Comprehensive 5-lug 2nd gen lowering info.
Discussion in 'Street Trucks' started by tcBob, Nov 4, 2012.
  1. Nov 4, 2012 at 8:12 AM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    5 lug base and X-Runner (XR), front suspension.
    -3" (base and XR) DJM upper/lower control arms.
    Fits all base and XR models.
    The lowest price I've found is $410 shipped from Tony (DJM Direct) on X-Runner Underground (XRU).
    They work by moving the all of the mounting points up 3" via replacing upper and lower control arms (UCA and LCA).
    You will need new ball joints or transfer your stock ball joints to this kit.
    I like the MOOG Problem Solver ball joints because they are greaseable.
    __________________________________________________ __________________________________________________
    Adjustable control arms.
    -2.2" (base) or -1.7" (XR) XII coils
    These coils drop the base model 2.2". 1.7" from the coil and factor in .5" from the stock height XR coil.
    Remember these were designed to drop the XR, so you must account for the height different from stock XR coils to stock base model coils.
    They work by shortening the coil and increasing spring rate via replacing the stock coils.
    Pictured: old skool Sittin Sic 1" drop coils (850 ppi).
    -0.5" (base) or 0" (XR) XR Bilstein struts.
    Stock for the XR, they drop the base model 0.5" and stiffen the front.
    -1" (base and XR) Spindle drop spacer.
    The spacers can be made available from .5" to 1.5".
    Most commonly used are 1" drop spacers.
    Good luck finding them, I had mine made by Phil Dammit.
    They work by moving the spindle and UCA farther from the LCA by spacing the LCA and bottom of the spindle via the addition of aluminum spacers and longer bolts.
    DD4D70CB-44E0-4A2C-83AE-E3B70A89ACFF-732_7200942689ad5b79a076b53df81d6a4a5a216c86.jpg
    Install between part 5 and part 18.
    -2" (base) or 1.5" (XR) SOS drop kit from TundraRacing.com
    Will fit all base and XR models.
    Designed to drop the XR 1.5" then account for natural difference in spring height to get 2" for base models.
    Basically what you're getting is a lower spring spacer.
    Install between part 6 and part 9.
    Sway Bars
    These XII Performance sway bars are thicker than stock and reduce body roll.
    Note: base models do not have a rear sway bar.
    If you are using lowering springs and spindle spacers the top nut on the strut stem will not thread down and secure the strut to the tower.
    You will need to stack washers or fabricate spacers.
    Before:
    274D10A7-8937-4D53-91FB-DBAB8A23B162-522_beff5db5a02cbb5ab84349c4d2408ea08bfe938b.jpg
    After:
    44BA699E-FE63-4BC0-8593-789EE5E69DF9-333_2e55c62a0c8518933079d6336fbdc03323c24479.jpg
    __________________________________________________ __________________________________________________ __________________________________________________
    In the air: DJM arms, 1" drop coils, 1" spindle spacers, XR Bilstein struts; equalling 6" drop and camber maxed out at 3* of negative camber.
    6FC97039-78CB-4CA5-98CE-7A8FBD6DA683-732_4250be92dddb3a5cb054a64b524deb7eb4345089.jpg
    On the ground:
  2. Nov 4, 2012 at 8:22 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    lol wtf dude^
    otherphone likes this.
  3. Nov 4, 2012 at 8:33 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I have been on tw today for almost 14 hours on and off TODAY. Welcome to you
  4. Nov 4, 2012 at 1:23 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Mods, please make sticky....
  5. Nov 4, 2012 at 1:27 PM
    dually
    dually Low and slow
    No not really.. Possibly link 'how to's' or make your own!
    oh, just checked my itinerary i'll be there till the 10th, we'll have to grab a beer.
    pinktaco808 likes this.
  6. Nov 4, 2012 at 1:51 PM
    dually
    dually Low and slow
  7. Nov 4, 2012 at 1:53 PM
    dually
    dually Low and slow
    Looks as though they sit on the bottom perch.
  8. Nov 13, 2012 at 3:17 PM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    This is awesome! I like seeing the options all in one place. Great work!
  9. Nov 13, 2012 at 4:53 PM
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
    excellent work ryan!
  10. Nov 14, 2012 at 12:40 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    has anyone figured out the BPV issue yet? It's starting to bug me a little (feel stupid when I brake too, looks like I'm being all dramamtic with my stops :( ).
  11. Nov 17, 2012 at 9:44 PM
    Mr.Schertz
    Mr.Schertz Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
    so if I want a minimal drop but a little added performance on handling go with bilstien shocks and struts for a .5 in drop?
  12. Nov 19, 2012 at 6:11 PM
    Kavik
    Kavik Kavik
    Texas, DFW
    Alright I found the QA1 on paradise racing but I am unsure of which ones to get. Is there a specific part number I can search?
  13. Nov 20, 2012 at 9:14 AM
    Kavik
    Kavik Kavik
    Texas, DFW
    Hmm, I searched the site with that part number and it didn't pull up anything, I will try again or maybe I will just call up after I get off work.
  14. Nov 21, 2012 at 8:33 PM
    Mr.Schertz
    TEXAS
    wheres the best place to get the bilstiens? Are they easy to install?
  15. Nov 25, 2012 at 6:17 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Nice reference hell of a coverage of the dropping method. If anyone needs drop spacers let me know.
    Mighty Mighty Mouse likes this.
  16. Dec 29, 2012 at 12:49 PM
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    Some info that might be helpful to add to the already super-helpful 1st post in this thread... ;)
    The part number for the MOOG ball joints for a 2005-2011 base model Tacoma is as follows. I'm assuming nothing has changed for 2012-2013?:
    DJM now sells their lowering kits with the ball joints already pressed in. I don't know what brand they use, but the photos show that they are grease-able. Considering DJM only charges <$100 more for kits that include the ball joints, that's a money and time saver if you're not going to use your OEM ball joints:
    I'd so like to go the route of getting the front control arm kit with the joints already pressed-in, but I'm thinking that having the control arms sand blasted and powder coated might be a good idea since the DJM finish has a tendency to flake-off pretty quickly (in my experience).
  17. Dec 29, 2012 at 1:15 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Big thread on xru about powder flaking and 1st gen fatigue/failure on the calmax arms. Just got my set, plan on beefing them up and repowder coating them.
  18. Jan 17, 2013 at 11:19 AM
    Hot Taco
    Richfield, WI
    I'm a little confused here... why would a truck see a 0.5" drop due to shocks? Why would a shock help correct the "Tacoma lean"? The weight of the truck is resting on the leaf springs, not the shocks. Am I missing something? :confused:
    I would think that in order to correct the lean, one would have to use different sized lowering blocks.
    I'm guessing the one shock is longer than the other to help the shock better control the heavier side of the vehicle (gas tank and driver), but I don't think it has much to do with ride height.
  19. Jan 31, 2013 at 3:26 PM
    Bizarroterl
    Bizarroterl Well-Known Member
    SJ, CA, USA
    2009 Accesscab 4cyl 2wd, 2010 Xrunner
    DJM 3/3, Hellwig rear sway, Rear Spoiler, Truck Covers USA tonneau, rear spoiler. Dynolock tailgate electric lock. Pioneer avic-z110bt. Xrunner is stock for now
    You forgot the Hellwig rear sway bars. :(
  20. Jan 31, 2013 at 3:29 PM
    Hot Taco
    Richfield, WI
    Swaybars don't have much to do with lowering a truck ;) "Suspension performance modifications" would probably be another topic.
