complicated situation, need help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by edgar1hurtado, Nov 26, 2011.
  1. Nov 26, 2011 at 10:42 AM
    edgar1hurtado
    edgar1hurtado [OP] Member
    Edgar
    Az
    '00 Tacoma TRD 4x4
    so one day i was offroading in my 2000 tacoma and everything was fine. afterwards i drove to the gas station to fill up and when i was finished i tried to drive off, but the truck wouldnt start. what was wierd was that all my electronics were off. i opened the hood and after wiggleing the neg battery cable my electronics came back on. i closed the hood and went to start it but when i turned the key the electronics went out again. so i just kept wiggling the cable trying to start it for about 7-10 times until it started. after it started i turned it back off then restarted it and it worked just fine, and still works fine to this day. WTF HAPPENED???
  2. Nov 26, 2011 at 10:47 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    was there a lot of corrosion on the battery terminals?
    did it look like a CHA CHA CHIA Pet?:D
  3. Nov 26, 2011 at 11:18 AM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    x2 clean your battery terminals
  4. Nov 26, 2011 at 11:25 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Mines did the same thing...I just clean the terminals and added another ground from the battery....never did it again
  5. Nov 26, 2011 at 11:34 AM
    bhh2000
    bhh2000 Well-Known Member
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    Get some of that battery terminal cleaner and a wire brush and clean every ground that's easy to get to then tighten the hell out of them. You should be fine after that.
    I never had the starting problem
    But I've had fading electrical systems before and it was pissing me off untill I did the above now it all works perfect.
  6. Nov 26, 2011 at 11:37 AM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    quick temp fix, is you can get a coke, if you dont have immediate access to battery cleaner, u just gotta spray it later on with some water to wash it away, saved my butt one time
  7. Nov 27, 2011 at 5:03 PM
    edgar1hurtado
    Edgar
    Az
    '00 Tacoma TRD 4x4
    fixed it :) the cable was just loose. thanks everybody
  8. Nov 27, 2011 at 5:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    This was my guess...Either the lead or a ground. Anytime there is a electrical issue...I start with the battery and the grounds...
    Glad it worked out for you man!!
