB
    Softopper Roof Rack
    Well it just finished snowing so I think I'm going to take a ride to the new subdivision. Just a straight paved road and see if I can't replicate the problem. What did the dealer say to you?
  4. Mar 4, 2016 at 7:57 PM
    #204
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Drove up an down the road. Couldn't get it to duplicate. More stopping in that 15 min than I'd care to repeat. Now I did discover something. Under 5 mph the wheels lock up and the ABS doesn't activate. At 6 mph it does. Under that 5 mph mark the peddle felt strong and no pulsing. Above 6 mph I had the standard ABS peddle pulse. Now I am honestly more confused. If ABS doesn't activate till after 6 mph how could the loss of peddle be due to ABS when I was going less than 1 mph...???
  5. Mar 4, 2016 at 8:09 PM
    #205
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It was never due to your ABS
  6. Mar 4, 2016 at 8:09 PM
    #206
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What kind of driving and temperatures prior to it happening the first time?
  7. Mar 4, 2016 at 8:11 PM
    #207
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Very similar to tonight. Upper 20's low 30's. Snow tonight was slightly slipperier than when it happened.
  8. Mar 4, 2016 at 8:13 PM
    #208
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  9. Mar 4, 2016 at 8:13 PM
    #209
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    After testing it tonight and seeing how the ABS reacts at a slow speed I agree. I still don't know what caused the problem but I cannot replicate it. Will try again in the morning with a colder temp. Hopefully the snow sticks around until then.
  10. Mar 4, 2016 at 8:14 PM
    #210
    splitbolt
    NW Arkansas
    Any higher speed driving prior to the first occurrence?
  11. Mar 4, 2016 at 8:22 PM
    #211
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Any aftermarket stuff done to your truck recently? Just curious. Seen guys blow a hole through a brake booster many times and try to patch it up with butyl rubber. Just wondering if maybe there is a leak or something. But OR's have the hydraulic booster right?
  12. Mar 4, 2016 at 8:22 PM
    #212
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Drove home from work on wet roads with some snow cover in areas. Max speed of 55mph. Truck sat for 45 min to an hour on the road as I cleared the driveway and sidewalks of snow. Turned truck around, pulled in driveway and they failed while feathering the peddle as I was positioning my truck in the garage.
  13. Mar 4, 2016 at 8:23 PM
    #213
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Truck is stock minus Softopper and roof rack. Yes the OR has the new hydraulic booster.
  14. Mar 4, 2016 at 8:27 PM
    #214
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Yah, I already know I'm a d- bag. Wait.......don't you drive a Ford?
    WMDtech and Speedytech7 like this.
  15. Mar 4, 2016 at 11:22 PM
    #215
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Ok this answers your complaint... The 2016 has hydraulically boosted brakes like most diesel trucks do. You pumping the brakes to "inch into position" most likely exhausted the accumulator of pressure resulting in a dead pedal. Instead of pumping the brakes try a more steady pressure on the pedal till you get to your parking position. I own 2 3500 Dodges both are different year models and have different ABS systems. Both trucks have "hydro boost" braking systems similar to the system used on the new Tacoma. You can make both of the have a dead pedal feel if you repeatedly pump the brakes at idle and exhaust the accumulator pressure.
  16. Mar 4, 2016 at 11:28 PM
    #216
    RedBeard1
    Red
    This is also correct tires lock from being wet on slick concrete ABS kicks in release front brakes. Truck slides then rolls.
  17. Mar 5, 2016 at 12:36 AM
    #217
    thors.hammer
    thors.hammer Well-Known Member
    You repro'd the issue ?
  18. Mar 5, 2016 at 2:36 AM
    #218
    AKTACOTRUCK
    AKTACOTRUCK Well-Known Member
    Shawn
    Red 2008 Tacoma TRD Offroad Double Cab
    Bull bar, but more to come
  19. Mar 5, 2016 at 4:50 AM
    #219
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    Madison here too man! This snow is perfect to go test out more. So sorry you are having to deal with this issue. You west or east side?
  20. Mar 5, 2016 at 5:11 AM
    #220
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I'm not going to scour the whole thread, but have you considered disabling the ABS system in your truck until you get a solution? Probably as easy as pulling a relay in the fuse panel and I bet that would eliminate whichever electronic component caused the problem.
