Complete Brake Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MadisonTaco, Mar 3, 2016.
  1. Mar 3, 2016 at 12:07 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I doubt it is the master, since the brakes worked fine after the fact. This is probably electronically related. The brake lines pass through an ABS pump that can cut pressure from the pedal to the brake calipers. The crawl control system also has the ability to modulate the ABS pump.
    I would ask that they replace the ABS pump, Crawl control unit to give me a small piece of mind.
    The master cylinder/brake caliper/brake lines work by hydraulic modulation -- if something was wrong with those items, it would remained in a failed state. The only 'interference' electronic component is the ABS pump and the crawl control system (to my knowledge) Even if the vacuum boost unit failed, it would make the brake pedal very_very stiff and hard to stop, but the brakes would still work.
    This is just my 2 cents. I am not a Toyota tech.
    TRDSport10 likes this.
  2. Mar 3, 2016 at 12:07 PM
    Macwest
    Macwest Well-Known Member
    New York City
    I believe the car has dual systems the front and rear would have to fail . I know if I brake hard on my 2012 FJ( that star control or what ever they call it ) if I hit a bump it feels like I have no brakes for a millisecond and scares the shit out of me. But putting the car in the garage , was it cold and you had that tranny surge? Good luck I know after all that unintentional acceleration that started all the way back with the Audi 5000 and then with the Toyota Prius I don't believe anything was ever found . The Audi was the pedal placement for heal toe driving meaning the gas was close to the brake and people hit the gas. The Prius I think was blamed on car matts. Mac
  3. Mar 3, 2016 at 12:07 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Take the truck to an empty parking lot and try to replicate the problem as best you can. Pretend you're slowly pulling into your garage just as if you were actually doing it, including pulling into your driveway or whatever you did when it happened.
  4. Mar 3, 2016 at 12:08 PM
    Tucktuck8
    Tucktuck8 Well-Known Member
    2016 White DCLB
    well... that's terrifying
  5. Mar 3, 2016 at 12:14 PM
    MadisonTaco
    MadisonTaco [OP] Well-Known Member
    Madison,WI
    2016 TRD Off-Road DCSB
    Softopper Roof Rack
    I saw that post if it is the same one I am thinking of. He said his brakes were locking up causing him to spin out.
  6. Mar 3, 2016 at 12:17 PM
    Tucktuck8
    2016 White DCLB
    Was this an off road as well?
  7. Mar 3, 2016 at 12:18 PM
    nh_yota
    Jeff
    Portsmouth, NH
    Yes and if it was the modulation then the pedal would remain firm and not go to the floor.
  8. Mar 3, 2016 at 12:20 PM
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    The engine revved slightly which is normal while I pull into the garage working the brake to get close enough to the work bench so the door will close. I am ready for that. This was seconds that I didn't have brakes. I had both feet with the paddle to the floor. There was no two footing the gas and brake. I had the peddle down the whole time while I grabbed the parking brake and shifted into park. The brakes came back after that and felt like nothing ever happened.
  9. Mar 3, 2016 at 12:21 PM
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Not sure. I "think" so
  10. Mar 3, 2016 at 12:25 PM
    stan23
    stan
    Santa Clara, CA
    OK, not to pry. But did the brake pedal actually lose all pressure and hit the floor?
    I reallize hitting the brake pedal and not having the vehicle stop is terrifying, but did the pedal really lose all pressure?
    I only ask because in modern brake systems, that seems virtually impossible to happen. When you press the brakes is the hydraulic fluid gets passed through the ABS pump, then directly to the calipers. If there was a malfunction on the ABS pump, the fluid would still need to go somewhere--the pedal would most likely be stiff, or you'd have a pool of brake fluid in your garage floor. Like someone mentioned, there are backup circuits. If there are no leaks in the system, the fluid HAS to go somewhere for the pedal to just drop to the floor like that.
  11. Mar 3, 2016 at 12:26 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    That guys last stated that he thought his truck was wrecked and repaired by the dealership before he bought it. He hasn't been back since then
  12. Mar 3, 2016 at 12:27 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    I would be getting rid of that thing in a heartbeat. no way no how would I get behind the wheel of something that doesn't brake when I push the brakes. that's just absurdly scary.:goingcrazy:
  13. Mar 3, 2016 at 12:27 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Was the truck still idling after you came to a stop?
  14. Mar 3, 2016 at 12:29 PM
    stan23
    stan
    Santa Clara, CA
    Let's not mix these two threads and clump them together. That dude's post was strange, and the behavior was completely different. To be honest, his thread reeks of buyer's remorse and using any leverage he can get to have Toyota take the truck back.
  15. Mar 3, 2016 at 12:31 PM
    #35
    Tucktuck8
    2016 White DCLB
    Big bubble in the hydraulic lines?
  16. Mar 3, 2016 at 12:35 PM
    #36
    Z50king
    Eric
    Southern California
    Stock and loving it
    Somebody asked about that so I shared the most recent info on that situation
  17. Mar 3, 2016 at 12:39 PM
    #37
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Yes it loss all pressure. It was not ABS modulation. I agree that it should be impossible but I have not sat down to look how the brake system works with the crawl control. The peddle was bottomed out. Didn't think it could have that much travel. I have been racking my brain, replaying it over and over. Trying to think through a normall braking system and how this could possibly happen. I love my truck and the 2016s.
    As for prying you are all good. I would be questioning this as well. I do have a general under standing of brake systems. I used to get to play with and work on a Prolite and a PRO2 in the Torc series until the Team owner and I had a falling out. New job doesn't give me enough vacation to join another team even through I still get the phone calls from time to time.
  18. Mar 3, 2016 at 12:40 PM
    #38
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Engine never died or stalled.
  19. Mar 3, 2016 at 12:41 PM
    #39
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    Possible but if there was that much air trapped in the system I would think the fluid would be low.
  20. Mar 3, 2016 at 12:41 PM
    #40
    Slipstream87
    Slipstream87 Well-Known Member
    Andrew
    2016 DCSB TRD Sport 4X4
    5100's w/ 285 KO2's, AFE CAI, MBRP Catback, BAMF Grill, remote start, oemaudioplus setup, sound deadened
    did you repeatedly try and mash the brake or just have time to mash down once and freak out before pulling the e brake?
