Composite bed strength
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigmooze, Mar 24, 2010.
  1. Mar 24, 2010 at 4:50 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I just installed some extra Toyota D-rings in my bed. I didn't use the bed bolts, just the supplied Torx head bolts and plates with welded nuts. How strong is the composite bed for this application? I plan to use the rings as tie down points for my Honda Rancher ATV. Should be fine eh?
  2. Mar 24, 2010 at 4:51 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    I would not recommend that.
  3. Mar 24, 2010 at 4:52 PM
    AK27
    AK27 Well-Known Member
    x2
  4. Mar 24, 2010 at 4:56 PM
    bigmooze
    Richard
    Belle River, ON
    For those not set on the idea, why not?
  5. Mar 24, 2010 at 4:58 PM
    AK27
    thats a lot of weight to pull on a very small area. unless you have large backer plates its just going to rip right through if the load shifts quickly
    imo anyways
  6. Mar 24, 2010 at 5:00 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    It does not take a genius, but AK27 nailed it.
  7. Mar 24, 2010 at 5:01 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    I did the same thing, not for the same reason. I won't be tieing down anything too heavy. I'm curious to know how the bed would hold up.
  8. Mar 24, 2010 at 5:02 PM
    bigmooze
    Richard
    Belle River, ON
    Ok then I'll used the bed bolts to fasten the two I have for the front set. Thanks.
  9. Mar 24, 2010 at 5:48 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    If you followed the instructions and mounted them correctly, the max. weight capacity for each D-Ring is 440 lbs.
  10. Mar 24, 2010 at 5:59 PM
    bigmooze
    Richard
    Belle River, ON
    Is that rating posted on the Toyota website? No trying to be a dick, I just like somewhere to "see for myself."
    The ones I installed are on the floor of the bed. I'll keep those for smaller loads.
    Now I'm torn between mounting my other set on the walls of the bed (per the Toyota instructions) or on the front bed bolts. I think the bed bolt idea will be the better option, but I would lose the swivel function. No rush, I'll decide by the weekend.
  11. Mar 24, 2010 at 6:00 PM
    AK27
    i think you would be safer to go with the bed bolt method bigmooze. especailly for an atv
  12. Mar 24, 2010 at 6:04 PM
    bigmooze
    Richard
    Belle River, ON
    Yeah I'm thinking just the same. I also plan to run a strap from the rear hitch of the ATV to the rear hitch of the truck to prevent smashing through the rear window.
    With two front bed-bolt-mounted d-rings, the rear hitch strap and straps from each of the rear factory-installed d-rings I would likely be in a good spot for load security. I also have the bed-rail cleats to work with too, though I don't have as much faith in those as the d-rings.
  13. Mar 24, 2010 at 6:06 PM
    AK27
    the bed cleats are only rated at 220lbs.... not sure if i trust that though.
    the other tie down points you plan to use sounds good :)
  14. Mar 24, 2010 at 6:08 PM
    bigmooze
    Richard
    Belle River, ON
    Cool thanks for the reply... you think I can pull some force on the rear factory-installed d-rings?
  15. Mar 24, 2010 at 6:10 PM
    AK27
    i use mine steadily for work and have yanked on them quite a bit. holding down sheets of plywood/drywall/materials. with the 4 d rings on the bed bolts you should be good
    mine are a lil bent up but i was hauling 12ft pressure treated 2x10s and hit a bad bump and rocked everything hard (bounced the load even with it ratchet strapped down)
  16. Mar 24, 2010 at 6:13 PM
    Asgard
  17. Mar 24, 2010 at 6:27 PM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    Anyone throw something heavy in the bed when it's -20F outside? I have not heard of one breaking in the cold yet and I know they sell them way up in Canada.
  18. Mar 25, 2010 at 5:49 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Mine has made some awful noises when throwing firewood back there in the winter time, especially the front section underneath the rear window. I usually take it pretty easy after that. A junk of firewood could go through the front section pretty easy in the cold if you wanted it to. There has been a number of occasions I thought for sure that i had it cracked.
    Where most people are getting cracks are in the two aluminum uprights in the rear on either side of the tailgate. Hairline cracks seem to develop regularly down by the tailgate hinges and begin to slowly spread upwards. Checked mine just now and I also have cracks on both side. Truck is going in tomorrow for a warrantied wheel bearing so we'll have to see what the dealership says on the matter.
  19. Mar 25, 2010 at 6:36 AM
    niit_train
    niit_train Well-Known Member
    WV
    06 Double Cab
    No mods, just extra accessories. Realtree bug shield, vent visors, and a custom Realtree Hunter 4X4 Bully
    I posted this in another thread about an ATV hitting the back glass. I beleive that if you can load it in backwards, that the rear tires will hit the bed rail, therefore not allowing the racks to hit the glass. Worth a try!!!
    NT
  20. Mar 25, 2010 at 9:06 AM
    Asgard
    ^^I've never carried an ATV in my bed but I don't think you should have anything that heavy sliding around in there. I broke my bed transporting a slot machine (about 300 lbs), I was careless and didn't tie it down.
