Comprehensive 5-lug 2nd gen lowering info.
Discussion in 'Street Trucks' started by tcBob, Nov 4, 2012.
  1. May 7, 2013 at 9:15 AM
    #81
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Yup, you can do the spacer without buying new coils.
  2. May 7, 2013 at 9:25 AM
    #82
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Does anyone know if you can take the stock sway bar from another Tacoma and mount it in the base model?
  3. May 7, 2013 at 9:48 AM
    #83
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    I'm the one that recommended he buy the stiffer stock height coils before doing the 1" spacers. Being that at 5" of drop up front he will want to be stiffer so as to not bottom out every where
    and no K only 5 lug sway bars work. I bought a 6lug one once, it no worky.
  4. May 7, 2013 at 10:11 AM
    #84
    Phil Dammit
    Your Mom
    Tempe, Arizona
  5. May 7, 2013 at 10:12 AM
    #85
    Kavik
    Kavik Kavik
    Texas, DFW
    Damn, well atleast it is money saved. Thank you Phil.
  6. May 7, 2013 at 11:53 AM
    #86
    Phil Dammit
    Your Mom
    Tempe, Arizona
  7. Jun 21, 2013 at 7:29 PM
    #87
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    I think this information is incorrect. I've got new Bilsteins in my hand and the shorter shock, part #48540, is listed as the left shock, where as the longer shock, part #48530, is listed as the right shock. I.e., the shorter shock goes on the driver's side and the longer one goes on the passenger side.
    Seems counter-intuative. The only thing I can figure is that because the gas tank is on the driver's side, Toyota made the shock a tad shorter so it doesn't bottom-out?
  8. Jul 4, 2013 at 1:52 AM
    #88
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Anyone figure out how to relocate those damn e brake lines, I rub them majoooooor when I got my street bike in the back. Need a solution ;*(
  9. Jul 5, 2013 at 9:55 AM
    #89
    Phil Dammit
    Your Mom
    Tempe, Arizona
    My only solution involves me welding a bracket and zipties and I still haven gotten around to doing it as I'm saving up for the 2nd gen QA1 coilover kit
  10. Jul 5, 2013 at 11:36 AM
    #90
    jmarquez808
    Jess
    Hawaii
    Ah! So they are done making the coilovers? How much are they looking at? So will that make the front not so stiff lol. Interested in those too. Do they have any information on them yet? Damn wish I knew how to weld I'd do the same. Hoping I can figure somthing out.
  11. Jul 5, 2013 at 11:40 AM
    #91
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Not done yet but close. Group buy is happening so price is still up in the air. Ride quality is all dependent on how you adjust them. Get on XRU in the djm vendor thread to keep updated.
  12. Jul 5, 2013 at 8:08 PM
    #92
    pinktaco808
    pinktaco808 Hot Steppa
    coilover for the front so can way lower than 3
  13. Jul 5, 2013 at 8:31 PM
    #93
    Hot Taco
    Richfield, WI
    While coilovers are usually height adjustable, the main reason for getting them is performance. Even if XII's new coil overs are adjustable to 3", you'll still need a DJM kit to get your truck into alignment.
    When I got Bilstein coilovers on my car, they definitely made me a believer in coilovers for performance. On our trucks, however, I really think the leaf springs in back are by far "the weakest link", so I personally am not going to spend hundreds of dollars to improve the front suspension only to have the back end still bouncing all over like a pogo-stick :eek:
  14. Jul 5, 2013 at 8:51 PM
    #94
    Phil Dammit
    Your Mom
    Tempe, Arizona
    They are only adjustable up to two inches, but are worth it. Plan to ditch my 1inch spacers once I get these. Will also be gettin rid of my higher ppi stock height and almost new billys while ill at it. Then I'll 4link the rear and sell the 6lug leafs, blocks, and qa1s in the back
  15. Jul 5, 2013 at 9:04 PM
    #95
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Sounds like you have not adjusted your QA1s properly
  16. Jul 5, 2013 at 9:35 PM
    #96
    Kavik
    Kavik Kavik
    Texas, DFW
    Is there a 4 link setup yet for 2nd gens?
  17. Jul 6, 2013 at 9:32 AM
    #97
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Nope:(
  18. Jul 6, 2013 at 11:02 AM
    #98
    Kavik
    Kavik Kavik
    Texas, DFW
    Sadness :(
  19. Jul 6, 2013 at 2:29 PM
    #99
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Indeed
  20. Jul 6, 2013 at 2:47 PM
    #100
    Kavik
    Kavik Kavik
    Texas, DFW
    I am guessing there isn't eve a 2-link
