complete noob to alignment and some info on 5100s that were just installed
Discussion in 'Suspension' started by StreetTaco4Me, Jun 17, 2013.
  1. Jun 17, 2013 at 12:27 PM
    StreetTaco4Me
    StreetTaco4Me [OP] Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    I put 5100s on this weekend and despite tightening the alignment after loosening it to get the 5100s on to their original markings prior to lift I was left with a severe "V" to my front wheels...
    I set the billies at 1.75 but am sitting at 2" lift right now as the truck has 600 miles on it and the spings and shocks are settling
    so I took it in this morning to firestone got the lifetime alignment for $170
    I asked them if the could do it to 0/0/2.4 the guy said they would look at it and the specs and try to get it close
    i know the #s are not what I asked so are they close or should I just drive it for the week and let things settle out or should I take it back in soone as the front tires are still slightly "V"ed
    I am attaching the spec sheet here...
    edit: just went back in...got the alignment re-done but they made the caster even more out of spec...what the heck is going on here?
    he told me they were able to adjust the toe...but when they do that it is going to affect the caster...with the 2nd alignment the caster went even more negative...how is that possible?
    I am attaching the 2nd alignment #s as well can someone with knowledge on this please get back to me on what to tell these guys to get it done properly because this is ridiculous...I have the option of going to another firestone nearby I have 6 within 10 miles of me so would 1 of 6 at least be able to do this correctly?
  2. Jun 17, 2013 at 12:30 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Wow... was the tech blind, deaf and dumb or what?? That's not even with spec for stock height, let alone what you specifically asked them for. Take it back and make them do it right this time.
  3. Jun 17, 2013 at 12:34 PM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Take it the hell back and tell them to try again.
  4. Jun 17, 2013 at 12:43 PM
    bwanamukubwa
    bwanamukubwa Well-Known Member
    Tennessee
    I'm new to all this so could you please explain what 0/0/2.4 is and why those numbers?
  5. Jun 17, 2013 at 12:46 PM
    Pugga
    Massachusetts
    F-150 Mod
    0 camber, 0 toe and 2.4 caster
  6. Jun 17, 2013 at 12:55 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Factory/Firestone 2012 Spec Range(from OPs printout):
    Camber -0.1, 1.4
    Toe 0.03, 0.13
    Caster 1.2, 2.7
  7. Jun 17, 2013 at 12:58 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    sorry sandman...what does the info you are noting mean? that there spec range is not even right?
    is the 0/0/2.4 what I should be asking for?
    thanks everyone I am going to take it back in about an hour...
  8. Jun 17, 2013 at 1:25 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You asked for the right thing. Toe and camber were both OK... but the caster needs to be a minimum of 1.3 positive to have decent highway drivability.
  9. Jun 17, 2013 at 4:55 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    0/0/2.4 is within the ranges I posted so it's fine. Anything in the range will be ok.
  10. Jun 17, 2013 at 4:58 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    After the second attempt I would go to the other store. Share your experience with them and hopefully they'll get it right. If they do get it right file a complaint against the first store.
  11. Jun 17, 2013 at 6:11 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    OK I will take it to a different one tomorrow...
  12. Jun 17, 2013 at 6:17 PM
    Pugga
    Massachusetts
    F-150 Mod
    I wouldn't just accept anything with that range. Toe should be 0 or damn close to it, same with camber. Caster needs to be at least 1.5, should be over 2.0. It would be acceptable, as a last resort, to sacrifice some camber to get more caster adjustment but the tech should talk to the customer about that before doing it. Just me $0.02 anyway...
  13. Jun 17, 2013 at 6:25 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    Is there any reason why they should not be able to get the numbers right? I only have 1.75 lift on there.
    Also should both sides be able to match exactly? Do they align independently? Or together?
    Pugga you seem to know your stuff...why have they not been able to get it right with 2 chances? Any thoughts?
  14. Jun 17, 2013 at 6:28 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Maybe your alignment cams are seized
  15. Jun 17, 2013 at 6:30 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    Truck is only 3 weeks old...could they be seized already
  16. Jun 17, 2013 at 6:34 PM
    OZ-T
    Peter North
    British Columbia
    My bad , didn't see the year of your truck
    Your alignment tech is a tard then
  17. Jun 17, 2013 at 6:45 PM
    Pugga
    Massachusetts
    F-150 Mod
    It's likely just laziness. Most shops just set the toe and if the rest is 'in spec' they don't mess with it. They should be able to get the side to side numbers pretty close, they won't be exact down to the hundredth of a degree but they should get close. Different numbers side to side can make the truck 'pull' depending on how large the difference is. Toe and camber affect tire wear so if they're not correct, they can eat up your tires. Caster influences drivability. A higher caster number will make it more stable at speed, a low caster number can make the truck wander at speed.
    FWIW, I have about the same amount of lift as you and I wasn't able to get to 2.4 degrees. I got 0 toe, 0 camber and the techs were only able to get me to around 2 degrees of caster. The techs worked on it for almost 2 hours. I gave the instruction to make sure toe and camber were 0, they were non-negotiable, then max out the caster adjustment.
    Here's your short answer :laugh:
  18. Jun 17, 2013 at 6:53 PM
    Hughesc99
    Hughesc99 Well-Known Member
    Derby, KS
  19. Jun 17, 2013 at 7:12 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    Awesome thanks everyone (especially pugga) I will insist on the closest to 0 for toe and camber and ask them to max the caster based on those 2 specs and hope to get close to 2.4...at least if they could get it to the low on spec I would be hopeful but seems it's not even close...
    with regard to these numbers so long as my toe and camber are good...as I am understanding this the caster is more of a feel thing?
    So if my caster numbers do not meet spec for some reason but it drives fine is that what really matters or is there risk to the components of the suspension is the caster does not meet spec as well?
  20. Jun 17, 2013 at 8:18 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Lol yea. In this case they could at least get it close to the low side..
