component speakers in the back of an access cab
Discussion in 'Audio & Video' started by 07TacoRidah, Dec 28, 2009.
  1. Dec 28, 2009 at 7:23 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    I was wondering if anyone has tried to put in components speakers (not ones in which you can place the tweet in front of the mid speaker or if the grille has a slot for the tweeters like how MB Quartz look) in the back of an access cab. Will it fit if I surface mount the tweeter on the grille? Is there another way to install it? I want to get the best quality from both speakers but I am a little puzzled as to how to go about putting them in. I might be getting these sometime in Jan.
    http://www.onlinecarstereo.com/CarAudio/p_21520_Cadence_FXC-6Ki.aspx
    anyone do that instead of using the 2 way speakers or what have you?
  2. Dec 28, 2009 at 7:56 PM
    07TacoRidah
    I mean the grille supplied from the component speakers. Not the panel one.
  3. Dec 30, 2009 at 6:46 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I have full components in my 02 (see sig). Some argue front staging is best meaning a nice set of components up front powered by an external amp and leave the rear stock, unplugged or filled with some upgraded coax speakers. Its all personal preference.
  4. Jan 1, 2010 at 10:39 AM
    07TacoRidah
    I didn't want to have to do that. for the price of coax's that will keep up with my comps up front, I could have just gotten another of the same set of comps. imo. reason why I am trying to do comps both front and back.
