Completely dead electrical.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wild Card, Mar 4, 2012.
  1. Mar 4, 2012 at 12:00 PM
    Wild Card
    Wild Card [OP] Truck yeah!
    Doug
    Portland, MI
    02 TRD SR5 4x4 V6 Xtra Cab 5spd
    6" Deckplate. Trimmed TB gasket. Grey wire. Disable DRL's.
    I went to start my Tacoma after coming out of the store today. Turn the ignition on, push in the clutch, go to crank the engine. The starter engages, and immediatelly ALL electrical in my truck is dead. Nothing. The only hint of life is a weak, weird chime when the key is in the ignition with the door open.
    Nothing comes to life on the dash, no lights, no horn, no power locks even. It would seem to me that I blew a fuse somewhere, but I cannot find anything that looks like a main fuse. I saw a 30AMP in the upper right of my interior fuse-block, all other fuses check out clean. I could not access the 30amp, as it needs pliers to get to, and I did not have any on me.
    So, luckily I was only about 2 miles from home and walked. I'll gather up some pliers and my multi-meter and try to figure this out.
    If you guys have any ideas or suggestions, let me know.
  2. Mar 4, 2012 at 12:04 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I believe there is a 100 or 120 amp main fuse somewhere in there. My brothers 01 did the same thing a few weeks back after he crossed his jumper cables :eek: It was a $5 fix, luckily.
  3. Mar 4, 2012 at 12:07 PM
    Wild Card
    Doug
    Portland, MI
    That's kind of what I suspect. Why do cars break on cold, cold days when you're sick! :confused: Can never happen on a nice week-day, when you have the day off, the sun is shining, and auto-parts stores are open....
  4. Mar 4, 2012 at 12:13 PM
    pwerrec
    pwerrec Active Member
    Curtis
    Cedar City
    01 Tacoma TRD
    Lift, 33's
    What ^ that guy said. You could start by grabbing the cables and if you can spin the clamp at all on the battery, it may be your problem.
    If they twist, spin them back and forth a little. Your truck should start and you can clean and tighten the clamps at home.
  5. Mar 4, 2012 at 12:15 PM
    1980 Well-Known Member
    The Dust Bowl
    If you haven't replaced a battery in five or six years you can also have a plate corrode in two and render it nearly dead instantly. I had this happen with my '87 once. However, I walked to a parts store then pushed the new battery back to the truck in a shopping cart (I took it back to the store it belonged to once I had the truck running again).
  6. Mar 4, 2012 at 12:18 PM
    Wild Card
    Doug
    Portland, MI
    Off to see what's wrong...wish me luck.
  7. Mar 4, 2012 at 12:20 PM
    ffirg
    mike
    Anchorage, Alaska
    Yep. Always start with the easiest stuff first.
  8. Mar 4, 2012 at 12:22 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Hope, it's not the Alternator that went out
  9. Mar 4, 2012 at 12:34 PM
    Wild Card
    Doug
    Portland, MI
    Ah ha! I'm back. It was the easy crap. Took the positive terminal off of the battery, and, lo-and-behold, horrible corrosion. Terminal was not loose, but the corrosion had completely opened the circuit. Cleaned everything, reseated the connection, and, presto, she's fine.
    Thanks for the help everyone!
  10. Mar 4, 2012 at 12:46 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    LOL...true.
