Complete Brake Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MadisonTaco, Mar 3, 2016.
  1. Mar 5, 2016 at 5:32 AM
    #221
    MadisonTaco
    MadisonTaco [OP] Well-Known Member
    Madison,WI
    2016 TRD Off-Road DCSB
    Softopper Roof Rack
    Interesting. Now When I am pulling into the garage I am more feathering the brake. Never fully on or off the brake. I will have to do some more research on the hydro assist.
  2. Mar 5, 2016 at 5:32 AM
    #222
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    OP,
    Though not desirable it seems like your experience was a normal characteristic of the vehicle and conditions. While your experience is useful information for many of us to be aware of it seems clear your vehicle did not have a complete brake system failure. As I stated before in post 143, making a claim that your truck's brakes completely failed is a serious accusation against an automaker and if it did not happen it would be malicious , at least in character to perpetuate that rumor. Respectfully, I suggest you delete or lock this thread and start a new thread which describes your experience and this braking characteristic, like the Gen2 thread, so people can be aware of it without having to read through all the noise in this thread and so that people aren't given the false pretense of the thread title.
  3. Mar 5, 2016 at 5:37 AM
    #223
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Don't change a thing OP. This thread is fine.
    TacoBella and Liquidmantis like this.
  4. Mar 5, 2016 at 5:45 AM
    #224
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    I disagree completely. My brakes did fail. It is interesting though that you keep bring up the 2nd gen and that in certain situations, at slow speed the ABS has trouble recognizing the situation. With my testing last night it would seem to me that Toyota corrected that problem by programming the ABS to not activate until you reach a speed greater than 5 mph.
  5. Mar 5, 2016 at 5:46 AM
    #225
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Sun Prairie technically.
  6. Mar 5, 2016 at 5:47 AM
    #226
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    No I did not. I was asked if I had traveled at high speed before the "incident" happened.
  7. Mar 5, 2016 at 6:58 AM
    #227
    anotherreject
    anotherreject Well-Known Member
    i read all 12 pages and have to ask
    -"if" the issue is the same as the 2nd gen as it relates to wheel speed, sensing a slide, etc why hasn't it been fixed from the 2nd gen?
    -"if" the problem is not the same as the 2nd gen and the hydro-boost and accumulator pressure is the issue why hasn't that been updated/fixed?
    at no point is it acceptable to lose all braking and have the pedal hit the floor and require use of the e-brake to stop. never. not all consumers are savy or have the thought process to yank the e-brake if this happened to them.
  8. Mar 5, 2016 at 7:37 AM
    #228
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Speedytech7 and Tunngavik like this.
  9. Mar 5, 2016 at 7:50 AM
    #229
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Here's a short story. Wife and I use to own a 2001 corolla, she has complained about the brakes doing that several times at slow speed while slowing down. I told her it was her high heels that she wears. I drive the car 99% of the time and the brakes on the car has never done that.
  10. Mar 5, 2016 at 7:58 AM
    #230
    Liquidmantis
    Liquidmantis Well-Known Member
    2016 MGM 4R TEP w/KDSS
    Problem solved! OP should stop driving in high heels.
    ratcityrain, Mr. Torgue and Tunngavik like this.
  11. Mar 5, 2016 at 8:00 AM
    #231
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    I only wear those when I need extra money for truck parts!
    Ch78, ratcityrain, bryanjoh and 10 others like this.
  12. Mar 5, 2016 at 8:41 AM
    #232
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Oh no, another tough guy making meme threats. If your not here to help the OP or to bring some knowledge to the table, then shut your mouth and go back to your second gen forums.
  13. Mar 5, 2016 at 12:54 PM
    #233
    File IFR
    Central MA
    You're confusing a simple and friendly tip of advice to have a continuous membership here on TW vs. a "tough-guy threat"..... dumazz.
  14. Mar 5, 2016 at 1:20 PM
    #234
    File IFR
    Central MA
    Um, it's not. If you recall, I was addressing you, not the OP.
    Your best bet would be to hang out in the Ferd forums..... I believe you'd fit in well there given your history on TW.
    Have a great day :thumbsup:
    Aussiek2000 and Speedytech7 like this.
  15. Mar 5, 2016 at 1:45 PM
    #235
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Just because I'm not a current Tacoma owner doesn't mean I'm not welcome here. I've owned a Tacoma in the past and I'll looking to maybe go back to the midsize platform and Tacoma would be my choice. TW is for owners and enthusiasts.
    Good day to you sir!
  16. Mar 5, 2016 at 2:02 PM
    #236
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    scottalot and File IFR[QUOTED] like this.
  17. Mar 5, 2016 at 2:54 PM
    #237
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    No-tell them to get you a new truck.
  18. Mar 5, 2016 at 10:34 PM
    #238
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    The master cylinder is the pump that produces brake fluid pressure. All the other systems working with the pressure are eithor amplfying this pressure or redirecting the fluid or pressure flow. The peddle should never go to the floor. It may not work in time with your application or the peddle gets extremely hard to apply in a booster failure.
    If it was my truck with this issue I would be asking the dealer to professionaly reverse bleed the brake hydraulic system. If after this is done you feel confident in your braking power go on and live your life. If not then the next step I would ask for is a new master cylinder.
    In order for you to loose complete peddle loss, you have to have a leak in the system or fluid bypass in the master cylinder. A huge air bubble workin its way back through your master cylinder could cause peddle failure. The brake system is still supposed to work partially in a failure. If the front brake fails the rear brakes should still work. Same if the rear brakes fail the front brakes should still work. The offroad model has awsome brakes. Test drive a truck same as yours to see if your brakes are as good as the truck your driving.
  19. Mar 9, 2016 at 1:13 PM
    #239
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Yeah that was my line of thinking also.
    MadisonTaco - can you post some pics of your master cylinder setup? I just want to look at how it's set up in the new trucks.
  20. Mar 10, 2016 at 1:23 PM
    #240
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    I can get you pics tonight. I don't have my truck right now.
