Complete Tacoma Key fob amatuer....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rbdudeman, Oct 17, 2024.
  1. Oct 17, 2024 at 4:57 PM
    rbdudeman
    rbdudeman [OP] Well-Known Member
    My wife's 2014 Honda will not lock when the key fob is in the car and it's manually locked. The 2024 Tacoma locks with the key fob in the truck. I have a spare key in a lock box for this situation but was wondering if this is normal or did I get the 'special' one?
  2. Oct 17, 2024 at 5:27 PM
    Big Cole
    Big Cole Well-Known Member
    Considering asking this question in the 4th Gen forum.
    auskip07, 23MGM and musicisevil like this.
  3. Oct 17, 2024 at 6:26 PM
    spp
    spp OC, Kalifornia
    OC California
    Push button start?
  4. Oct 20, 2024 at 5:21 AM
    rbdudeman
    Yes...push button start...it's a third gen...is this a standard non-feature of the 3rd gen Tacoma's? If the fob is in the truck, it will lock if the door lock is manually pressed at the driver door? Or is there a problem with my fob/ tech settings?
  5. Oct 20, 2024 at 5:34 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If your truck is a 2024 it’s a 4th gen. What does the owners manual say about FOB and lock performance based on location?
    musicisevil and ace_10 like this.
  6. Oct 20, 2024 at 5:37 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    :gossip:
    musicisevil likes this.
  7. Oct 20, 2024 at 1:23 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    why are you using the internal lock button? closing the door and pressing the 'nub' area on the door handle will not lock the truck with the fob in the truck, and it will angrily beep at you.
  8. Oct 20, 2024 at 5:56 PM
    spp
    spp OC, Kalifornia
    OC California
    You can put a fob to sleep and lock it in the car by holding the lock button on the fob and pressing the unlock twice. We do this on our 2023 Tacoma and 2024 Lexus to save batteries and allows my wife to lock her purse in the cars when needed.
  9. Oct 23, 2024 at 5:50 AM
    rbdudeman
    So to your response Soundman98, if the fob is in the truck, and I manually lock the truck at the door, the truck locks and there is no warning. My question is this normal. Per your experience, sounds like I got the special one that locks. Sound about right?
  10. Oct 23, 2024 at 6:17 AM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    Does it stay locked when you close the locked door? Better question, can't you just grab the door handle and open the door since the fob is in the truck?
  11. Oct 23, 2024 at 8:08 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I’d have to test it, but going just off my poor memory; I believe I can leave my fob in the vehicle and press the lock button inside the door without any beeps or anything. However if I close the locked door, it will unlock and yell at me.
    Again I could be completely wrong. I’ll have to try after work
  12. Oct 23, 2024 at 9:18 AM
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    That is exactly how mine operates.
    Barsoom and musicisevil[QUOTED] like this.
  13. Oct 23, 2024 at 6:44 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Does manually lock mean you use the key to lock the door?
    gudujarlson and musicisevil like this.
  14. Oct 23, 2024 at 11:00 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve not yet tried to lock my keys in the truck, so I cannot immediately answer your question. How do you do it? Is it possible to use the switch on the inside of the door (which I never use) before you close it? I suppose if I had two keys with me, I could leave one inside and use the other to lock the door. Can you explain the steps?
    I have not heard anything ask this question before.
    CAVEAT: I don’t have push button start
  15. Oct 24, 2024 at 6:36 AM
    rbdudeman
    Apparently I'm the only re-?-d that's ever locked my truck with the fob in it. And yes, to answer one of the posters, I would use the fob to lock / unlock the truck like I do on every other car I've owned / used but the fob only works half the time. So I stopped using it cause it is'nt reliable.
  16. Nov 4, 2024 at 4:23 PM
    HuskyTaco
    HuskyTaco Well-Known Member
    No, you're the 2nd. I always turn my fob off, because I'm weird. Turned it off, left it in the cup holder headed to the gym. I come out can see it plain as day. The wife did a drive by to unlock it.
  17. Nov 5, 2024 at 6:52 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I have a question for whoever can answer. with auto truck start.
    If I leave the fob in the cab and use my spare one in the house. Will it start my truck with fob in cab. Just wondering cause I have not tried it yet.
  18. Nov 5, 2024 at 2:49 PM
    shark56
    shark56 Well-Known Member
    Yes. I have done that several times. The truck will still shut off after you open the door.
    O.P. on mine when I leave my spare fob in the truck, the only way I can lock it is by pushing "lock" on my other fob.
  19. Nov 5, 2024 at 4:19 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    I have not tried on '24 models.
    But on 3rd gen Tacomas, so far I know:
    You put fob in the truck and lock via lock button on armrest but it will unlock because of security/safety feature.
    If you want to leave fob in the truck but you want to lock the truck with fob inside, then use the key to manually lock it.
    Yes you can start the truck with fob but it will be shut off if you open the door because it's a security feature that thief can not steal your truck to take off. Plus it has the timer which it can be turn off about 15 mins. If you don't want this, then you need to get in the truck to start it up then get out of the truck so you close it then lock it manually, that way, it will not activate the timer.
