Composite bed question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bagster, Jun 20, 2010.
  1. Jun 20, 2010 at 12:19 PM
    bagster
    bagster [OP] Well-Known Member
    What are the advantages to a composite bed beside not rusting? Are there
    any disadvantages?
  2. Jun 20, 2010 at 12:28 PM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    No need for Rhino Liner LOL
  3. Jun 20, 2010 at 12:32 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Adv:
    -Will not rust
    -Lighter weight (better MPG)
    -Does not dent/deform like steel
    -No need to spend extra money on rhino/line-x
    DisAdv:
    -Lighter ass end will cut you loose quicker in rain or snow
    -more vulnerable to repetitive scoring than steel (i.e. something sharp sliding back and forth on it with pressure applied)
    All in all, I feel the composite bed makes more sense from a design standpoint.
  4. Jun 20, 2010 at 12:32 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Tougher...you can hit it really, really hard and it doesn't dent. How much till it breaks though? don't know.
    But it does seem to have a problem with rubbing: people have reported gouges where metal things have rubbed when being driven around.
    I remember reading where one person had a crack...but how that can form and propagate I've no idea since composite is supposed to have excellent resistance to crack propogation.
  5. Jun 20, 2010 at 12:35 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Not only is it lighter, but the composite material is also stronger than steel. It does however scratch, but a good bed mat (i'd recommend one to anybody who hauls anything in the bed) will solve that problem and keep your cargo secure and free of any sliding action.
  6. Jun 20, 2010 at 2:39 PM
    T0y0ta05
    T0y0ta05 Well-Known Member
    Pennsylvania
    05 Silver Sport DC Tacoma
    Bone stock other than new floor mats.
    I 2nd a bed mat as well since things do slide around. On the other hand, my brother's Rhino sprayed bed doesn't allow things to slide around so I guess that would be another disadvantage of the composite bed. I also concur that it does scratch/gouge. I had a aerator in the back of my truck that slide around and gouged/scratched the bed a bit. It wasn't horrible, but enought to notice.
  7. Jun 20, 2010 at 3:17 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    how much weight can u put in our beds before bad things happen to them?
  8. Jun 20, 2010 at 5:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you looked in your owners manual - there are limits to what you are allowed (technically) to carry in the bed (load capacity).
    Those limits have nothing to do with the composite bed. Those limits are there because of the axle/suspension strength (so to speak) and probably a bunch of other things I'm not mentioning.
  9. Jun 20, 2010 at 8:24 PM
    Wolfman
    Wolfman Well-Known Member
    Paradise, TX
    2010 PreRunner SR5
    Another advantage is that I don't have to fork over several hundred dollars to have a spray in bed liner installed.
    Disadvantages might be that stuff does seem to slide around more.
  10. Jun 20, 2010 at 8:30 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The OEM bed mat is the best $50-$90 you will spend if you haul anything in the bed .
  11. Jun 20, 2010 at 8:38 PM
    Wolfman
    Paradise, TX
    2010 PreRunner SR5
    All I've hauled in the bed so far is hay, and that stuff doesn't seem to want to move when I throw it into the bed. :D 100 pound bales fit almost glove tight.
  12. Jun 20, 2010 at 8:39 PM
    OZ-T
    Peter North
    British Columbia
    Yeee Haaawww :D
  13. Jun 20, 2010 at 9:51 PM
    Deano
    Deano Member
    Dean
    Iowa
    Sport access cab 4x4
    Cut down an old full size bed mat to fit and seems to be doing ists job. no slipping or denting or scratches. best of all i had it and not sure what to do with it.
  14. Jun 20, 2010 at 10:08 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Not to be a smart a**, but can you drill through that stuff without it cracking over time? Noticed that someone said its stonger than steel, but I've heard of metal objects rubbing a hole in the bed. I'm not sure about the newer Toys if they have the rear leaf spring problem? How do you get that problem with such a light bed? I have an older Toy with a steel bed in it, with my tire mounted in the back, and a lightbar mounted back there too. Can you do that with the new composite beds. Like I said not trying to sound like a smart a** just kinda curious about the stability of it.
  15. Jun 20, 2010 at 11:11 PM
    Janster
    Jandy
    Lancaster, PA
    How do the leaf springs have anything to do with the bed? The leaf springs are attached to the underside of the frame and the axle. The bed doesn't even come in contact with the leaf springs. The bed is mounted ontop the frame.
    So what exactly are you trying to say?
  16. Jun 21, 2010 at 5:36 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Are you familiar with how the sheet molded composite bed is made? It's like fiberglass and other composites in that it has fibers spread throughout the resin. That makes it highly crack resistant (much better than steel) but I'd back holes with washers or a plate to give a crush-proof grip for the bolt system.
    Like it's been noted: there are pluses and minuses for both steel and composite bed. It's important to understand and take advantage from the pluses, and avoid stupid things that make the minuses a problem to you.
    And yes, there are bed-mounted spare tires and light bar systems for the 2nd gens...I've seen them. I'm sure they have well-designed mounts that are compatible with the SMC bed; you should check them out if you've questions.
  17. Jun 21, 2010 at 12:36 PM
    MajKong
    MajKong Well-Known Member
    Johnny
    Reno, NV
    2008 4X4 Access Cab 4cyl
    Seatbelt Buzzer turned off, Bed Mat, Illuminated 4X4 switch, Intermittent Wipers, Fumoto drain valve, LCE header, fog lights
    X2 My bed mat is the best thing I've purchased so far. And I'm addicted to my Garmin.
