compression is only 55!
Discussion in '4 Cylinder' started by Scummy, Jul 13, 2011.
  1. Jul 13, 2011 at 5:54 PM
    Scummy
    Scummy [OP] SCUMBAG CUSTOMS
    Phelan, CA
    hopped up 96 single cab 5 lug 4 banger
    Fabtech uppers and spindles, extended shackles in rear, k&n intake, flowmaster exhaust, and much more to come
    Did a compression test today cause my engine light is on and the obd2 reader says its misfiring in the 4th cylinder. All the others were reading around the same but this one. Any ideas? Already have the valve cover off to check those.
  2. Jul 13, 2011 at 6:04 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Has it gotten hot recently ? If so, checked for water in the oil? If none apply I'm thinking valve/valve seat saying adios, not leaning towards a head gasket (cause that would probably involve 2 cylinders comp. being low) no knocking so a hole in the piston is out,maybe cracked head in combustion chamber ?? :notsure:
    could be alot of shit:confused:
    why valve cover off ?? checking cam for flat spot ? (which if it was both valves would be closed)
  3. Jul 13, 2011 at 6:06 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It depends on where the compression is going. Make a leakdown tester(if you have access to an air compressor). You will be able to tell what the problem is without a teardown.
  4. Jul 13, 2011 at 6:21 PM
    Scummy
    Phelan, CA
    I have it off to check to make sure I don't have any stuck valves.
  5. Jul 14, 2011 at 2:15 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Good call.
    The leakdown tester will show where the leak is. Air noise in exhaust, bad exhaust valve. Air noise in intake, bad intake valve. Air noise in oil fill, bad rings/cracked piston. Air noise in radiator, cracked cylinder/blown gasket.
    It has it's limitations, but it will give you a solid indication of cylinder health. They say 20% leakage=bad motor, but i'd say it's more like 10% and time for rebuild.
    Google homemade leakdown tester. It will consist of two gauges, a regulator, orfice, valve, one male and one female quick disconnect. You make the orifice by stuffing one tube with epoxy putty and drilling the orifice. I think it's an"F" drill bit, but I'm not sure.
