Complete lift kits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by htan00, Mar 16, 2016.
  1. Mar 16, 2016 at 9:46 PM
    htan00
    htan00 [OP] Well-Known Member
    Bay Area CA
    2016 Tacoma TRD Sport DCSB 4x4
    Hi everyone. I'm new to all this lift kit stuff. I want to lift my 2016 dcsb Tacoma about 2-3 inches. I would like to keep the ride as close to stock as possible. I'm doing it because of the looks. I'm not doing any off roading or anything. I also want to know if I do this 2-3 in lift, what are the biggest tires I can run without rubbing. What brand lift kit should I get and about how much will it run me? Thanks in advance for any info!
  2. Mar 16, 2016 at 9:57 PM
    FarmBoyTaco
    FarmBoyTaco Work Hard, Stay Humble
    Josh
    California
    '12 TRD Off-Road DCSB MGM
    Someone is going to come in here and say "use the search function" because honestly everyone of your questions can be answered that way.
    If you lift max 3", you may be able to squeeze in 33s because you will not be off-roading, but you may get some rubbing when turning the steering wheel completely.
    Once you lift, nothing will be as close to stock. I don't know how it rides, but go an see if you can get the TRD Pro suspension from a dealer or website. That kit was made for the tacoma, or you can get Bilstein 6112 kit from Headstrong Off-Road which is like the TRD Pro suspension. It can be anywhere from $800-$1400 depending on what you get.
    Any lift kit will have good and bad reviews. Just know that once you go over 2" you made need new UCAs, that's another $400 at least.
  3. Mar 16, 2016 at 9:59 PM
    FarmBoyTaco
    Josh
    California
    There's a whole Tacoma world section on suspensions. Look in there for more info.
  4. Mar 16, 2016 at 10:07 PM
    htan00
    Bay Area CA
    Thanks for the info
