complete instrument cluster power loss
Discussion in '1st Gen. Tacomas (1995-2004)' started by FarNorCalRiz, May 15, 2014.
  1. May 15, 2014 at 11:58 PM
    FarNorCalRiz
    FarNorCalRiz [OP] New Member
    Shasta county, Ca
    1997 3.4 tacoma 4x4 manual trans
    Icon 2.5 shocks in front
    I have a 1997 taco 3.4 and have complete power loss to my instrument cluster & clutch start cancel button. Also engine dies when the light are turned on, I thought it was the alternator so I replaced it and that wasn't the problem. Any ideas to help would be appreciated
  2. May 16, 2014 at 12:20 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I would look for a short in the light that makes the engine die.
  3. May 16, 2014 at 8:41 AM
    FarNorCalRiz
    Shasta county, Ca
    The truck dies even if the lights are off it will start then idles for about a minute then slowly starts to die, could I be a bad ecu?
  4. May 16, 2014 at 10:08 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Could be bad fuse under hood? Might go to technical chat thread and ask also. Kinda sounds like a short somewhere. Bamatoy might be the man to ask. He has lots of experience and good advice for sure.
  5. May 18, 2014 at 12:41 AM
    FarNorCalRiz
    Shasta county, Ca
    It was a bad fuse, I used a tester n chased it down thanks fellas
