Compressing Springs
Discussion in 'Texas' started by Taco76087, Mar 27, 2010.
  1. Mar 27, 2010 at 2:26 PM
    Taco76087
    Taco76087 [OP] Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    i need help removing my coils from the shocks. My spring compressors don't really fit. If anyone could help me install my 5100's, I just need help with the coils.
    Thanks. I'm in the DFW area.
  2. Mar 27, 2010 at 2:40 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Why don't the spring compressors fit?
  3. Mar 27, 2010 at 2:54 PM
    Taco76087
    Robert
    Weatherford,Texas
    I got the set I have on the highest coil I could get the hook deal on, which was only about half way up the spring. The coil is still touching the top plate. So do I need another set of compressors to get it the rest of the way? To get enough space between the coil to fit the hook of the compressors?
  4. Mar 27, 2010 at 3:05 PM
    ikataco
    ikataco Well-Known Member
    06 DC Sport
  5. Mar 27, 2010 at 3:07 PM
    Taco76087
    Robert
    Weatherford,Texas
  6. Mar 27, 2010 at 3:09 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I understand your problem. Even though you've compressed a section of the coil, the rest of the coil has expanded enough to make up the difference. Sometimes you can take the top bolt off even though the coil still touches the plate. As you take that bolt off, you'll get another 1/4" or so of room. If you choose to try this, do it very carefully!!!! Have both ends pointing in safe directions. If the bolt is getting easier to turn, you're probably ok. If the bolt stays tight as you run out of threads, don't continue.
    Is the compressor the Autozone two separate bolts with hooks type? If so, you can get them farther up the coil. First, take each bolt apart. Working with the pieces individually is easier than working with the whole compressor. If you can't put the hook in higher at first, start it lower then spin it around the coil to a higher spot. Do the same with the other side going the other direction, then thread the bolt through the hooks. I've done this 3 times with those Autozone compressors. Every time the hooks needed a little rubber mallet love to convince them to go where I wanted them.
  7. Mar 27, 2010 at 3:40 PM
    Taco76087
    Robert
    Weatherford,Texas
    Hey thanks for all your help. I'm going to try and see the bolt, if it turns loose, if not, I'm going to go rent some compressors and have four on there for good measure. Thanks
