Complete list of tools for these?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natenite, Feb 10, 2025.
  1. Feb 10, 2025 at 1:06 PM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Has anyone ever made a list of what tools are actually needed to do basic repairs on the first gens when on trail? Socket sizes and wrenches etc. I carry some tools around but I’m thinking some of it is likely completely unnecessary and overkill. If I could lighten my load and clutter with the tools I carry that would be a big plus for me.
  2. Feb 10, 2025 at 1:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    When you know what's going to break then you'll know what tools you'll need. ;)
    JustADriver likes this.
  3. Feb 10, 2025 at 1:38 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Yea, no Kidding. I’ve purchased a lot of tools after something goes wrong
  4. Feb 10, 2025 at 2:09 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Whatever tools you need to replace whatever parts you are bringing as trail spares
    If you have the tools, but not a replacement part, the tools are pretty pointless
    Basics for me; 10-24mm 1/2" deep impact sockets (theres a few in there you can skip), 1/2" ratchet, impact wrench (remember to recharge the battery), pliers, vice grips, crescent wrench
    If you have a spare CV, make sure you have an axle nut socket. Make sure its the right size too, I've had issues with aftermarket CVs using a different axle nut size than oem.
    Other randoms, ratchet straps, c clamps, zip ties, tire plug kit, tub of grease and duct tape.
    Natenite[OP] likes this.
  5. Feb 10, 2025 at 2:57 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    I would add an assortment of hoses and hose clamps Also a tube of jb weld.
  6. Feb 10, 2025 at 8:27 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    @turbodb (Dan) made a very thorough tool list, indexed by usage/fastener: https://www.tacomaworld.com/threads...ckets-and-wrenches-for-1st-gen-tacoma.481748/
    Some things will vary a bit depending on year and aftermarket equipment, but this will get you close.
    I built a tool kit based on that list and I use it whenever I go to the junkyard or when working on the truck at home. Wrenching on your truck at home--even if it's just basic maintenance work--is the best way to understand what tools you need and what repairs you're capable of. You'll learn a lot from replacing your ball joints, belts, fluids, brake pads, etc--and you'll have the peace of mind knowing that your truck is in good shape and less likely to need a trail repair in the first place.
    If you want to go even deeper, Dan also regularly catalogs everything he carries in his truck. Again, your truck might vary, and some of the equipment needed will vary with the terrain/climate you're out in, but it's a well-thought-out place to start: https://adventuretaco.com/tag/gear-roundup/
    dankthetank and turbodb like this.
