Completely dissappointed with the lack of car seat attachments.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tintala, Jul 18, 2014.
  1. Jul 18, 2014 at 6:56 PM
    tintala
    tintala [OP] Active Member
    09 Tacoma Access 4 cyl, 5 spd
    The other day I was driving home with my 8 mo old in the car seat and the seat belt let the attachment and seat slide over to the middle . The seat belt appears to work, but it won't hold a cat seat. It's one reason I just traded my f150 for this taco. Very dissappointed in the lack of attachments for car seat in this truck.
    Anyone have suggestions.
    09 access cab.
  2. Jul 18, 2014 at 7:03 PM
    ainokea
    ainokea Well-Known Member
    Hawai'i/ Washington
    13' Tacoma DCLB
    35's MTRs, King shocks, all pro rear, pelfreybilt bumper, rigid lights
    trade it for a double cab?
  3. Jul 18, 2014 at 7:04 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    get a mini van?
  4. Jul 18, 2014 at 7:07 PM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Are you in an access cab?
    My truck handles a car seat fine but there are a couple things you need to do in order to get it right. If it is an access cab then there is a piece of plastic under the headrest in the back seat that pulls off and you can anchor there.
    Also, with all car seats it is just good practice to attach the seat with the regular seat belt and pull the belt all the way out and let it pull back in.. If you pull it all the way out it will lock the seatbelt from letting out any slack. Then just yank every bit of the slack you can out of the seat belt until it is nice and snug.
    I hope that helps
  5. Jul 18, 2014 at 7:09 PM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Oh yea and one more thing. I didn't know this at all but when my daughter was first born my wife (as most new mother's are usually paranoid about every little thing) had someone help her install the car seat that was trained to do that. He told us that the anchor points, while a novel idea and not really a bad idea, are not near as secure as the seat belts simply because they are not reinforced and engineered as well as seat belts. So the anchor points are merely for "added" safety and not designed to be used alone as the anchor.
    Again, Hope this helps
  6. Jul 18, 2014 at 7:47 PM
    tintala
    Why would I want a mini van when toyota makes a truck :confused::eek:
    You get a mini van .:D
    Dangerdave I use the seat belt and it slips thru the attachment. The anchors are not an option with this car seat which is brand new. A Chicco .. I'm not sure how I can attach it, if so it's not obvious to me. I appreciate your help.
    Ainokea- because I can't afford one, there are NONE in my area , and especially no 5 spd in my area, everyone wants one so no availability and I need the bed space for "things".
  7. Jul 18, 2014 at 7:51 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    correct
    incorrect
    LATCH is equally as safe as seat belts, and the engineering behind it is very specific and well done. They are designed to be used alone, and NOT with a seat belt at all.
  8. Jul 18, 2014 at 7:56 PM
    JimBeam
    JB
    2015 Tundra
    OP, Contact your local police or fire department or visit the website to find a CPS Certified installer in your area. They can help show you the best way to secure the seat properly
    http://cert.safekids.org/get-car-seat-checked
  9. Jul 18, 2014 at 7:58 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    You must be doing something wrong because my car seat is rock solid. Like dangerdave said, make sure you pull the seat belt all of the way out then slowly let it back in until you hear faint clicks, then secure the car seat.
  10. Jul 18, 2014 at 7:58 PM
    mutilatedjak
    WA
    +1
  11. Jul 18, 2014 at 8:18 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    While this is very true information is used correctly, the latch system has a harness weight limit of roughly 40 lbs depending on manufacturer. So, while Dangerdave's post on the issue contains some truth, there is no reason not to use such a wonderful system so long as it is used within it's designed limits. I have found it far easier to secure a car seat properly using the latch system, using a seatbelt can be downright frustrating depending on the vehicle.
    I certainly second your suggestion to have a qualified professional asses the installation and correct any issues according to their recommendation. I can proudly say that my interpretation of our local regulations and the seat manufacturer's instructions proved correct after hours of head scratching. I must say the peace of mind I had when my wife had my installation inspected was well worth the few minutes it took for the inspection.
  12. Jul 18, 2014 at 8:24 PM
    JimBeam
    JB
    2015 Tundra
    good point. there is a weight limit for both LATCH and each seat
  13. Jul 18, 2014 at 8:44 PM
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    I agree. More is better. They need to add anchor points at the passenger rear. I have a 2011 access cab and the anchors are only on the driver side rear passenger and shotgun. Who the hell is going to use the car seat directly behind the driver seat. You have to scoot all the way forward and cram.
  14. Jul 18, 2014 at 9:03 PM
    JimBeam
    JB
    2015 Tundra
    are you sure? Every vehicle manufactured after 2002 has to have LATCH points in a corresponding number to the number of designated seating positions for adults
    3 rear seats requires 2 lower anchor and 1 top tether or 3 lower anchers
    2 rear seats requires 2 lower anchors
    google FMVSS 225 for more on federal guidelines for vehicle manufacturers and child seats
  15. Jul 18, 2014 at 9:12 PM
    JimBeam
    JB
    2015 Tundra
    i stand corrected
    according to the owners manual...the 2011 AC does only have LATCH behind the driver and front passenger seats
    strange
  16. Jul 19, 2014 at 6:06 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    I think yall misunderstood what I was trying to say. LATCH is a good addition to the safety belt but was never intended to replace attaching the seat. It was meant for support.
    Now, let me say I could be wrong. I am solely going on what the child seat professional taught my wife when installing the seat the first time.
  17. Jul 19, 2014 at 6:30 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    So you traded in the f150 for a tacoma thinking it had better seat belt latches? Didn't check?
  18. Jul 19, 2014 at 6:53 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    I was a certified safety seat installer right out of the Fire Academy...yes....they actually sent NHTSA to certify all 30 of us. *eyeroll*
    Anchors or LATCH are just as safe as safety belts. I have to kids, a 6 year old and a 15 month. I personally use the safety belts for all of our car seat needs. You never want to use both.
  19. Jul 19, 2014 at 7:02 AM
    medic2230
    Murph
    Bama! Roll Tide
    When attaching a car seat in the back on the passenger side you use the flip up tray below the seat if they are still on the 2nd gens. Put the car seat in and use your knee to compress it into the seat. Pull the seatbelt all the way out and run it through the anchor slot behind the seat. Latch the seatbelt and then let it pull all the way back in. Pull on the seatbelt to compress the car seat all the way down while keeping your knee on it. When you pull the seatbelt all the way out like that it locks and keeps it from being able to pull out until the seatbelt is released and back into it's storage position. Hope this helps.
  20. Jul 19, 2014 at 7:03 AM
    Blackpearl2007
    Blackpearl2007 Active Member
    Southeast
    2013 4x4 TRD Off Road
    Thanks for this. Curious, why would you not use both together?
